11-05-2019, 09:49 AM | #1 |
Rep 170
New Ebay Steering Wheel with Paddle Shifters
Guys,
Just wanted to share this... I picked up a custom steering wheel off Ebay, made to order so I got to customize the colors/materials. Shipped from Poland. All-in took about 2 weeks to receive. Seller - AACars. I was able to reuse the stock airbag and coded in the paddle shifters in less than 5 minutes with Bimmercode. For under $500, I'm pretty pumped The ergonomics of the wheel itself aren't great, but I think it looks cool and I'm getting used to it pretty quick. Would def recommend for the price. Last edited by Diirek; 11-05-2019 at 10:20 AM.. |
11-05-2019, 10:06 AM | #2 |
Rep 109
Image not showing up. Is your car non M Sport? If the stock wheel didnt have paddle shifters, your car must've been pre-wired for paddles. I've been interested in a new wheel and paddle shifter retrofit but havent gotten around to checking to see if my car is pre-wired for the paddles.
11-05-2019, 10:23 AM | #3 | |
Rep 170
Yes - I have the non-sportline/non m-sport model. I know there was a good chance the car may not have been pre-wired but I took a gamble and it payed off. I did lose my heated steering wheel but with the added padding and alcantara, it doesn't seem as cold to the touch. |
11-05-2019, 10:46 AM | #4 | |
Rep 109
05-13-2020, 10:28 AM | #6 |
Rep 170
05-13-2020, 06:01 PM | #8 |
Rep 170
05-14-2020, 10:36 AM | #9 | |
Rep 78
btw, on the vindecoder site it show that i have S255 Sports Leather Steering Wheel. can you check if that's what you also have? thanks. |
05-15-2020, 08:24 AM | #10 | |
Rep 170
There is a module within the steering wheel, which I thought was only for the heat element. If you have this, you need to swap it over as well because without it you will get an annoying cruise control malfunction in iDrive intermittently. Cruise control still works without it, just annoying. |
05-15-2020, 10:57 AM | #11 | |
Rep 78
I also have the heated wheel, so I'll definitely keep in mind about that module. Thanks for checking out bro. |
07-07-2020, 11:51 AM | #12 | |
Rep 57
Cruise control malfunction after steering wheel upgrade
Do you know which module from the original wheel needs to be swapped over? I still have it and the airbag. |
