BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > PSdZData Full vs. Lite
      09-16-2018, 08:13 AM   #617
shawnsheridan
shawnsheridan's Avatar
Originally Posted by dashti640 View Post
Hi,
no, its just normal Bi-Xenon i had on my car F06 2014 and already installed the LED Headlight done all the wiring and but won't accept the 5A2 code. i can change it to 552 and also change it back to 522.
My guess is only LED Option on F06 is Adaptive LED, and that non-Adaptive LED in invalid, as in never available as a factory option.
      09-16-2018, 09:11 AM   #618
pcp1234
Drives: G03
is it normal that engine management light comes on after odd flash ? reading ista d, it obviously ses faults from flashing stage but actual car is ok
also i was under impression that EPS hasn't been updated because of below message but now its no longer on list of items to update
https://ibb.co/h3WRme
      09-16-2018, 02:22 PM   #619
dashti640
Drives: F06
Hi,
yes there is LED headlights from 2015 LCIs are LEDs now and the one i got is none Adaptive thought because i didn't had Adaptive Xenon I should go for none adaptive LEDs.
      09-16-2018, 02:29 PM   #620
shawnsheridan
Hi,
And in 2015 car with non-Adaptive LED Lights from factory, what is Option Code? Does FA have 5A2? Did you change FA Build Date (Zeitkriterium) for LCI Date?
      09-16-2018, 02:38 PM   #621
dashti640
Drives: F06
Hi,
that is the next step is to get a copy of the FA build data for a none Adaptive LED and try that but i don't know how to get FA data for a F06, F12 or F13
do you think that would work or do i need to change the ZGW to 8SK module? thanks
      09-16-2018, 02:40 PM   #622
shawnsheridan
Hi,
If 552 works, and 5A2 does not, I am not sure why ZGW would matter.
      09-16-2018, 02:46 PM   #623
dashti640
Drives: F06
yes, 552 works fine i get all the error message about the Adaptive is not working but won't accept 5A2. to change FA build to a newer model would work? or what other problem i should be looking out for if changed FA build
. thanks
      09-16-2018, 02:56 PM   #624
shawnsheridan
. thanks
I have no idea what the issue is. If 5A2 is valid factory option and you use correct FA Zeitkriterium, it should not be an error.
      09-16-2018, 03:03 PM   #625
dashti640
Drives: F06
any idea where i can get a FA build data for a 2016 6 series? thanks
      09-16-2018, 03:17 PM   #626
shawnsheridan
Not one with 5A2 in it. I have a 2016 GC F06, but I have 552 ADAPTIVE LED HEADLIGHT in mine.
      09-16-2018, 04:17 PM   #627
dashti640
Drives: F06
nice one, one more question if i get a VIN number for a car with 5A2 is it going to be any use for my case to get FA data build or just have to be the file itself-copied from the car ? thanks
      09-16-2018, 04:20 PM   #628
shawnsheridan
If you have car with factory 5A2, you should be able to load same FA, and VO Code FRM and Light Light Modules without error.
      09-16-2018, 05:24 PM   #629
dashti640
Drives: F06
ok, ill give it a try and see thanks for your help.
      09-21-2018, 12:18 AM   #630
Gixfighter
Drives: E91 2006 335i, M-sport
Hi,
Can I get the link to full PSdZData please?
thanks!
      09-21-2018, 07:04 AM   #631
shawnsheridan
Originally Posted by Gixfighter View Post
Hi,
thanks!
PM sent.
      09-22-2018, 05:41 AM   #632
cormellema
Drives: F30 340i
Hi Shawn,
May I have the link for the latest PSdZData please?
Thank you in advance
      09-22-2018, 05:46 AM   #633
atzebmw
Drives: Tesla Model 3
Originally Posted by cormellema View Post
Hi Shawn,
https://www.bimmerfest.com/forums/sh...d.php?t=983244
      09-22-2018, 07:46 AM   #634
shawnsheridan
Hi Shawn,
PM sent.
      09-23-2018, 09:47 AM   #635
pcp1234
Drives: G03
updated another car yesterday, below time stats; was F010-13-07-506 to F010-18-07-530
1. ZGW = 3m 7sec
2. EGS = 2m 28sec
3. DSC = 4m 28sec
4. PDC + JBBD = 1m 42sec
5. EKPM = 1m 31sec
6. FZD = 2m 22sec
7. FRM = 4m 43sec
8. TBX + ZBE = 3m 10sec
9. TRSVC = 4m 37sec
10. SZL + EMF = 1m 54sec
11. EPS = 1min 32sec
12. HKMF = 1min 37sec
13. TCB = 12min 53sec
14. SM = 3m 6sec
15. DME + KM = 6min 45sec
overall 55mins and 55sec
atzebmw588.00
      09-24-2018, 08:57 AM   #636
///Magic Bus
///Magic Bus's Avatar
38
Drives: M3C G80 XDrive
Hi Shawn,
Delivery of my new M2C coming soon.
May I have the link for the latest PSdZData and Esys please ?
Many thanks in advance
      09-24-2018, 09:34 AM   #637
shawnsheridan
Originally Posted by ///Magic Bus View Post
Hi Shawn,
PM sent.
      10-10-2018, 04:33 PM   #638
pcp1234
Drives: G03
i keep getting this error on EPS, any reason or guidance please?
[EPS - 30] - [Exception - EPS - 30] SVK-Ist does not match expected SGBMIDs for ecu ECUId:EPS_0x30. Excpected (relevant process classes only): [hwel_00000e1c-001_004_005, hwap_00000e21-255_255_255, hwap_000002be-255_255_255], Actual (relevant process classes only): [hwel_00000e1c-001_004_000, hwap_00000e21-255_255_255, hwap_000002be-255_255_255], Missing SGBMID(s): [hwel_00000e1c-001_004_005], Surplus SGBMID(s): [hwel_00000e1c-001_004_000]
