12-01-2022, 12:54 AM | #1 |
Rep 906
Towing after misfueling scenario
I've been driving diesel cars for over a decade now and never once misfueled. But always wondered: if the car was misfueled and was caught early right at the pump, what would be the procedure to get it to a shop?
In order to put the car on a flatbed, the ZF8HP electronic unlock requires cranking the engine. Can't crank the engine because of gas in the tank and I'd imagine you can't pull the fuel pump fuse as that would run the HPFP dry. Is the only option to get under the car and release the mechanical unlock?
2020 i3 Rex: Capparis White, Giga World |
12-01-2022, 02:17 AM | #2 |
Rep 8,495
My understanding is that, yes, going under the car to engage Neutral mechanically is the only way in that scenario.
It's a ridiculous design. Here in the UK I'd just insist that the recovery vehicle had a crane with specialist wheel cradles, or wheel dollies as a fallback option.
12-02-2022, 10:48 AM | #3 |
Rep 424
Why cant you just turn the car to acc and put it in neutral? Guarantee the shop will do that once it gets to them anyway. Understood you dont want FP to run, but I imagine it wont be sucking the misfuel just priming for pressure. But I dont have any data to support that assumption
12-02-2022, 11:58 AM | #4 |
Rep 1,802
It seems completely fine per BMW to pull the power supply to the low pressure fuel pump to do the electronic unlock procedure. See attached. It's not convenient, but it does work.
The HPFP will not have time to run completely dry, as its swimming in a lot of diesel.
12-03-2022, 11:19 AM | #5 | |
Rep 906
12-03-2022, 12:19 PM | #6 |
Rep 1,802
Fuse 165 (20 Amp) on the rear fuse box in the trunk area, or unplug the electronic fuel pump module (EKPS) which is located behind the passenger rear seat side cushion thing.
capt_slow556.00 |
12-06-2022, 05:37 PM | #7 |
Rep 810
There should be plenty of diesel between the tank and injectors to start the car to pop it in N should you realize before the car dies on you. I think the diesel filter itself holds a good 300ml plus.
12-06-2022, 07:05 PM | #8 |
Rep 1,802
The injectors don't spray until there is 200bar of rail pressure, so it may be questionable if it would start.
To be extra safe, disconnect the fuel rail sensor and crank all you wish. It won't start then even with all the fuel.
