07-05-2021, 08:47 PM | #23 |
Rep 35
Reviving this thread. Happens to me anytime I drive longer than 45 minutes. I've had the sensor relocation, the reprogramming, and the resistor installed per the SIB but it still happens. Fan settings don't matter, auto / manual, whatever. Nothing changes it. Two dealers have looked at it. Freon charge is fine.
I'm at my wits end; I can't take the car anywhere long term because of it when temperatures are 85+ and high humidity throughout the midwest right now. Anyone found a different fix other than selling the car? |
07-06-2021, 11:56 AM | #24 | |
Rep 562
Drives: 2017 BMW 330i xDrive
One quick thing to check, make sure the coolant level is good in your smaller overflow tank under the hood. This one is tied to, among other things, your AC compressor. When too low, the car has to limit how long the compressor stays on to prevent overheating the system. Up until it reaches concerning temperatures, however, it will work fine. My car has a very slow leak in that system for some reason, I have to periodically add coolant to keep the AC (and everything else) running right. Also notable is that your car is running the newer R1234yf refrigerant. Not that this affects much, the principles are basically the same, just noteworthy for future readers. Unfortunately, this system is not yet easily serviceable at home.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
Jvac432.00 |
07-06-2021, 12:00 PM | #25 |
Rep 295
Drives: 2016 340i X Drive
Since mine was reprogrammed the freeze ups have not reoccurred. I’d take it back to the dealer.
07-06-2021, 02:40 PM | #26 | |
Rep 35
It's been to my local dealer three times and another dealer once. I'm not sure another trip is going to do much for me. I've been talking to my local dealer to see what my options are, but so far, they have nothing to offer me. |
07-06-2021, 02:47 PM | #27 | |
Rep 562
07-06-2021, 07:29 PM | #28 | |
Rep 4,877
07-06-2021, 07:59 PM | #29 | |
Rep 35
Need to check the coolant level tomorrow to see if that has anything to do with my symptoms. Local dealer is checking into any other options, but given this is a common issue with no "silver bullet", I suspect I'm out of options. |
07-06-2021, 08:05 PM | #30 | |
Rep 4,877
You'd think the dealer would have caught that, unless it wasn't failing when they tested it. |
07-06-2021, 08:23 PM | #31 |
Rep 562
For the benefit of future and current readers, low coolant in the smaller tank has a few different errors that can be tripped as a result, one of which being compressor shutoff protect due to over pressure detected, or something along those lines. There’s few other protective shutoff codes that will come up if allowed to get worse. Oddly, not a one of them will result in a visible warning to the driver.
07-06-2021, 09:40 PM | #32 | ||
Rep 35
07-07-2021, 02:30 PM | #34 |
Rep 216
there are only two things that cause a freeze up in all the years Ive worked on air conditioning. A dirty filter not allowing enough air or a bad low temperature sensor causing it to freeze up. It's also possible that it got moved into the wrong location, but a pressure sensor wont cause this problem. A bad charge wont cause that either
sspade2464.50 |
07-07-2021, 05:54 PM | #35 |
Rep 295
I’d ask the dealer for a loaner until they fix your car.
AndrewC198910931.00 |
07-11-2021, 11:26 PM | #36 |
Rep 1,387
I'd check that the path between the HVAC intake and the filter isn't blocked by tree debris or the like. IIRC the intake is covered by some of the trim at the base of the windshield and the slot is pretty small.
07-13-2021, 07:53 PM | #37 |
Rep 35
As an update to my situation, the dealer is replacing both the compressor and the dryer (their words) as directed by BMW Corporate. I won't have the car back for a while, but will update once it's ready. Hoping it's good after this.
07-21-2021, 05:16 AM | #38 |
Rep 10
Common BMW issue, Had that on my 3 previous BMWs f20, f32 nd now my F31.
There is enough r134a, no leaks ... I just added the evaporator temperature sensor Adapter today, costs £1 and 20 minutes DIY job as per: https://static.nhtsa.gov/odi/tsbs/20...47927-9999.pdf Will have a long drive over the weekend and see. My next step would be the software update. Will keep you updated. |
07-24-2021, 03:38 PM | #39 | |
Rep 3
Any update?
Any update on how your drive went? I drive last night from Colorado to Ohio (arrived this morning) and at some point in Illinois it appears my system froze up too.. the wife was driving at that point while I was taking a power nap, so I’m not sure what the A/C setting was at.. I suspect she had it at low temp low fan speed.. I will be in Ohio for this week and would like to have AC on the drive back.. it was a pain to turn off the A/C in 90degree weather for it to Thaw for around 30 mins to get a good 5 minute worth of AC so any thoughts are appreciated.. Also my f30 is still under warranty so I will be reaching out to BMW when I get back home as I need the car while on my trip and cannot leave it at a service center while in Ohio
BMW..it's a lifestyle
07-24-2021, 05:16 PM | #40 | |
Rep 4,877
And yes, had the same deal as you. Turn off the AC, bake while waiting for it to thaw. |
07-24-2021, 06:01 PM | #41 |
Rep 282
BMW seems to have the worst ac system I've encountered. Mines randomly does the same thing sometime. Sometimes it takes a little while for the ac compressor to kick on as well.
07-24-2021, 06:21 PM | #42 |
Rep 37
i remember reading another thread that some one posted and said to run the fans higher and keep the temp to 72 degrees F been doing this all summer so far and no issues
07-24-2021, 09:34 PM | #43 |
Rep 3
Living in Colorado, where it’s not humid at all I get away with blowing at low temp low speed.. but at the same time It’s not like I drive for hours non stop in my city like I did over the course of the road trip.. I’m going to get the car into the shop since it’s under warranty just to have them check it out, but driving back I’m going to have the fan either low temp and full blast or above the 70degree mark.. at least until I get back into CO
