02-28-2020, 08:45 AM | #1079 |
Rep 289
02-28-2020, 08:59 AM | #1080 | |
Rep 843
Or if you use the Carlinkit or Andream software update on the Bimmertech unit. Or if you use the Andream or Bimmertech software update on the Carlinkit unit. |
x-m4n148.00 |
02-28-2020, 09:54 AM | #1081 | ||||
Rep 1,217
02-28-2020, 10:06 AM | #1082 |
Rep 21
Is it just me or is there no volume bar that shows up on the carplay display? Also, for some reason without a backup camera installed, all of a sudden whenever I put my car in reverse it starts the camera screen(blacked out) trying to mimic a camera. I am guessing one of the dip switch just turned on by itself?
02-28-2020, 10:08 AM | #1083 |
Rep 42
I noticed that when I use the Bimmertech MCU with my Andream unit the auto day/night feature works. However, it takes much longer to connect to Carplay. With the Bimmertech MCU it usually takes several minutes to connect to my iPhone or I would have to manually reconnect, but with the original Andream MCU the connection was a few seconds, usually before the cold start idle settles. I went back to the Andream MCU for this reason.
02-28-2020, 10:45 AM | #1084 | ||
Rep 843
x-m4n148.00 |
02-28-2020, 11:05 AM | #1086 | |
Rep 256
the only connections issue come when my phone is on my house wifi and it takes an extra 30 seconds or so to connect to carplay. but that only really happens when i park in the garage (which i usually dont do) |
02-28-2020, 11:22 AM | #1088 |
Rep 21
I don't have a camera or the PDC in my F30. Why should either show up? The only dip switch I switched ON were 1,2 and 3.
02-28-2020, 11:28 AM | #1089 |
Rep 843
02-28-2020, 12:07 PM | #1090 |
Rep 256
isn't set to 3rd party camera as default on the box? so if nothing was changed the mmi thinks its looking to override the screen by default, so maybe set 7 to "on" to stop that from happening?
02-28-2020, 03:56 PM | #1092 |
Rep 247
I just bought one off aliexpress from a different company (Road Top); it looks the same (other than being a little cheaper) and they told me it's also on 2.0.2.7.
In all these descriptions, it mentions that these units do DVR? Anyone install a camera with this and use it as a dashcam? kind of interested to see if the dashcam function of it can replace a standard dashcam. |
02-28-2020, 10:36 PM | #1093 |
Rep 128
Drives: 2015 BMW x5
Hi everyone.
I got my andream box installed on my f15 x5 but I can't get passed the "no signal" screen. Downloaded the updates and tried to update but no luck. Yes tried so many times with holding the back button. Any thoughts? |
02-29-2020, 01:19 AM | #1094 |
Rep 37
Make sure all of the LVDS cables going into the Andream and out to your display are fully clicked in, and double-check the main harness pass-through to make sure they're fully seated.
02-29-2020, 02:00 AM | #1095 |
Rep 128
Drives: 2015 BMW x5
Ok thank you. I will check the cables tomorrow. I can toggle between the iDrive and the box, just no signal...
02-29-2020, 03:47 AM | #1096 |
Rep 289
02-29-2020, 01:12 PM | #1097 | |
Rep 17
Checking on the Iphone in CarPlay settings, I saw there was a parallel "ghost" connection next to GPlink. So, I removed the CarPlay "GPlink", have clean up the BT connection on the phone also then restarted it. Then same on the MMI, I deleted the BT ******ion and Carplay entries and rebooted the MMI. I have then added my Iphone and this now work pretty well. On cold boot this takes between 10 and 15 seconds to display CarPlay screen (Maybe a bit more than with previous releases, but this is ok) You may try this is not done yet |
02-29-2020, 01:24 PM | #1098 |
Rep 17
I am asking this question as I could not find a reference on it in the thread (unless I missed some comments, could be the case as already 50 pages):
Does somebody already had a try with the "Logo Image Update" ("no logo.bmp") and/or the "CarPlay Icon Image format" ("no cp_back.bmp") ? These are visible in the setup entry and detailed on IndiWork.co.kr Documentation / http://indiwork.co.kr/archive/manual...CB-NBT_ENG.pdf I guess this is the boot screen for the MMI as well as the Icon in CarPlay. |
02-29-2020, 01:36 PM | #1099 | |
Rep 1,217
02-29-2020, 01:50 PM | #1100 |
Rep 109
Got mine installed today. I have a 2016 340i with Harmon Kardon. There was just enough space under the HK headunit that I didn't have to drop the glovebox (thankfully), but jamming all the cabling back behind/under the headunit was pretty tight. Oh, and getting the Andream quadlock onto the back of the headunit was a b!tch.
Everything works (audio, OEM mic), the only problem I've observed with my first few tests is that it doesn't always connect (wireless Carplay). A couple times when I powered it up (after a completely cold start, battery disconnected), it simply wouldn't connect to my phone until I went through pairing again in iPhone settings by deleting the connection and starting over. Not a good sign. However a couple times since then it seemed to connect on its own relatively quickly (5-10 seconds from On). I'm not sure what the variable is yet. Hopefully that latter behavior sticks. Attached are pics of the firmware my unit came with and how I positioned it. You can see the WiFi antenna with the 3M backing still attached to the tape; I haven't permanently positioned it yet, it's just kind of tucked between the injection molded foam of the dash and the black plastic that the Andream unit is sitting on. Going to wait to make sure I don't have any signal problems before permanently affixing it somewhere. I don't have the USB jack accessible without pulling off that bottom trim piece, but I don't need it. Oh and in case it's not obvious how to toggle between the Andream unit and the BMW infotainment...long-press the Menu button! Took me a bit to figure that out Also, holding the Back button seems to reboot the Andream. |
x-m4n148.00 |
Tags |
andream, android, android auto, apple, carplay, mmi, retrofit |
