08-04-2021, 08:34 AM | #8427 | |
Rep 31
08-04-2021, 01:29 PM | #8428 |
Rep 1,701
Drives: 22 X3MC MBB - C-17 Globemaster
PSA,
Updated my ID4 to ID6lite via easybimmercoder, and the MMI still works perfectly. So best of both worlds. Native Carplay and MMI for Android. |
08-04-2021, 02:18 PM | #8429 |
Rep 1,454
Can you connect to the car's stock USB for wired CarPlay after you got the ID6 coding? Thanks.
2022 CT4-V Blackwing 6-speed
08-04-2021, 03:17 PM | #8430 |
Rep 376
has the bluetooth echo issue been resolved while on calls (believe this happens for Logic7 install-based systems)? i saw some previous posts indicating they made (andream) firmware improvements to mitigate this. i saw another post indicating that using OEM BT would improve calls.
2010 E92 Monaco Blue 335i / Gray Dakota Leather / Steptronic / Sport / Premium / Navi / L7 / 18" Performance Wheels / HPFP fail @ 8400 miles (replaced with #933 pump) // MODS: Mishimoto OCC | VRSF CP + Turbosmart Dual Port BOV | RB PCV Valve // Maintenance: Walnut Blast @ 56k | Spark Plugs Replaced @ 56k | Addons: BN2000 Combox // Andream Carplay // Rear Camera // Spark Plugs (.022 gap) and Coils Replaced 73.1k
2019 G01 Carbon Black X3 M40i / Premium / Driver Assist / 21" on Bridgestone Alienza RFT |
08-04-2021, 03:19 PM | #8431 | |
Rep 2,590
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
08-04-2021, 04:20 PM | #8432 |
Rep 499
08-05-2021, 05:38 AM | #8434 |
Rep 11
It doesn't work for me. I connect it to iphone hot spot and to home wifi network.
08-05-2021, 09:24 AM | #8435 |
Rep 499
08-05-2021, 11:00 AM | #8436 |
Rep 31
08-05-2021, 11:55 AM | #8437 |
Rep 584
I received my Andream screen from ewaying today along with a reverse camera. There was no instructions provided in the box. Does anyone have fitting instructions I could use for installation. The screen seems to be straightforward. But the camera wiring isn't obvious. Provided in the box is a small black box with +and - on it and written Chinese. And it's got red and black wires either end. The camera/handle has a red and yellow plugs and some tiny white wire sitting out of a mold.
Any help would be appreciated Thanks |
08-05-2021, 12:17 PM | #8438 | |
Rep 11
08-05-2021, 12:19 PM | #8439 | |
Rep 499
You mean a little 'box' with wires? This is a noise suppressor in case you use the rearlight 12V connection of the car itself on the bulb. But it's better to use the MMI 12V rear light connection. It uses the DCAN signal when the gear is in reverse. Last edited by RAAF12; 08-05-2021 at 05:01 PM.. |
08-05-2021, 12:59 PM | #8440 |
Rep 584
08-05-2021, 01:06 PM | #8441 | |
Rep 11
Use CVBS OUT labeled "reverse camera" |
08-05-2021, 01:11 PM | #8442 |
Rep 584
Thanks.
[/B]2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
08-05-2021, 01:31 PM | #8444 |
Rep 11
08-05-2021, 01:42 PM | #8445 |
Rep 584
The 2 yellow plus on the main loom are labelled CCD CVBS and the other DVR CVBS. There are 2 power wires on the link also. The pink one of labelled CAMPOW and the other DVRPOW?
08-05-2021, 06:09 PM | #8446 |
Rep 584
Thanks for your help everyone. I have it installed and working. I know the specific errors to us for the rear camera. It was the pink pretty wire and ccd-cvbs yellow connector.
Last question. Does anyone have the pin for the factory settings? The screen in idrive is the same size as the 6.6" screen. Like a split screen. Thanks
08-05-2021, 06:29 PM | #8447 |
Rep 376
would this require for me to install the mic adapter that comes with the andream box? or do i not have to do any installation related to the mic? thats one area i was confused with the installation process, whether to install the mic or not, since i already have the OEM mic installed in my car.
08-05-2021, 07:12 PM | #8448 | |
Rep 247
edit 8/17/21: I've gone back down to 20.06.02. I've had it happen sometimes where the volume of the mmi gets really low when it switches from idrive to mmi and vice versa. Seems to be happening a bit more frequently. Will give the newer firmware a try with the 20.06.02 MCU. edit2 8/19/21: 20.06.02 works better with 3.5.0.9.gpe.b than 20.10.22.16. Last edited by corduroy; 08-19-2021 at 06:11 PM.. |
andream, android, android auto, apple, carplay, mmi, retrofit |
