BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6WB coding tread
      12-24-2018, 10:43 AM   #111
sherif atta
sherif atta's Avatar
Drives: f30 340i
Hello all.. Need some help please, i installed a used 6wb cluster and its not identified via any software, the MOST is connected.
Any recommendations?
      12-24-2018, 11:24 AM   #112
atzebmw
Drives: Tesla Model 3
I'm not sure if a used 6WB will work.
But you mean you can't see it in E-Sys?
Then change the VO to 6WB an first code the HU with it.
Then the 6WB (DKombi) should be visible.
      12-24-2018, 11:40 AM   #113
sherif atta
Drives: f30 340i
Yes i cant see it using Esys, i changed the VO adding 6WB but didn't do the HU coding.. Could you tell me what to do to code it?
      12-24-2018, 11:43 AM   #114
atzebmw
Only hit the button "Code" (right beside FDL code).
      12-25-2018, 05:31 AM   #115
sherif atta
Drives: f30 340i
It didnt work after coding also.. Any other thoughts?
      12-25-2018, 06:05 AM   #116
atzebmw
Did you try both possibilities? "Read SVT (VCM)" and "Read Ecu"?
Do you still see the old 6WA cluster in the SVT list?
      12-25-2018, 10:11 AM   #117
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Try changing the built year to 11/16.
      01-18-2019, 08:33 AM   #118
sgimips
Drives: '18 540d
I’ve been running with my 6WB retrofit for a few months now and all is well, mostly. I have the navigation info clipping in the center with certain directions (round abouts or complicated intersections mostly) and an error code for “MOST node: the default registry is outdated” which doesn’t seem to affect anything but would be nice to fix if anyone knows how to update that.
Also is it possible to code the fuel range graph so it shows static numbers (like 0 and 200 in the middle) rather than showing the range following the end of the bar graph?
      01-18-2019, 02:03 PM   #119
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
You already have the fuel gauge in the circle to the left.
The scale right of it is range. Or am I misunderstanding your thought?
      01-18-2019, 06:50 PM   #120
sgimips
Drives: '18 540d
Correct. The scale on the speedometer side shows the range as a graph with the miles as a number which follows the end of the graph. I wondered if it could be changes so that the numbers are shown in a fixed location on the graph, sort of like how the mpg graph is displayed on the right side of the cluster.
      01-18-2019, 07:22 PM   #121
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
Still don't understand why you would want that, but either way it is not possible through coding.
      01-22-2019, 05:13 PM   #122
ZECAR33
Drives: BMW 318d F31 2014
FDL Code theese:
CIC => KOMBI_CIC = kombi_high
DKOMBI => NAVI_NBT_ENABLE = kein_nbt
hello, I made kombi retrofit for 6WB I added 6WB to FA and coded HU_nbt evo and kombi everything works fine but oil temperature and diesel do not work well. when I turn off the ignition the diesel does not come to zero is a 1/3 and the temperature seems to be the opposite wronf side pointer. will it be some coding or do I have to also add the FEM ICM etc …
i filling full up the pointer marks out the scale, analyzing well the pointer always points to 1/3 higher what should mark with the car off should point to zero points to wrong to 1/3 above when full fil points 1/3 off range
The oil temperatura pointer are on wrong direction (like a mirror)
see pictures
https://f30.bimmerpost.com/forums/sh....php?t=1553764
      01-22-2019, 05:14 PM   #123
ZECAR33
Originally Posted by chp10 View Post
Hi,
because some of us installed already the 6WB Kombi i would like to start this tread. Here you can share your experience and findings with us.
Some of you asked me for the compass function. This can be found in section
3003 FZG Ausstattung -> Kompass Graph Enable -> set to aktiv.
I found also Motorleistung Enable which should show the engine power used (only workingin sportmodus). Unfortunately it is not working in my car. Maybe someone can try it and confirm. As it seems it is working at least for the F10 series cars.
In my 2013 F31 is still the HUD not working, i guess a coding mistake (resolution, wrapping...?), so if someone can help me would be nice.
see pictures
      01-23-2019, 01:20 PM   #124
AndreiRRR
Romania
Drives: BMW F36
I have a problem with the street name not being displayed correctly on my retrofitted 6WB with NBT (see picture).
Tried the solution quoted below and it doesn’t work:
As far as i remember you have to change HU_NBT coding. There is a something like Guiding_Kombi_HUD and you have to change it to Rueko mit HUD
Someone can help?
      01-23-2019, 05:19 PM   #125
hanselfransel
Someone can help?
Try this
KOMBI_Aufloesung - Aufloesung_1
HUD_Komprimierung_Art - RLE 1
      01-23-2019, 10:06 PM   #126
jdgay22
Drives: 428i f33 m sport convertible
does anyone know the code to make the 6wb stay in sports display mode. while even in comfort or eco.... I really just wanted it for the big digital read out.. dont want to always drive in sport.. mines is a retro fit
      01-24-2019, 01:38 AM   #127
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
No such code as far as I am aware.
      01-24-2019, 02:39 AM   #128
AndreiRRR
Romania
Drives: BMW F36
Originally Posted by hanselfransel View Post
Try this
Forgot to mention that I don’t have HUD. Do I have to use the same codes?
      01-24-2019, 04:59 AM   #129
KimHaugli
Drives: Bmw F10
Originally Posted by KDKE30 View Post
Hey, do you find a way to increase the splash screen time?
Have been searching everywhere for the same. I think the duration of the startup logo is fixed and cannot be changed.
It sucks, if I want to see the M550D logo i need to rush into the car before it dissapears..
      01-24-2019, 03:22 PM   #130
hanselfransel
Yes, i don t have hud too, and worked for me
      01-26-2019, 05:34 PM   #131
AndreiRRR
Romania
Drives: BMW F36
Try this
It works!!!
Thank you!
      01-27-2019, 12:34 PM   #132
hanselfransel
It works!!!
Thank you!
No prob
