09-18-2021, 07:01 PM | #8757 | |
Rep 1,217
09-19-2021, 02:02 AM | #8758 | |
Rep 92
09-19-2021, 11:33 AM | #8759 | ||
Rep 1,217
09-19-2021, 11:58 AM | #8760 |
Rep 5
Hi everyone,
Which version should I need to update?
Also, would the audio bluetooth "hack" also work with an Android phone and Android Auto? If yes, how do I achieve streaming music over bluetooth and have Android Auto running? |
Ma_rtas0.00 |
09-21-2021, 05:10 AM | #8761 |
Rep 22
Hi
I just got Andream MMI box for my F36. 2015 NBT ID4. Everything works fine except that if I hold back button and want to use OEM menus MMI box forces itself back to CarPlay pretty much instantly. Is it a bug or is it ment to do like this when carplay is connected? If I disconnect carplay from phone, then everything works like charm in OEM menus. Its little bit annoying that I have to disconnect carplay for that. I use OEM bluetooth calling and music ( I have Harman Kardon and MMI has terrible sound), so carplay basically is only for Waze traffic info and sometimes for navigation. I have newest software,I belive. SDK 25.0.0.7.0.0.2.0 CUST B2_V1.5.10 MCU 21.6.7.116 HW BMW_NBT2_1_G |
09-21-2021, 05:37 AM | #8762 |
Rep 71
09-21-2021, 09:55 AM | #8764 |
Rep 5
Hi everyone,
I can't seem to achieve this bluetooth hack thing with my android device. I see on youtube that people are able to stream music over bluetooth with OEM sound while also having the MMI box enabled/connected. How do I do this? Android phone with android auto, OEM bluetooth music. |
09-21-2021, 10:43 AM | #8765 |
Rep 92
After a week with carlinkit 9.5.10 - I strongly recommend updating! Works perfectly, no bugs, no freezes, fast and even resolution is out of a box fine.
sbrook0234.50 Firefly1337846.00 |
09-22-2021, 04:27 AM | #8766 |
Rep 15
Hi!
Andream unit A for NBT. Used to run the custom firmware with no trouble at all. First with Android and now with Apple Car Play. Just updated to v3.5.0.9.gpe.b Runs smooth and no problem at all!!
Proud owner of BMW 2015 X5 F15 30d
Firefly1337846.00 |
09-22-2021, 09:36 AM | #8767 |
Rep 41
for some reason my system refuses to recognise the ISPBOOOT.BIN file for the latest Carlinkit 9.5.10 software.
i just checked and used the same USB to update to 9.2.20.yl.b without any issues the system just give me an error that it cannot see the ISPBOOT.BIN file. bizarre that said the 9.2.20 version is so much better than the custom version. works smoothly and no longer crashes. phone no longer stutters either. |
09-22-2021, 10:10 AM | #8768 | |
Rep 339
If the answer is yes, proceed to next steps..Even if you don't, the factory professional system sounds better than the android based one with phone calls AND music. step 1 Is the cars MMI device set to use the cars bluetooth? step 2 Is car "idrive" set to stream both phone AND music? Make sure the MMI device is connected first, wifi AND bluetooth...then do the idrive system... If you can stream music from your phone via Bluetooth, then after you change a few settings, Harmon Kardon sound will stream as well. |
09-22-2021, 10:34 AM | #8769 |
Rep 10
Hi,
I've made the update to v3.5.0.9.gpe.b without any issues Thanks for the update |
Firefly1337846.00 |
09-22-2021, 11:08 AM | #8770 | |
Rep 41
bizarre. all other updates worked on the older USB. the lastest version needed a different USB |
09-22-2021, 11:23 AM | #8771 |
Okurrr
Rep 54
Sorry this took me a while to get back to, my car ended up going in the shop for some work on the cooling system. I ended up taking everything apart and while the antenna did fall off where I attached the sticky part on my dashboard, it remained connected. I went ahead and disconnected/reconnected everything anyway, but still no dice. It's as if the unit isn't broadcasting the WiFi/Bluetooth signals now. I even tried another iPhone that had never been used with the car or this screen.
Maybe I have a dud?? |
09-22-2021, 12:07 PM | #8772 | |
Rep 499
You can check the wifi reception with an wifi scan app. For me I use Android Wifi Analyser, I see the transmitter of the MMI box named 'Carplay' in the 5GHz band. If your antenna ain't broken and you don't see a BT and a Wifi logon the phone you have a problem. If you have all the wires firm connected and the system is not working maybe the seller sent a new box, they have email. Last edited by RAAF12; 09-22-2021 at 03:04 PM.. |
AlexAnthony4.00 |
09-23-2021, 03:32 AM | #8773 | |
Rep 92
2. Try to update from 9.2.20 to 9.5.10 - it's possible that older version can't jump to 9.5.10; 3. Check MCU if 2 is not working (especially if you are using MCU from a "custom" firmware) - update to the latest one on a first page and than try to update to 9.5.10 again Last edited by yulian; 09-23-2021 at 03:42 AM.. |
09-23-2021, 09:51 AM | #8774 |
Rep 339
Question, last night I updated the software to the newest carlink software. I can confirm that the Harmon Kardon wireless hack, works as usual...My question is. anybody got a clue what Hicar map confirmation is in the MMI settings?
09-23-2021, 11:01 AM | #8775 |
Rep 247
HiCar is Huawei's Carplay/Android Auto alternative. I think it's only available in China.
09-23-2021, 01:47 PM | #8776 | |
Rep 18
Does that hack work also with usb connection? The sound stops playing through bluetooth when I connect the usb port to my iPhone. Bluetooth in idribe menu is set to phone and music and in mmi it is set to use car bt. |
09-23-2021, 03:09 PM | #8777 | ||
Rep 339
09-24-2021, 01:42 AM | #8778 | |
Rep 92
andream, android, android auto, apple, carplay, mmi, retrofit |
