BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Transfer key electronics from F30 shell to X5 key shell?
European Auto Source (EAS)
      10-30-2019, 02:24 PM   #1
Cpatel
Drives: N26 328i
Can I open up my F30 key fob
Remove the electronics, and place them in an X5 key fob? It seems like the button locations are in the same position and the spacing is similar.
Do both of these remotes use the same batteries?
      11-18-2019, 11:12 AM   #2
ibazooka
Drives: '14 335Xi, '89 S50 E30
Subbed
      11-18-2019, 12:38 PM   #3
cjn
Drives: 2014 F30 330DX
Isn't there a bit of a problem with the physical key? How will you move the F30 key to the X5 fob? It's not an obvious fit and I assume you don't want to be without it when your battery dies.
Answering your detailed questions appears to be something you could easily do for yourself.
      11-18-2019, 12:52 PM   #4
UnknownBeing
Drives: 2016 340i
You could always get a locksmith to cut the new key for you, that would be pretty in-expensive.
I don't think this is possible, looking on eBay it seems the two have a slightly different PCB layout and shape.
      11-18-2019, 02:40 PM   #5
jkwhar
Drives: F30 328i Xdrive | F15 x35i
They are two completely different PCB and will not work.
https://f30.bimmerpost.com/forums/sh...331334&page=10
Did my post help? Click "Appreciate!"
F30 328i xDrive | 475 BSM | 2A5 18" | Cold Weather | Nav Pro | Tech Pkg | Injen Intake | CW DP | VRSF IC | MR Dual Exhaust | BM3 | BC coilovers | Swift springs | Integral Audio | Retrofit: 522 & 524 EDM | 5AC | VLD | 2TB SAT | 508 | 3AG | 5DL | 6WB | 8TH
