08-18-2021, 10:47 AM | #1 |
Rep 190,750
Agency Power B58 Intake Rebranded to VR Performance - Now Available! **NEW PRODUCT**
One of the easiest ways to gain horsepower and improve your throttle response on the BMW 40i B58, turbocharged engine, is with an air intake kit. VR Performance new short ram air intake kit for the M240i, 340i, and 440i is a great first modification to do. The intake kit is a complete replacement for the OEM air box. The kit includes a new aluminum intake tube with CNC machined MAP sensor mount, precision cut heat shield with mounting tabs, and a new high flow air filter. The MAP sensor mount has been CNC machined out of 6061 aluminum to retain the factory fitment for proper readings. It is than TIG welded to the aluminum intake tube for proper placement. The main part of the intake is the high flow air filter. It features an inlet on the end cap to allow for an even larger volume of air to come through than a standard cone filter. The design improves air filtration while increasing air flow. The air filter is finished off with the VR logo on the rubber end cap. The heat shield is water jetted from aluminum with rubber trim to provide a secure fit and seal when the hood closes. It is designed to prevent direct hot air from the engine being sucked into the filter. Each heat shield features the VR logo neatly cut out from the shield panel for added style. All parts are finished in a matte black powder coat for an OEM look while the cylindrical air filter features a blue element matching to the BMW Roundel logo. With the new air filter, your turbocharger can breathe better than the factory intake allows. This is noticeable as you step on the accelerator and hear the turbo work (sucking air noise). Release the throttle and the factory blow off valve noise (whoosh) is more audible and keeps you entertained through the gears! Features: Aluminum construction CNC machined MAP sensor mount Black powder coat for OEM look Reusable high flow air filter Fitment: BMW M140i F20 BMW M240i F22 BMW 340i F30 BMW 440i F32 Note: Heat shield was designed on the BMW M240i chassis and may require alterations or removal to work on the 340i and 440i. This product use to be under the Agency Power brand as AP-M240I-110. Same product different logo!
08-26-2021, 10:33 AM | #3 |
Rep 190,750
Its already available
08-26-2021, 03:13 PM | #5 |
Rep 190,750
im not sure i understand the question but i'll dm you the link
08-27-2021, 01:23 AM | #6 |
Rep 884
Thanks. What I meant was on your website when I would go to the intake section for the 340i it wasn't listed there.
2013 335is - sold
2011 335d |
08-28-2021, 10:43 AM | #7 |
Rep 190,750
its there now
08-29-2021, 09:25 AM | #9 |
Rep 190,750
Not sure what's going on as it's visible for me but I went ahead and refreshed the website. Please try now and let me know if you still cannot see it
08-29-2021, 01:42 PM | #10 |
Rep 95
08-30-2021, 09:04 AM | #11 |
Rep 190,750
09-08-2021, 11:57 AM | #13 |
Rep 190,750
09-16-2021, 12:41 AM | #14 |
Rep 141
Agency power sells the filter if you’re looking to get a replacement.
Sent them a email asking the same question a few months back when they postponed production of the intake. Here’s the link they sent me https://www.agencypower.com/agency-power-high-flow-air-filter-1719-bmw-m240ipolaris-rzr-rs1-20182020-p-152675811.html |
about94ninjas94.50 |
09-16-2021, 09:19 AM | #15 | |
Rep 190,750
09-16-2021, 11:00 AM | #16 | |
Rep 116
09-17-2021, 06:30 PM | #18 |
Rep 190,750
No issues, the website needs to be updated
zen_f308.50 |
10-15-2021, 06:28 PM | #19 |
Rep 39
Thank you Mike for the quick delivery on the intake. Quality and fitment is perfect. I had to make one modification which is getting larger hose clamps (90-110mm) from Amazon because the ones came with it seemed too tight. Overall very happy with the new intake.
10-16-2021, 08:37 AM | #20 |
Rep 190,750
Congrats
07-20-2023, 08:47 AM | #21 |
Rep 106
Anyone know where to get a replacement filter for these, the link now shows it unavailable. I have the AP version from a few years ago, but they are the same, right?
07-20-2023, 10:03 PM | #22 |
Rep 54
Contact VR and tell them what you are looking for. I just got a replacement by emailing it took a few back and forth but it did end up getting the job done! It was like 70 bucks though
