06-15-2014, 08:55 PM | #1 |
Rep 54
A/C evaporator freezing over?!?
Now that it is warm out and I am running the A/C all the time, I am running into an issue on my 2013 328. Around town, everything is fine but after several hours on the freeway, the blower is working but very little air is coming out of the vents. You can hear the blower working, but almost nothing coming out of any vents causing the whole car to heat up. If I turn off the car and let it thaw out everything comes back to normal. Lots of water coming from the evap case when parked. I strongly suspect the evaporator is freezing over. There is supposed to be software and sensors to prevent this. Anyone else having this issue or found a solution? Taking a road trip with the F30 is not much fun when having to stop all the time to thaw out the evaporator.
06-15-2014, 10:04 PM | #2 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Check the refrigerant pressure it might be low on gas.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
06-16-2014, 07:44 PM | #5 |
Rep 54
Thanks for the help guys. I know my cabin filter is clean, so next step will be to bring it in and check the system charge. I did drive 4 hours today in 98 degree heat with no issues. Today I left the fan speed up and turned the temp warmer. It seems to only ice over with low fan speeds.
06-17-2014, 01:40 PM | #6 |
Rep 444
I strongly suggest you take it to your dealership. I do a bit of work with building A/Cs and icing over is usually a sign of a fault (or a sign that the system isn't powerful enough, but I think we can discount that).
Worse, if an A/C ices up that in itself can cause or exacerbate faults/coolant leaks. And if there isn't enough coolant in the system, the compressor will be working overtime and could burn out. You don't want that to happen out of warranty! |
07-16-2014, 11:56 AM | #7 |
Rep 5,089
Anyone knows if F3* still requires complete dashboard removal to replace AC evaporator and/or blower? This is one of the craziest repair on E39, E46(and many other cars as well) for $3k+(a 2-day job!!!), just curious if BMW engineers finally address this.
07-16-2014, 08:45 PM | #8 |
Rep 54
I checked the gas, and pressures. Everything was fine. I found that by leaving the fan speed low AND the temp low (75 or lower) the evaporator will freeze up in about 5 hours with outside temps over 90F. I don't normally take trips that long though. I think what is happening is with the low air flow, the icing isn't getting knocked off the evaporator. Now I just run the fan speeds higher and no more problems. Still, I would rather have a lower volume of colder air versus a higher volume of slightly warmer air, but that is just my preference.
07-17-2014, 12:24 AM | #9 | |
Rep 17
I actually ran into the same exact problem! During the 4th of July weekend, I drove from NYC to DC and about 2 hours in, my a/c stopped working. I had it on the same setting as well (low temp and low fan speed). The blower still made a loud noise when I turn up the fan but no cold air came out until I turned off the a/c for a while.
I took it to a dealership in VA over the weekend since I didn't want to drive back up with no a/c (I had no idea that it was due to a frozen evaporator at the time). The rep and the BMW technician told me they charged the battery but could not find out what is wrong either and that if it happens again, BMW will replace the blowing motor for me. Anyways, supposedly there is a BMW service bulletin for that frozen evaporator. I PM'ed someone to see if they can get it for me. If I get it, I'll send a copy to you too. Quote:
07-17-2014, 11:25 AM | #10 | |
Rep 5,089
07-22-2015, 01:04 PM | #12 |
Rep 1,668
Ha AC wanna be for sure. Typically this is due to low freon.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
07-23-2015, 02:54 AM | #13 |
Rep 1,348
If you're going to be running it for hours, setting the fan to high will help prevent it from freezing up.
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
07-23-2015, 06:25 AM | #14 |
Rep 1,267
07-23-2015, 03:35 PM | #15 | |
Rep 1,369
Good luck. |
09-07-2015, 12:46 PM | #16 | |
Rep 390
Thanks.
Best,
Charlie 2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp |
09-07-2015, 03:05 PM | #17 | |
Rep 16,083
I once worked at a motel that had inadequately sized window AC units. On an average day no problems, but when above 90 with high humidity they would build up literally a full inch of ice on the coils. The users in these cases always had the temp control set all the way down, which made the situation worse, as the compressor never shut down. The temporary fix was to simply turn the temperature up. The compressor would turn off, and the ice would melt. Since they did not have the ability to recirculate the air in the room there was no permanent cure except to replace them with higher capacity units that didn't have the compressors running at a 100% duty cycle to cool the room. |
09-07-2015, 03:23 PM | #18 |
Rep 10,509
What is your temp set at? This happened to me during my SC to Socal road trip in high humidity when I had the system on auto, fan speed 1 and 67F.
The next day, when things had a chance to (I assume) thaw out and the AC was working normally, I had good luck with the system on manual, fan speed 3 and 71F I read elsewhere that setting the temp too low can cause some condensation in high humidity, and raising the temp a bit can help out Thanks also everyone for the TSB number. The issue has not happened again since I made it back to Socal, even in 110F heat in the desert, but it is good to have the knowledge of the TSB around for the future |
09-07-2015, 05:24 PM | #19 |
Rep 16,083
09-08-2015, 11:19 AM | #20 | |
Rep 69
We had a loaner so something tells me they took their time.. |
08-01-2020, 08:34 AM | #21 |
Rep 27
Drives: 2016 BMW M328I & 2013 BMW 328i
NO NO NO you dont need a new evaporater...common problem google BMW SI B64 06 13
repair bulliten and the shop does a firmware update. YOUR EVAP WILL STOP FREEZING UP |
08-01-2020, 09:45 AM | #22 |
Rep 143
Had the SIB done yesterday under CPO.
Had frozen up 2 hrs into a road trip. AC was on Auto @ 70 degrees, low speed w/outside temps 85-92 and humid (spotty showers). '16 F31 328ix 42K miles Next road trip in 2 weeks. Will report back in.
Jvac432.00 |
