BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > N55 Turbo Replaced but still blue smoke coming from exhaust
      01-14-2022, 04:20 PM   #1
f33_aish
f33_aish's Avatar
Drives: BMW 435i F33
Hi, hope everyone's well.
Just after some advice just had turbo replaced on my 435i N55 2015 following the seals failing
Had the car a day and it's still shotting out a load of blue smoke when idling in Park. Doesn't do this when driving only when car is parked with engine running.
First thoughts is oil still in the exhaust however I've driven it about 20 miles on A and B roads at speed and still smokes on idle
If it is still excess oil in the exhaust any idea on how long this takes to clear?
My Indy also did a compression test and was no oils leaks following the new turbo being fitted
[IMG][/IMG]
Thanks all
      01-15-2022, 10:23 AM   #2
f33_aish
f33_aish's Avatar
Bump
      01-15-2022, 10:57 AM   #3
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Residual oil
Leaking valve guide(s).
That's all I can think of.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      01-18-2022, 02:48 PM   #4
thejeremyman9
thejeremyman9's Avatar
4362
Drives: 2015 BMW 335i
Check the charge pipe to see if oil is making it from inlet to turbo to TIC to IC to CP.
      01-18-2022, 06:58 PM   #5
cfm56d7b
Did you have a chance to retrieve and examine any stored codes?
      01-26-2022, 04:39 PM   #6
weehe126
Drives: 2017 340i
20 miles isn't enough to burn off residue in the muffler. Could also be valve guide seals, bad PCV or piston rings.
