10-12-2017, 08:13 AM | #1 |
Rep 846
428i, ESS tuned with upgraded hardware (with Dyno chart)
Hey guys,
Last year I updated my ECU with ESS software. Their Dyno was broken so no Dyno chart that time around. During the last three months I installed some new hardware: Charge pipe Intercooler TIC pipe Cold Air Intake Catless Downpipe Yesterday, I went back to upgrade my software: below is the result. Originally the car was rated at 270hp with way less tq (sorry about not getting a baseline). Please consider that the tq number in the chart is in NM which translated to 326lb ft. Gas was 98 octane, which is very common here in Sweden. I am extremely happy with the end result together with the supporting mods. The power is consistant, the car feels proper fast! Next up is ESS turbo upgrade next spring. I want to take this N20 to a whole nother level! Last edited by Manboy; 10-27-2017 at 02:34 PM.. |
10-12-2017, 11:03 AM | #3 |
#gotboost
517
Rep 861
Nice gains, thanks for the dyno! Do you manually shift? Looks like 5500 would be a good spot
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
10-12-2017, 11:59 AM | #4 | |
Rep 21
Drives: BMW F30 328XI
BMW 2013 F30 328XI N26
10-12-2017, 12:04 PM | #5 |
Rep 846
10-12-2017, 05:03 PM | #6 |
Rep 657
10-13-2017, 06:33 AM | #7 |
Rep 846
10-13-2017, 10:29 AM | #8 |
Rep 657
Ohhhhh shiiittt ESS tuning get ready man its between you guys and pure turbos now idk which one to get lol .-. Anyways man congrats on the results pretty damn good ones at that our little 4 bangers can do some work lol
04-17-2018, 08:53 AM | #9 |
Rep 2,382
Congrats man... When I first read it, I was like "Damn, those are good numbers for only those mods" and then I read 98OCT! I'm really jealous lol. Good to hear though. If I could make a recommendation, think about upgrading your rod bolts to ones made by ARP. Another member pointed this out to me and it's pretty smart if you want to get to about 350whp safely and not rebuild the entire engine.
All in all, great #s!
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
04-17-2018, 12:24 PM | #10 |
Rep 307
Take into account, the correction factor on the dyno is DIN which isn’t the standard SAE correction factor we use here in the states. How that affects the numbers being, higher or lower? I don’t know, but it will change the numbers for sure. DIN is more popular in Europe.
BunkerJ1032.00 |
04-17-2018, 08:29 PM | #11 | |
Rep 65
just dropping the oil sump ?? |
marcozen10.50 |
04-17-2018, 08:55 PM | #12 |
Rep 2,382
Yup! From there it's easy. Might as well replace the bearing shells while you're in there as well. Stamp is on the crank as well.
04-17-2018, 09:02 PM | #13 | |
Rep 89
what was your boost like? peak and towards redline? What kind of dyno was it, like a rolling road or a hub dyno where your wheels come off for the run ?
N20, EWG, Full M package, 19" x 8.5/9.5, JB4, Catless DP, Custom 3" exhaust, Upgrade intercooler with metal piping, drop in K&N, Snow Performance Stage 2 kit
04-17-2018, 09:20 PM | #14 |
Rep 65
04-17-2018, 09:25 PM | #15 |
Rep 2,382
Oh, sorry. Stamp will tell you which shells you need, as there are different ones and depend on the crank.
08-12-2018, 11:20 AM | #17 |
Rep 56
08-13-2018, 09:14 AM | #18 |
Rep 2,382
These are the bearing shells that sit in the con rod end cap and end of the con rod.
08-14-2018, 11:41 AM | #20 | |
Rep 56
and; Have not found anything on bearing shells yet. Last edited by marcozen; 08-14-2018 at 11:48 AM.. |
