BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3 for BMW F series Vehicles - General Discussion
      07-09-2020, 01:08 PM   #991
phorge
phorge's Avatar
31
Drives: 2017 BMW 330i M Sport
Originally Posted by RadBavarian View Post
Nice man, that could be the problem with mine. I am missing a ton of other stuff that could cause the GTS Roar not to work out.
The GTS Startup Roar option should work on a stock car.
      07-09-2020, 03:11 PM   #992
mechamanz
mechamanz's Avatar
19
Drives: F30 320i LCI
What are your settings set to for the GTS Roar? Could you take a screenshot? Also, It may be my cutback system. I did remove the muffler and resonator.
The setting is set to 'ON' for the GTS start up roar. It only burbles on start up after I have driven it around for a bit and the engine is slightly heated up. On cold starts it doesn't sound any different from when it was off
The only mod on my car is that I have installed a Cat back 340i exhaust system (with golf tee mod)
      07-09-2020, 09:56 PM   #993
Luverse
Luverse's Avatar
Indonesia
142
Drives: BMW F30
GTS roar only work when your engine is warm. It will not work when your engine is cold.
GTS roar is not effected by the mods you had, as long as you enables it and the engine is warm, it should work.
The problem is, choking up which many people also had it.
Instagram: nightfall.f30
      07-10-2020, 10:30 AM   #994
snipagang
Drives: 2017 320i xdrive
anybody selling a used bootmod license? Dont feel like paying the full price
      07-10-2020, 11:30 AM   #995
Luverse
Luverse's Avatar
Indonesia
142
Drives: BMW F30
check classified. but beware of scam. Many people got scammed with used BM3 license. always use good and things type of payment if using paypal.
      07-12-2020, 05:04 AM   #996
Vesther
Vesther's Avatar
Drives: 2016 340i xDrive
Does anyone happen to know if i can run the N20 E30 tune on 102 RON pump gas and Stage 2 hardware? I don't have access to high ethanol fuel but wonder if the high octane pump gas we have in Germany would work instead. Unless there are different considerations tuning for Ethanol mixes instead of "Race" fuel?
      07-15-2020, 09:56 AM   #997
drdino
drdino's Avatar
Drives: BMW 330i
2018 BMW 330i  [0.00]
Looks like bm3 is "more" detectable, for the time being at least.
https://f80.bimmerpost.com/forums/sh....php?t=1739110
Luverse141.50
      07-15-2020, 10:16 AM   #998
Luverse
Luverse's Avatar
Indonesia
142
Drives: BMW F30
nice info
thanks God my BMW dealer is fine with tuning and other performance mods.
Still under warranty until 2022, and last month just claim the ABS module for free with BM3 stage 1 still installed.
      07-16-2020, 06:29 PM   #999
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Crap. I wonder if this is going to affect n20/n26 timing chain claims IF the class action lawsuit does go thru.
F30 328i xDrive | Cold Weather | Nav Pro | Tech Pkg | Injen Intake | CW DP | VRSF IC | MR Dual Exhaust | BM3 | BC coilovers & Swift springs | Integral Audio | Retrofit: 522 & 524 EDM | 5AC | 508 | 3AG | 5DL | 6WB | 8TH | FCW/LDW/SLI | Carplay
      07-16-2020, 08:35 PM   #1000
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Your waiting on the class action lawsuit(CAL)... it won't affect anything. A CAL is a group lawsuit... you might get something (probably less than $500) or not. The law firm will make the money. BMW will not check every car.
Remember Hyundai CAL for mpg. Friend got $200 dollars out of it....
Ford transmission CAL... have a maximum of $2300 per car because it depends on how many times you went to visit ford to complain or Ford service the transmission .. up to 8 visit.
      07-17-2020, 02:46 AM   #1001
Luverse
Luverse's Avatar
Indonesia
142
Drives: BMW F30
for those who is experiencing engine start chokes when cold, this is what PTF suggest me to do.
I don't know the result yet, since tomorrow i will clean my BMS open filter. Hope this fix the choking issue.
Name:  WhatsApp Image 2020-07-17 at 2.45.02 PM.jpeg
      07-18-2020, 02:07 PM   #1002
zerodb
Drives: 2008 335i + 2013 X5M
Has the BM3 transmission tuning come far enough that its not worth doing the xHP flash? Ive had my F31 for over 24 hours now so its about time to change something, right?
I was thinking Id leave power stock and just do the xHP tune at first but at over $300 for the license and maps Id rather not do it if its redundant and Id get just as much benefit from the transmission map on the BM3 setup.
If that was the case Id obviously rather just go for the BM3 and get everything in one place.
      07-18-2020, 04:17 PM   #1003
Gen13 F36
Gen13 F36's Avatar
Bm3 transflash is still the same as before... I don't think there an update at all.
So if you have driven car with bm3 transflash, that all there is to it. XHP flash is still very different feel. So still a tossed up if it is worth the upgrade from bm3 transflash.
      07-18-2020, 05:06 PM   #1004
zerodb
Haven't driven either!
But I'm coming off a 6MT and never loved the soft takeoff from a standstill and shift logic of our autos very much and it seems from what I've read that the XHP flash makes huge improvements to the feel of these cars. If BM3 offered similar improvement then I'd hate to do both but it seems like their trans tune is more of a bonus feature than a key feature at this point
      07-18-2020, 05:54 PM   #1005
Gen13 F36
Gen13 F36's Avatar
Correct ... bm3 transflash is a bonus indeed. I don't know about you but I should just as wait for funds and get bm3 stage 1 or 2 whichever you prefer and decide then if the transmission flash is good enough for you.
The biggest advantage of x-hp flash is that you can change shift point on sport mode (auto mode) which is really great when using everyday on city traffic. The rpm don't stay on the higher rpm and will save you gas. I mean it can shift up and cruise.
zerodb8.00
      07-21-2020, 12:02 AM   #1006
Luverse
Luverse's Avatar
Indonesia
142
Drives: BMW F30
if you feel enough with BM3 transmission tune, spend your money somewhere else. It is a good transmission tune come from its bigger brother. But that's it.
if you want to feel a game changer, go with XHP.
      07-21-2020, 05:11 AM   #1007
pierreye
Drives: F10 & G01
I have done both tune. Would go for BM3 first as the power gain is addictive. XHP would further improve the driving experience in term of faster gear changing and removing the torque limit. I also set the RPM limit to 6k for comfort and 6.5k for sports. No point going higher as the torque start to drop after 5k.
      07-21-2020, 12:27 PM   #1008
zerodb
Thanks, good to hear!
      07-22-2020, 05:17 AM   #1009
Milkman670
Drives: 2018 330i F31 MSport II
Has the BM3 transmission tuning come far enough that it’s not worth doing the xHP flash? I’ve had my F31 for over 24 hours now so it’s about time to change something, right?
I was thinking I’d leave power stock and just do the xHP tune at first but at over $300 for the license and maps I’d rather not do it if it’s redundant and I’d get just as much benefit from the transmission map on the BM3 setup.
If that was the case I’d obviously rather just go for the BM3 and get everything in one place.
TCU flash is not supported on F31 in bm3, at least not with b46 engine. Had to go with xHP.
zerodb8.00
      07-23-2020, 02:44 PM   #1010
drdino
drdino's Avatar
Drives: BMW 330i
Thread deleted?
Anyway, a G30 had something similar pop up:
https://www.reddit.com/r/BmwTech/com...now_autoflags/
So it looks like the car is flagged anytime it's plugged in.
      07-23-2020, 07:37 PM   #1011
Luverse
Luverse's Avatar
Indonesia
142
Drives: BMW F30
Having trouble with my GTS Roar Flash on my N20.
It tends to choke up on startup then settles. I might take it out if it continues, anyone have any experience with this?
after conversion with PTF, it seems that the engine chokes is caused by aftermarket intake. i will try to put back the stock intake, and see if this still happens.
also, all BM3 OTS tune is designed for stock intake, at least that what PTF said.
      07-23-2020, 07:52 PM   #1012
chowser51
chowser51's Avatar
Drives: 18 F33 430ix B46 BM3s1-93
Which intake do you have?
I have bms billet with occ and start up roar worked fine.
I have since turned it and burbles off. Stage 1.
bm3, bootmod3
