BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > What F3x components failed after the warranty expired: please post your updates here
      02-17-2020, 04:12 PM   #1
cfm56d7b
Dedicated thread with components failing after the warrant expiration will help the community to keep an eye on these components and visit the dealer before the expiration date.
My warranty is still active with 7 months remaining.
2017 440i GC with 27K miles.
      02-17-2020, 08:36 PM   #2
n00bkiller944
Drives: '14 328d M Sport
2014 328d w/ 75k
- Thrust Arm Bushings
- HPFP
      02-21-2020, 05:03 PM   #3
KeelTiii
Drives: i5 eDrive40
Drive belt tensioner at 38k miles
2017 F32 440i
VVlasy48.00
      02-22-2020, 04:51 AM   #4
cfm56d7b
Battery at 27K miles. Replaced under warranty.
      02-28-2020, 06:01 PM   #5
khj24
khj24's Avatar
221
Drives: 2015 m235i
F22 but my valve cover gasket failed at 30k miles 3 weeks after CPO warranty expired.
      03-03-2020, 11:10 AM   #6
TanzM4
TanzM4's Avatar
Drives: BMW M4
My battery was replaced at around 35k. I wasn't experiencing any issues but the dealer replaced it when I got an oil change.
      03-06-2020, 09:11 AM   #7
IraHayes
Drives: 328i
No failures, but my warranty expired in January. First week of February I get an intermittent suspension squeak. Figures.
F32Fleet3570.00
sspade2464.50
      03-06-2020, 09:19 PM   #8
cfm56d7b
2017 F32 440i
Thanks for sharing. What were the symptoms?
      03-06-2020, 11:50 PM   #9
KeelTiii
Drives: i5 eDrive40
2017 F32 440i
Rattling noise when accelerating
      03-11-2020, 12:20 AM   #10
BimmerMat135
Drives: E82M/S213 E450 A/T
328d: NOx sensor
      03-22-2020, 09:10 AM   #11
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
58k miles
Oil filter housing gasket (seeping but not leaking. I'm OC about this stuff)
Valve cover gasket. Started to seep @53k miles. Because plug swap requires removal of components which also get removed when the VCG is replaced I held off until now.
Valve cover and PCV vent tube replaced as well. Why? I'm keeping the car and don't want to crack open everything again if the PCV failed or the cover cracks.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      03-22-2020, 02:34 PM   #12
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
2014 328i w/ 92k miles.
- coolant thermostat (under warranty)
      04-01-2020, 01:54 AM   #13
jh_f30
jh_f30's Avatar
1306
Gaskets. All the gaskets. If they're not leaking now, they will. Not saying you should do this, but if you don't have a leak yet, you could try dribbling some used motor oil around the main suspect areas and try to get them to replace them for you.
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
Appreciate 6
      04-01-2020, 07:59 AM   #14
Polo08816
Drives: 2014 335i M Sport
This is the best advice ever lol.
jh_f301306.00
      04-06-2020, 12:56 PM   #15
SlickShift
SlickShift's Avatar
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
On my M235i, the valve cover gasket started seeping around 70K
On my current 435i, the charge pipe cracked at 40K.
As for under warranty repairs, the 2er had the charge pipe, oil filter gasket and drive belt tensioner all replaced under warranty.
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      04-26-2020, 11:00 AM   #16
tardboi
Drives: 335i xDrive MSport
What spots may that be? OFHG and VCG? Where does the oil typically go (google wasnt that helpful)?
      04-26-2020, 07:12 PM   #17
jh_f30
jh_f30's Avatar
1306
VCG usually leaks toward the exhaust side. There's a little lip there where it can accumulate and eventually drips down onto the exhaust manifold/downpipe area. OFHG leaks down the front on the engine, along where the serpentine belt is. Just don't drip any oil directly into the belt. It can cause it to slip off and get eaten by the engine.
      04-27-2020, 11:12 AM   #18
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
2015 435i 65k miles...
1. GPS went dead - antenna OK, head unit ok... mid-wiring from antenna connector to head unit connector was the culprit. Fix was run OEM EBAY GPS antenna mounted in dash. $15. (I'm not chasing a GPS cable through the body!)
2. ACC - automatic collision control malfunction... around town it's fine, highway it acts up. Just needs "realignment" because it gets bumped around A LOT. Dealer wants $600 to fix. (My fix, pull off bumper, nudge unit up/down as the bracket is aluminum.)
3. Low-Frequency horn died - replaced/fixed using Hella horn from Amazon, $38.
Eyeballing coolant breather line... although at 65k ... it's still solid.
(EDIT 24 hours later)
4. Coolant breather line, I had the part so decided to swap it now before it leaks. As soon as I went to un-install it, it snapped. Brittle as heck.
      04-27-2020, 03:30 PM   #19
Silverlining_m2
Silverlining_m2's Avatar
1732
Drives: 2023 M2, 2024 m235i
2013 328i sport line. Oil cooler gasket at 50400 ish. Discovered just after I bought the car and covered under my used car warranty. Outside of BMW's 50k warranty though. I added a 3rd party warranty after that for safe keeping.
2023 M2. ZB. Manual.
2024 m235i
      04-30-2020, 09:48 AM   #20
KeelTiii
Drives: i5 eDrive40
Transmission getting replaced at 49k miles. Whining issue.
      04-30-2020, 12:32 PM   #21
cfm56d7b
Thanks for sharing. My vehicle is 2017 440i GC with 28K miles. Can you provide a few more details? Did the whining sound came about suddenly or over time increasing in volume? Any stored fault codes?
      04-30-2020, 01:34 PM   #22
KeelTiii
Drives: i5 eDrive40
No faults stored. I bought the vehicle as CPO last year and I had been trying every dealership around. Engine gets up to operating temperature and it starts whining noticeable past 2k rpms and intensifies along with revving. Sometimes crowds out the turbo noise.
