BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Poor Brakes
      01-10-2022, 01:32 AM   #23
tpoddar
Drives: BMW 320i B48
Also, the 320d and 330i with 312mm and 330mm discs upfront share the same caliper specifications (can be used interchangeably) and use the same size of pads. How is that possible? Does it mean that most of the added brake disc size is just for added heat dissipation rather than larger surface area of contact for the brake pads?
      01-16-2022, 12:44 PM   #24
tpoddar
BUMP! Just wanted to check if switching from 300mm rotor upfront to the 330mm with the correct calipers will require any coding of the abs system or brake bias settings?
      01-16-2022, 03:05 PM   #25
Onizukachan
Great Teacher
Onizukachan's Avatar
1086
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Nope.
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
