11-25-2021, 08:18 AM | #1 |
Rep 5
Install 2015 iDrive screen on 2013 F30
Hi there,
I have looked everywhere for this but cannot find a definite answer. Is it possible to install the 2015 idrive screen in a 2013 f30? I broke the screen in the 2013 model and rather than putting the same screen in I wanted to install the nicer 2015 version. I do not want to do any programming, just simply want the nicer screen in place. |
11-28-2021, 02:18 AM | #2 | |
Rep 1,576
11-28-2021, 07:35 AM | #3 |
Rep 145
Just go to realoem.com and put your VIN.
You can check there which screen will fit your car. (You will see the part number you need). *This is what i did and had no issues. If you want to buy bigger screen (8.8), you will also need coding because the big screen has higher resolution. |
11-29-2021, 11:34 PM | #4 |
Rep 1,976
Drives: 2020 G20 320i M Sport
What sized screen is it and what kind of head unit do you have?
Most are interchangeable between these two model years but if you're getting a 2015 8.8" screen from a 2 series, that may be a different story.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
