03-20-2019, 02:09 PM | #23 | |
Rep 3,540
How is the labor any different whether you use your OE bump stop or a new one? The top mount still has to come off of the OE front/rear struts/stocks and the bump stop slides right off. I guess if you count pulling the dust boot off of the OE bump stop to put on a new one it could be a minuscule amount of more work. |
03-20-2019, 02:57 PM | #24 |
Rep 5,392
Good question. That's what I assumed too from struts that I have changed on other cars. But that was the comment that a BMW tech made when he was installing mine. He held the top of the strut assembly up for a second and said "I'm glad we aren't changing the bump stops so I don't have to pull this apart". Then he grabbed the new Koni strut & Eibach spring, and kept going. That was it! I mentioned it as more of a time savings and less components to touch/go wrong rather than saving any money on labor.
12-21-2023, 07:07 PM | #25 | |
Driver
23
Rep 24
Really interested in reducing body roll for mine, but I spend at least half the year in wet weather. Already swapped out springs/struts and lowered. RWD. |
12-22-2023, 09:04 AM | #26 | |
Rep 5,392
The mods that had the biggest effect in wet were tires that are highly rated in wet conditions. I have Michelin Pilot Sport 4S. In rain, full crossdrilled brake rotors prevent water from being trapped between rotors and pads. They also have best bite so they improve braking. I use StopTech full crossdrilled rotors. What year/model do you have? Exactly which parts did you use? Sway bars focus on limiting body roll so they don’t do much while a car is going straight down the road. However the functionality of springs and sway bars can overlap. So at times the choice of one can affect the choice of another. One example in an F30 if H&R or Dinan springs were installed which have heavy spring rates, then I wouldn’t choose a rear 19mm or 20mm sway bar. A 16mm/17mm would be better. A heavy rear bar with heavy rear springs might cause lift under heavy cornering, reducing the tire patch. Another example is Bilstein B16 coilovers which are notorious for super high front spring rates. So leaving the stock front sway bar and installing a heavy 20mm rear sway bar might be recommended. A typical F3x with typical suspension and tires would benefit by reducing body roll by using a solid front 28mm H&R sway bar and a solid rear Eibach 16mm or solid rear KC Design 17mm sway bar. That would be a balanced combination. That typical F3x would even benefit from just upgrading the rear sway bar from the stock size which is often 12mm to a solid BMW 15mm, Eibach 16mm or KC Design 17mm. This would help reduce body roll as well as the excessive understeer of the stock F3x suspension. Note: I only recommend solid sway bars. Hollow bars are cheaper to make so more profitable to manufacture and prone to snapping which can potentially be dangerous. Hope this helps! |
12-31-2023, 10:34 AM | #27 | |
Rep 204
My car is a 2017 340 xdrive 6 speed MT, with adaptive dampers. After reading your and Farkies advises, my initial plan was to go with the Eibach springs (the higher E10-20-031-06-22 version), F80 bumptstop, H&R 28mm front sway bar, and an Eibach 16mm rear sway bar. I also ordered a f80 bracket with f32 V-shaped struts, to tighten the rear. But at the moment of ordering those parts, I couldnt order the front H&R 28mm front sway bar only, I had to take it with the rear one (20 mm thick), as a package. Now I am doubting to install both H&R swaybars, or to stick to my initial plan, and buy the Eibach 16mm rear swaybar (around 250$ more). It's not a great deal or extra money but, at the same time, I might be inclined to think that if H&R sell their sway bars as a package, they should work well together. I know that you recommended against a thick sway bar in the rear, when using stiffer springs, as this could lead to tire lift in hard corners. I also know that Eibach springs are stiffer than stock ones, but not that stiff in absolut. What would you do ? Just install both front and rear H&R sway bars and call it a day, or just the front H&R sway bar, and buy a thiner (16mm) rear sway bar ? Thank you very much!
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
12-31-2023, 11:50 AM | #28 | |
Rep 5,392
I have an F30 335ix, so essentially same chassis setup as your 340ix. When I installed the H&R Front 28mm and Rear 20mm sway bars with the Eibach -06 XDrive spring kit, FaRKle asked me if I noticed any rear tire lift under heavy cornering, but I didn’t in daily driving. He said that if I tracked the car it might be noticeable. Note: We aren’t talking about full tire lift here. Just a slight lift from an extra strong rear sway that might slightly reduce the tire contact patch of one rear tire. After that I tuned the car for more power and really tried to push it hard in high speed freeway on-ramp curves. That’s where I could just about notice it. Also I was on stock sized run flats and winter tires so square 225/45-18 setup. So that’s why I started recommending a slightly smaller solid rear bar than the H&R rear 20mm. In researching solid rear sway bars I found that my stock rear sway (easily found on realoem website) was 12mm and yours on your 340ix probably is too. On some models BMW installs rear 13mm, 14mm and 15mm bars. So the rear 15mm is an upgrade to a stock rear 12mm bar. Eibach makes a solid 16mm rear bar and KC Design makes a 17mm. Also ST Suspensions makes a 19mm rear bar. Although I had planned to swap out my H&R 20mm rear sway bar for a KC Design 17mm solid rear sway bar, I’m still using the H&R 20mm solid rear sway bar. I upgraded my tires to Michelin Pilot Sport 4S in square 245/40-18 on the stock 18x8 400M wheels, and now square 255/40-18 on APEX VS-5RS 18x8.5” ET40 (Front 3mm & Rear 5mm spacers make them perfectly flush). I’ve upgraded my engine power even more now but with the larger rear tires I do not notice any rear lift/reduction in tire patch size at all no matter how hard I push it. I gave you the entire detailed story so that you and others might have more details to go on to make an informed decision. If you were on the fence about installing both bars and thinking about maybe upgrading just the rear bar, then I’d suggest the solid rear 16mm or probably 17mm bar. With the 17mm rear, you could add the front solid 28mm later and it would still be pretty balanced. If yours is a daily driver or a weekend track car I don’t think you can go wrong installing both the H&R Front 28mm and Rear 20mm solid sway bars like I did. You will notice an immediate difference from the original F30 chassis that has a lot of body roll to a car that corners FLAT! Hope this helps! |
vcx83.00 |
12-31-2023, 12:25 PM | #29 | |
Rep 204
My rear wheels are the 18' 255 for summer, and 17' 225 for winter. After reading your experience, I will probably use the H&R front and rear sway bars. I usually don't track this car (just sometimes drift on splashed asphalt or ice), and it's essentially a daily driver, so even in spirited driving, I will probably not take corners hard enough to have that issue. Happy new year!
johnung4528.00 |
01-02-2024, 05:13 PM | #30 | |
Rep 3,408
johnung, if there was an award given to the member that consistently provides great information to other members, my vote would be you! Thanks for always providing well-informed responses that directly address the questions being asked and doing so in a humble, non-condescending manner. Happy New Year! |
johnung4528.00 |
01-02-2024, 05:25 PM | #31 | |
Rep 5,392
01-02-2024, 06:36 PM | #32 | |
Rep 3,947
01-02-2024, 10:32 PM | #33 |
Rep 5,392
Oh, good. That confirms what I experienced at lower street speeds with square 255/40-18. I’ve been extremely happy with my H&R F28mm/R20mm solid sway bar setup since the day that they were installed. Definitely on my Top Mods List.
01-03-2024, 11:52 AM | #34 |
Rep 103
Drives: M440i xdrive, X5, Acura MDX
How much of the instability in higher speed cornering do you think is from the rear toe angle changing/flexing and suboptimal tire contact? In other words, could this be fixed with coilovers and a rear toe link?…rather than sway bars.
01-04-2024, 04:10 AM | #35 |
Rep 63
01-04-2024, 06:19 AM | #36 |
Rep 3,947
So I never fit 275 width tires on the front, but the most immediate issue that I saw based on my Ohlins R&T and 255 front tires was that you needed the tire to clear the spring perch. If the overall diameter was just small enough or you have a bit more preload on the coil spring, you'd be able to clear the spring perch, but it would still be very close clearance to the strut / coilover body.
Then you would need a bit of fender rolling and -2.75 to -3.5 camber in the front. |
