11-29-2021, 06:02 PM | #111 |
@_sunbish
282
Rep 611
You still had a major HPFP pressure drop.
I'm starting to think the e70 or fueling issue that some people were having wasn't because of the lpfp, but instead because of the vacuum lift pump. Then again, I believe jq555 runs a spool fx180, not sure if he had any issues tuning that but he runs full E85. Dorch stage 1 & 2 pumps are direct fit, so this has me thinking why wouldn't it be able to be installed with any other HPFP, or even the stock one? Maybe the spring on the stock HPFP is too soft (and not knowing any spring specs to any of the aftermarket pumps)? I'm wondering if it would cause issues similar to valve float in OHV engines when the camshaft is too aggressive for the valve spring.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
11-29-2021, 07:07 PM | #112 | |
Rep 643
https://www.bimmerpost.com/forums/sh...php?p=24680607
M235i rwd 6mt
11-29-2021, 07:57 PM | #113 | |
Rep 7,606
And yeah, i have also heard of a few people supposedly running full E85 tunes with FX180s, but who knows what E% that "full E85" is and theres little to no datalogs on it, especially with corresponding E% |
11-30-2021, 06:33 PM | #114 | ||
Rep 643
M235i rwd 6mt
11-30-2021, 06:46 PM | #115 | |
Rep 7,606
12-04-2021, 11:03 AM | #116 |
Rep 3,695
Hey guys.
So, after all the logs, have you been able to determine that the Stg 2+ Multimap will scale properly bn the Stg 2+ Exx map and the Stg 2 93 map simply based on your ethanol content when using an ethanol sensor? |
12-04-2021, 01:44 PM | #117 | |
Rep 7,606
He hasnt logged in a while because the test 2 map was terrible and it caused a really bad HPFP crash and the car wouldn't start afterwards for a while. |
ZM22810.50 |
12-04-2021, 03:17 PM | #118 | ||
Rep 5,392
However the MultiMap Stage2 is designed to toggle with the steering wheel buttons between base maps of 91ACN, 91 and 93. So that should scale back from E85 all the way to 91ACN. Right now that's the FlexFuel map that I am running with E24 in the tank. After I had trouble with the Test2 map, once I got it started then I filled up right away with 93 octane. Temperatures were dropping into the 30's overnight. I was afraid that I'd have trouble starting it in the cold with E78. Based on cold starting issues with E78 when air temperatures are in the low 40's, I won't run more than E50 this winter. I could go down to E30 or even just 93. We'll see. The consensus is that my new month old Precision Raceworks LPFP with Walbro 535 may be slightly out of spec so they are shipping another under warranty. Hopefully that will fix the issue so that I can run the remaining logs with E85. |
ZM22810.50 |
12-04-2021, 05:47 PM | #119 |
Rep 3,695
Got it.
So, install an ethanol sensor, run the stage 2+ Multimap, let it auto adjust based on Emix, and use fast map switching when running 93. I guess that’s not too bad of a way to do it. |
12-04-2021, 08:33 PM | #120 | |
Rep 5,392
Gotta run MultiMap Stage2 which can go all the way up to E85, but at the bottom end you can switch between three base tunes: 91ACN, 91 or 93 octane. |
12-04-2021, 08:40 PM | #121 |
Rep 3,695
Apologies if I’m rehashing already presented info, or maybe it’s different for the M2? From the below pic, it looks like I can do what I mentioned?
12-04-2021, 09:14 PM | #122 |
1296
Rep 3,533
not the same for the 335 etc
ZM22810.50 |
12-05-2021, 08:35 AM | #124 | |
Rep 5,392
Apparently BootMod3 for some reason has different switchable tunes grouped together for your M2 and for my F30 N55 EWG. I actually prefer yours. To run with less than E30 in the tank I have to flash to the MultiMap Stage2 which has base tunes for as low as 91ACN, 91 and 93. Ideally I would like to have a MultiMap Stage2+ tune with: 1: 91ACN 2: 91 3: 93 4: E30 This would provide me with the flexibility to never have to reflash the entire tune between MM Stage2 and MM Stage2+. I have an E85 station down the street. But if they are temporarily out or their E85 pump is broken (which has happened) then I have to fill with 93 octane. Or if I'm traveling in the surrounding states, they might not have E85 or quality 93, so I might need to switch down to a 91 or even a 91ACN tune. BootMod3 does say that a custom tuner can change the tunes in the switchable maps. I just wish that this setup above came from them off the shelf. FYI- I've noticed, what has been reported elsewhere, that running E85 as the temperature drops into the 40's Fahrenheit, the car has some difficulty starting. So for winter I intend to run lower concentrations of ethanol. I'll drop it down to E50 and if that still labors when starting I will drop to E30. The 93 Octane in my state is all E10, but I could run E15 if I want to give it an octane boost and guard against a weak batch of 93, which has happened. UPDATE: 12/5/21 FYI- I just opened a case with Bootmod3 requesting that they add a 93 Octane option to the F30 N55 EWG MMSt2+ tune. This would result in the following switchable map options: 1: 93 Octane 2: E30 3: Racegas Hopefully they will do so, to make it easy to put 93 Octane in the tank without reflashing down to MMSt2. |
ZM22810.50 |
12-05-2021, 11:04 AM | #125 | ||
1296
Rep 3,533
12-05-2021, 12:17 PM | #126 | |||
Rep 5,392
Or were you asking to create a standard Stage2+ tune but using 93 Octane instead of E30? I can understand why that isn't feasible. To do that would mean trying to squeeze more power out of 93 Octane out of an already optimized OTS tune. The only hardware difference between Stage2 and Stage2+ hardware is that Stage2+ has an upgraded HPFP. That isn't something that adds more upside to 93 octane fuel the way that being able to run a higher ethanol mix does. I'm not asking BM3 to squeeze more power out of 93 octane fuel. I'm just asking to add the switchable map choice for 93 Octane into the MMapStage2+ that is already in the MMStage 2. Bootmod3 already does this for the M2 MMStage2+ so presumably it it wouldn't be rocket science to accomplish it. |
12-05-2021, 01:41 PM | #127 |
Rep 7,606
So yeah it does look like you have a 93 option under the MM 2+ tune. I didnt understand the part about running full E85 and stock HPFP at the end though... i assume that's not supposed to be there on the 2+ map page.
12-05-2021, 02:16 PM | #128 |
Rep 769
https://drive.google.com/file/d/1ioS...ew?usp=sharing
Refer to page 14 for diagrams on how our HPFP works, including the regulator, and how exactly the HPFP Angle pid is calculated. Angle is how much of the lobe is being used. If a cylinder wants low pressure, the DME can fire an injector before the HPFP is at full compression. |
12-05-2021, 02:36 PM | #129 | |
Rep 5,392
12-05-2021, 05:04 PM | #130 |
Rep 7,606
I know that, i am talking about the part i circled in red. Seems like that belongs on a stage 2 map not a 2+
12-05-2021, 09:01 PM | #131 | |
Rep 5,392
Bootmod3 Typo
So the header at the top is definitely correct and so is the Stage2+ reference a little further down. But below that it should say Stage2+, not just Stage2. The entire page discusses the Stage2+ map, but that typo gives the impression that the bottom of the page is about Stage2. Please see photo for illustration. |
12-05-2021, 09:39 PM | #132 | |
1296
Rep 3,533
ZM22810.50 |
