11-25-2022, 11:30 AM | #23 |
Rep 218
12-05-2022, 11:56 AM | #26 | |
Rep 218
I found my mass flow reading was to low, near 29lb,but it should be 35-36lb I'll try to find out |
12-10-2022, 05:03 PM | #27 |
Rep 1,058
I don’t want to share logs with this publicly, however to get the MAF to read 35-36 lb/min, you will need a turbo inlet and cold air intake. My setup for that is afe magnum stage 2 intake (whatever this means) and the ftp turbo inlet. Tuner can get a little more flow as well with boost and load targets. Otherwise the stock MAF sensor within BM3 (software limited) won’t read higher than 35.8 lb/min. You can achieve a little higher than this by logging in metric and it’ll show up to 37 lb/min when converted from metric (anything over 974 or higher logged is 36 lb/min) imperial. Rule of thumb is take the metric number and divide by 27.2 for a rough estimate
12-10-2022, 10:03 PM | #28 | |
Rep 218
MAF reading in my log shows that 3500 RPM MAF 22.1 Mass Flow HFM 20.2 4500 RPM MAF 30.1 Mass Flow HFM 26.1 5500 RPM MAF 36.8 Mass Flow HFM 29.7 6000 RPM MAF 37.4 Mass Flow HFM 31.1 Readings deviate more as RPM increases. I have seen your log last year, this is the reason I replaced TTE400. In my memory your deviation is not so much , only about 2lb. So I am a little curious, I have never seen such a deviation in other log data. In the afternoon I will replace it with a Wagner Tuning EVO2 intercooler, and re-record the log to analyze whether the difference in the intercooler caused |
12-10-2022, 10:14 PM | #29 | |
Rep 1,058
MAF 37.4 - highest it'll read in BM3 "Mass Flow HFM 35.8" - highest it'll read in BM3. This is an older log on 93 octane before I swapped to metric. Boost is different now (holds 25.2psi to redline) + more aggressive load targets + WGDC:
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block |
12-11-2022, 01:48 AM | #30 | |
Rep 218
1 pound represents 10 horsepower, which means I'm losing a lot, and that's what I'm trying to work around. Wagner Tuning EVO2 intercooler being installed, I'll re-log when I'm done, hopefully that fixes it You're maybe making 400WHP now? Great work |
12-11-2022, 09:47 AM | #31 |
Rep 1,074
Yes arp rod bolts, they are usually the failure point.
Instagram: M2_Medusa
04-10-2023, 01:59 PM | #32 |
Rep 218
schedule
I hardly care about MAF, the sensor reading seems to be wrong, I can clearly feel more horsepower, but the MAF reading is still under 31lb With the help of navardi, we found that it seems that the stock BOV cannot be stabilized at 25PSI, and there will be large fluctuations after reaching 25PSI. I'm buying the BOV from turbosmart that navardi mentioned, hope that will fix the problem Recently I saw a guy running 27-28PSI, ignition 12 degrees. 60-160KM only took 7 seconds, which seems to be a good reference. |
04-10-2023, 07:54 PM | #33 |
Rep 1,058
Turbosmart is the only thing I’ve found that holds the boost and doesn’t leak.
Gfb leaks above 335 whp on 93. Forge leaks around 340 whp on 93. Turbosmart holds without issue. Talked to turbosmart and it’s the same kompact unit that’s used on n55, GTRs, r8s, etc that see 35+ psi through them at events. Recirculating version makes no noises (car sounds like stock), dual port is dual port and brings a “BOV noise” for anyone wondering
06-23-2023, 02:10 PM | #34 | |
Rep 218
I am stuck... Can you maintain 25psi till 6500rpm? |
06-23-2023, 07:01 PM | #35 |
Rep 1,058
There are too many variables for every persons car.
What fuel are you using ? List all your mods and self mods you did (that wastegate actuator arm mod was pure BS). Idea is you peak boost and then use the least amount of boost to hold the air flow through the turbo.
06-25-2023, 10:13 AM | #36 | |
Rep 218
TTE400turbo FTP V2 Turbo Inlet FTP Charge pipe + Boost pipe WT Intercooler Turbosmart DV JBOM Catless Downpipe 335i muffler Aquamist WMI system runing 700cc 100% meth I wish keep 25psi to 7000RPM here is the log,I'm very surprised why? https://www.bootmod3.net/log?id=648f...90c65999748532 |
06-25-2023, 09:16 PM | #37 |
Rep 1,058
This turbo doesn’t make 25psi to 7000. It is a td04-19T. Thus 21-22 psi is the max at 7000 rpm or so. It also depends on fuel. 95 Ron is similar to 89 octane in the USA. Thus boost require timing which requires a proper octane. Methanol injection can help, but isn’t a 100%.
Looks like for your environment the turbo is maxed out. If you are PWG that’s harder for boost control but it looks the best it can do. Are you at sea level or what’s your altitude ?
06-25-2023, 10:21 PM | #38 | |
Rep 218
I see you can still maintain 24psi at 6300rpm, so 6800rpm should be at least 23psi I also have a log of a test process that can reach a similar level, but the pressure fluctuation is very severe https://www.bootmod3.net/log?id=6481...729bdbf9d53a4b |
06-26-2023, 10:35 AM | #39 |
Rep 1,058
Are you electronic waste gate or pneumatic waste gate ?
My “stock engine tte400” record turbo run peaked 23 psi and held 21 to redline. More boost =/= more power after flow is maxed out.
06-26-2023, 11:16 AM | #40 | |
Rep 218
It looks like I'm currently performing about the same as your previous stock engine TTE400. How is your stress performance now? Peak 25,then 24-23 last to the red line? |
06-26-2023, 12:00 PM | #41 |
Rep 1,058
I have a development cam mod at the moment so using boost to redline doesn’t exactly give the same results to compare apples to apples.
07-19-2023, 09:53 AM | #42 |
Rep 218
I'm almost done with the final adjustments at the moment, I'll switch to the AFE intake kit in a while and log again to see if anything changes
07-20-2023, 11:51 PM | #43 |
Rep 1,058
No need. Hit the MAF HFM channel and post a photo. Curious to see if you are flowing the same if not more air than me. If so that means you may be faster
07-23-2023, 03:19 AM | #44 |
Rep 218
To be honest, my mass flow reading has been consistently low, even among the people around me. On the contrary, your mass flow reading is the most I have ever seen
