06-24-2021, 02:56 AM | #2 |
Rep 624
Looks like your car has tune. Did you know? Some states with emissions testing are looking for this. You need to be on stock software in order to pass. Specifically, there is a tamper code in the DME called the Cal ID that is compared to a checksum called the CVN. If the two don’t match you get flagged. I’m on a bootmod3 tune and to pass emissions I would have to flash back to stock and relock the DME.
06-24-2021, 06:17 AM | #3 | |
Rep 11
Unit R5 and R8 |
06-25-2021, 11:14 PM | #5 |
Rep 11
It's the system on the computer that connects the obd that gives that message and there is no code or any info to know what the issue is . I still haven't been able to figure out the way to fix this .
06-25-2021, 11:24 PM | #7 |
Rep 1,452
06-25-2021, 11:25 PM | #8 | |
Rep 11
06-26-2021, 06:50 AM | #9 |
¯\_(ツ)_/¯
945
Rep 1,762
How many miles did you drive on the car after the dealer did the work? If you drove it under 60 miles it's possible they computer does not have the readiness monitors for inspection. The dealer doing the work could have reset the ECU resulting in that.
