07-10-2020, 11:19 AM | #3191 | |
Rep 2,653
07-10-2020, 12:10 PM | #3192 |
Rep 814
Drives: 2021 BMW X3 M
Awesome!! Thanks! IAT's super hot but its like 105 outside so yeah. I miss the cooler days. It pulled so hard even on the stage 1 map during the winter lol.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
07-10-2020, 04:53 PM | #3193 | |
Rep 1,079
07-10-2020, 05:07 PM | #3194 | |
Rep 7,591
The other thing is that your MAF is pretty erratic for being on stock intake, but not much you can do about that. You are maxxing it at 41.4 which is pretty good airflow for stage 1. |
TK335iMSPT299.00 |
07-10-2020, 05:10 PM | #3195 | |
Rep 7,591
The other thing i would note is that your WGDC is really high after about 6k rpm. Like nearly 100%. I wouldnt rev past 6k anyways, its pointless, especially with stock turbo. Shift at or before 6k. |
07-10-2020, 05:38 PM | #3196 |
Rep 1,170
https://www.bootmod3.net/log?id=5f08...0b430700153dc6
here goes another pull still getting some misfires but this is a wot with "protunning freak" doing idk what. the car basically acted the same and here goes another one part throttle https://www.bootmod3.net/log?id=5f08...90c628bdfbf46f
bmw m2
07-10-2020, 05:56 PM | #3197 | ||
Rep 479
07-10-2020, 06:14 PM | #3198 | |
Rep 7,591
Did you try resetting adaptations? Did you try stage 1? Did you try a map other than ACN like 91 octane? |
07-10-2020, 06:15 PM | #3199 | |
Rep 2,639
Negative is bad, not everyone has access to E85 or good quality 93 oct, but quite honestly, your throttle angle stays at 100% the entire run, and the one cylinder that had a negative timing pull will probably go away as it was just adapting to the fuel. As you can see in the next 2 logs.
TK335iMSPT299.00 |
07-10-2020, 06:19 PM | #3200 | |
Rep 2,639
His timing is fine as long as it's above 5+ If you're expecting 8-10+, it's fairly rare unless gas quality is amazing, or people are running E85. There's alot of expectations that the good timing as to be double digits, but in real life scenario, having 5+ to 7+ is really good without meth or E85. Best way to tell if it's a bad log, is if throttle angle closes in the run, and doesn't stay at 100% (Usually a sign of either overboost, or timing pull.)
TK335iMSPT299.00 |
07-10-2020, 07:17 PM | #3201 | |
Rep 7,591
Regarding timing, i just said it "wasnt great" - i didnt say it was bad or he had an issue, merely made an observation on what i saw in the log. Personally, i would be quite disappointed if my timing was 3 or more degrees below target across all cylinders, but different people have difference expectations. Yes, some amount of timing corrections is totally normal and i always say you will drive yourself crazy chasing perfect timing (been there, done that), so it's up to him if he wants to just continue using this map or try a lower octane one to see how it looks. Its very possible to have more consistent power on a lower octane map if your higher octane map is always pulling timing (generally speaking, not necessarily saying this is a example of that situation). His timing targets are actually relatively high, but that's because he is on stage 1 map and timing targets decrease when boost increases. On stage 2 93 map i am pretty sure the timing targets peak at 9 at a little over 6k rpm. I have seen ozymandias435 collect numerous logs on 93 octane map with 93 pump gas in FL that have literally perfect timing in all of them. So yeah, it really depends on gas quality in your area and how much correction you are willing to accept before trying a lower octane map. For stage 2, its really the ethanol (or race gas) maps that will target over 10 degrees up top at full boost. I see up to 12.5 degree on MHD stage 2+ E20 map, for example. In terms of throttle closure, BM3 is very lax with throttle intervention. You almost never see a throttle closure unless something bad happens. So i suppose you can use that as a high level check to see if the DME really thought something was wrong, but the tune is not nearly as sensitive as MHD when it comes to throttle closure intervention for overboost or other general protection. Hell, the BM3 tunes even intentionally overboost (at least stage 2) at the beginning of the pull, and there is no throttle closure. |
TK335iMSPT299.00 |
07-11-2020, 02:01 AM | #3202 | |
Rep 1,170
it just doesnt do it on stock map
bmw m2
07-11-2020, 09:31 AM | #3203 | |
Rep 814
07-11-2020, 11:59 AM | #3204 | |
Rep 7,591
WGDC 100% means the WG is fully closed and the turbo is at 100% duty cycle - i.e., it is literally spinning/working as hard as it possibly can to maintain boost. Not something that is sustainable long term and it pushes the turbo way out of its efficiency zone. Its going to generate a lot of heat and potentially accelerate wear if you push it like that for a long time. It basically means you are pushing the turbo to its limit. Note that WGDC at 100% at the beginning of a pull is normal (sport + in particular does this so that the throttle response is better), but it should drop once you reach boost target, and then typically slowly rises back up with RPM. After installing my inlet and MPPK airbox mod, my WGDC is now in the 82-89% range from 2500-6500 rpm with 16.7psi peak on MHD stage 2+ E20 map. I see alot of BM3 tunes pushing it to mid 90s, but yeah, i just wouldnt want to run something that pushes it to 100% all the time. Here's an example of one of my logs so you can see what i mean: https://datazap.me/u/thejeremyman9/2...data=4-5-21-34 |
07-11-2020, 12:21 PM | #3205 | |
Rep 814
07-23-2020, 07:33 PM | #3206 |
Rep 252
Drives: 2017 Model S P100D
Quick question regarding the st2 e30 map:
Would it be safe to (carefully) drive on just 94 to get to the station that has e85 to finish the fill, or should I flash back to the 93 map for the 5min drive and then reflash the e30? I'm just curious how others do it when your reg gas and e85 are at different locations. I would prefer not to buy a jerry can if I don't have to |
07-23-2020, 07:47 PM | #3207 | |
Rep 7,591
codestar180.50 |
07-24-2020, 02:31 PM | #3208 | |
Rep 252
When I made my first fill and moved my car away from the pump to a parking space to switch to the e30 map, the head unit had thrown a fueling problem on the screen so I wasn't sure. After I flashed and cleared the codes it was fine though |
07-26-2020, 02:57 PM | #3209 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
Hey guys, so after my boost leak when I first installed everything, car has been running great. Absolutely zero issues.
I’m the type of guy that wants to make sure everything is running right, so I decided to do a log. I get this: https://www.bootmod3.net/log?id=5f1b...0b4377a7aa8254 Uhhh, is something majorly wrong? Seems like there’s something going on. I also have a showdown code 1A2108. |
07-27-2020, 02:11 AM | #3210 |
Rep 35
Has anyone tested the VMAX removal?
When I tested the top speed of my car I could not reach a higher speed than before, 260kph on the speedometer and 236kph according to Waze. |
07-27-2020, 11:29 AM | #3211 | |
Rep 7,591
The boost control is a little strange and you have a clear deviation from target. If you are PWG the drop off up top could be normal but you also fall below target quite a bit earlier on as well. Timing is also pretty bad. One cylinder even goes negative and there are alot of corrections. Fuel trims are also pretty high at >10% fuel added throughout the pull. Not sure if you are running an intake but MAF looks a bit erratic. |
07-27-2020, 11:30 AM | #3212 | |
Rep 7,591
I did 160 mph speedo indicated when my car was bone stock (Msport though, so i believe no speed limiter). I did 171 mph GPS indicated with stage 2+ 91 on MHD, which the vmax box checked, if that even made a difference. |
