05-22-2018, 10:17 AM | #1387 |
Rep 1,467
Anyone with N55, EWG, have an E30 map log I can look at?
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
05-22-2018, 01:42 PM | #1388 |
Rep 1,541
05-22-2018, 06:38 PM | #1389 | ||
IG @bmwF9xG80
3813
Rep 7,593
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
05-22-2018, 08:27 PM | #1390 | |
Rep 1,467
05-22-2018, 09:41 PM | #1391 |
IG @bmwF9xG80
3813
Rep 7,593
I can & do, just monitor your HPFP.
05-22-2018, 09:47 PM | #1392 | |||
Rep 180
05-22-2018, 09:50 PM | #1393 |
Rep 2,357
HPFP is one thing. Another is the trims which you might end up maxing out adding too much E. Consequent of that is running lean. I'd say that checking your trims/AFR is most important in this scenario. If the hpfp run out you will just get a misfire.
(A Dane in China) |
FSociety3812.50 |
05-23-2018, 09:31 AM | #1395 | |
IG @bmwF9xG80
3813
Rep 7,593
That is correct, I start with hpfp to keep it simple the OTS itself will run a decent AFR and with E15 i don't think the AFR or Trims will max out at all. I've tested E20-E25 on a 93 OTS but just for testing purpose and it was good, but i dont recommend others to do this unless they' know what they're doing and looking at. At the end of the day E30 OTS Map with E20-E30 blend is going to be better for that. +1
05-23-2018, 10:26 AM | #1396 |
Rep 1,499
bm3 will overwrite your MPPK but you can always flash back to the MPPK.
reddemon73103.00 |
05-23-2018, 03:15 PM | #1397 |
Rep 266
Just out of curiosity, how lean would the AFR need to get before I should start to worry? I heard these cars run pretty lean as is
2013 F30 335i
BM3, MPE, VRSF DP, VRSF Street HD FMIC, VRSF Chargepipe, AFE drop-in filter, Bilstein B14 PSS Coilovers |
05-23-2018, 05:56 PM | #1398 | |
Rep 2,357
(A Dane in China) |
05-24-2018, 05:52 AM | #1399 | |
Rep 504
16.5psi @ 6000rpm? stock turbo?
05-24-2018, 10:58 AM | #1400 |
Rep 266
This is the "Lambda [AFR]" parameter in my logs, correct? There are a couple other [AFR] parameters not sure what they are
2013 F30 335i
05-24-2018, 11:06 AM | #1401 |
Rep 1,541
05-25-2018, 01:20 AM | #1402 |
Rep 504
05-25-2018, 05:45 AM | #1403 |
Rep 216
Drives: F30 335i PWG
Anyone interested in selling their BM3 license?
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
05-26-2018, 03:04 PM | #1404 | |
Rep 1,541
My most recent log from today. I plan on getting the VRSF Race IC next. I bought their original street IC back in the day. I believe my IAT are causing my timing to not be as clean as it could be when I do very long pulls. 3rd through 6th gear pull on 8at. Should be about ~140mph when I let off. http://www.bootmod3.net/log?id=5b09b67dd10b432f2edcca10
05-27-2018, 09:39 AM | #1405 |
Rep 46
BM3 Help
Hey just wondering if anyone can help out, I tried making a support ticket but it won't let me login, it says "Error in Authorization"
I installed a catless DP and Stage 2 BM3 93 tune about a week ago. The car drives great but I have a fuel system malfunction code. Now I just had my LPFP recall done at bmw about a month ago, car always ran fine no codes. I tried to online re-code and I get this error message, can anyone help out? Is their and email address to contact BM3 directly or only though support tickets? Thanks! |
05-30-2018, 01:31 AM | #1408 |
Rep 2,499
I'm considering purchasing a license but was hoping someone could answer a couple quick questions. I've tried searching but couldn't find any solid answers:
- Car is a 335i EWG 1) Will exhaust burbles work on stage 1 91 octane? I am not looking for the backfire/shotgun type burbles. I'm just looking for a more aggressive and louder version of the stock burbles in Sport+ mode. 2) Can I run stage 2 without a downpipe? I plan on just eventually adding a FMIC and chargepipe to my car. I don't want to mess with the exhaust at all except for maybe a catback. Thanks in advance! |
