BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Disable BMW Voice Recognition
      01-26-2021, 05:15 PM   #1
coniman
coniman's Avatar
Spain
Drives: G20 320d M Sport
22 BMW 320d G20  [9.83]
Hi guys. I'm trying to disable BMW Voice Command to enable Siri on my aftermarket CarPlay when pressing the button on the steering wheel. At this moment when you push it it activates both things. I'm using Esys and an OBD to RJ45. I'm changing 6NK to 6NH but when I VO code HU_ENTRY I get an error related to CAFD but the unit reboots and the button gets disabled. The problem is it also disables Phone and I have strange options in settings like Sprit of Ecstasy and Bang and Olufsen settings lol.
I need help to code it properly.
Thanks!
EDIT: working deleting 6NK in SALAPA but Phone still not appearing on iDrive
      01-28-2021, 02:21 PM   #2
Spyder3
Drives: 2018 540i xDrive M Sport
I'm watching this thread. Have the same situation (aftermarket CarPlay). I tried searching a while back, but never found a solution.
      11-07-2021, 01:44 PM   #3
micma_27
Drives: BMW 320I 2013
how to enable ?
      04-28-2023, 01:00 PM   #4
TheNine90
Drives: bmw
I think you should manually edit the cafd. Compare the two cafd and change what is necessary.
      12-08-2024, 02:13 PM   #5
sao
Drives: F30 328
Hi there did someone manage to disable VOICE button from steering wheel?
I already try to put inactive
SVS, SVS_VOICE, SVS_PAL, SYSTEM_TTS, CE_DEVICE_SPEECH_RECOGNITION
and button still work...
