10-25-2016, 05:28 PM | #1 |
Rep 210
Brake Bleeding Procedure on ISTA/D
I read so much about how so many people have a mushy pedal when they DIY, I DIY'd the brake bleed on my 340i but after that my pedal felt mushy. So i bled it a week or so later with ISTA/D by activating the DSC pump. Needless to say my pedal was much firmer after activating the DSC pump motor to get some air out of the brakes.
Steps that i did were: Vehicle Information -Control unit list --Dynamic Stability Control (DSC) ---Call up ECU functions. Afterwards: You will get this screen, just click "Pump motor on" and "Trigger Component". You will now here the DSC pump cycle and you have sucessfully activated the "bleed mode" I did this one time on each wheel starting from the wheel furthest from the master cylinder so LR RR RL LR (L=Left, R=Right). Hope this helps somebody
Car List: 2000 328i E46 Steel Gray Metallic 5SPD MT- Sold 2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current |
10-26-2016, 11:21 AM | #2 | |
Rep 272
10-26-2016, 06:26 PM | #3 | ||
Rep 210
10-26-2016, 07:41 PM | #4 |
Rep 3,947
10-26-2016, 07:44 PM | #5 |
Rep 265
04-17-2018, 02:17 PM | #6 |
Rep 39
successfully active the pump 5 second with your instruction, but is weird no brake oil are coming out ... unless i step the brake then the oil is out ...
04-17-2018, 02:44 PM | #7 |
Rep 210
This is the bleed the abs as well not to force brake fluid out. I use this in conjunction with a motive power bleeder
04-20-2018, 10:34 PM | #9 |
Rep 210
Brakes feel spongy without computer. It will work but the pedal feel is different. I've tried this multiple times
04-21-2018, 08:08 AM | #10 |
Rep 16,083
It would be helpful if you specified how you bled the brakes that left them spongy. I've never heard of there being a problem when it's done with the two man method or with pressure bleeding.
04-24-2018, 08:48 AM | #11 | |
Rep 39
sorry to ask again, what you means is when bleeding with motive power bleeder, then active the abs right ? |
04-24-2018, 08:49 AM | #12 |
Rep 39
im the one who use the basic 2 man bleeding way but still spongy on 1st brake pedal press, 2nd pedal become normal ....
04-24-2018, 09:29 AM | #13 |
Rep 16,083
It's not unusual for one press to leave air in the line. The two man method is to have the first man open the bleeder screw, the second man then presses the pedal to the floor and holds it there. The first man closes the screw, the second man pumps the brakes a few times to be sure it feels firm. If it doesn't feel firm repeat the process until it does. One man can do it this way if he has a brake pedal hold down tool.
04-30-2018, 08:24 AM | #14 |
Rep 15
Also remember to periodically check and fill up the brake fluid level in the reservoir. Don't want to risk pumping air by accident into the brake line.
pumping the brake: soft -> firm == good pumping the brake: firm -> soft == very bad! |
05-18-2018, 05:50 PM | #15 |
Rep 16
Just to be annoying, that is not how you bleed the brakes, this is how you do it http://www.m5board.com/vbulletin/e60...ml#post5838729
Under that option is the special mode if you are having trouble purging the system like I had to do today. |
05-18-2018, 09:52 PM | #16 |
Rep 16,083
Using a pressure bleeder is an option, but manual bleeding has worked well for some ninety years.
The main advantage to a pressure bleeder is it's an easy one man operation. It doesn't work any better than manual bleeding. |
05-19-2018, 04:49 AM | #17 |
Rep 797
I have the pressure tank .. and ista. Do I need to use the computer or not? I can't find anything .. apart from conflicting information .. on if it is truly needed or at all beneficial. What does that pump actually do that the tank can't??
05-19-2018, 05:05 AM | #18 | |
Rep 204
Using ista is the proper way to do it as without it it can lead to a spongy pedal feel |
05-19-2018, 08:32 AM | #19 | |
Rep 16
I retired my gunson eezibleed and upgraded to a Sealey VS820, it was worth every penny. Also if you have a TPS factors near you the dot4 ESP low viscosity is just over £4 a litre, bargain. |
06-25-2020, 02:04 PM | #20 | |
Rep 525
i have the same Sealey bleeder kit, and did it last year with no issue before a track day - but i never involved ISTA.... i'm now stepping into this ISTA world so i can do the flush involving it as it sounds like that is the best possible way to do it. so... - connect the bleeder pump up, pressurize, etc.... - still go in sequence, RR,RL,FR,FL, as before, but now - get on ISTA and start program to bleed? - what happens exactly does it just make some noises and how do you know when its finished? would i still have to watch the tube carefully as the old fluid flushes through into my catcher bottle and close the nipple when i see the new stuff come through with no air etc.... like before? |
