BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 2015 F32 428i seats heat up without heated seats option..?
      08-12-2019, 11:20 PM   #1
wespiard
Drives: 2015 BMW 428i
I purchased a 2015 428i a couple weekends ago and have been loving it. The one thing that I have noticed (starting a couple days after owning it) is that there is no heated seat option (no heated seat buttons fitted on the dash), however the seats actually get hot as if the seat-heating elements are on.
I have attached an image of the front panel to show the buttons aren't there. I believe the passenger seat also gets hot.
I haven't been able to perfectly correlate it, but it's more noticeable when I turn the AC colder. This may just be a coincidence as when I turn the AC colder the last thing I want is the seats to get hot... so it may annoy me more then.
What should I check?
      08-13-2019, 07:43 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Make sure you don't have the rear seat console vent temperature wheel turned to red.
      08-13-2019, 08:40 PM   #3
IK6SPEED
IK6SPEED's Avatar
Drives: BMW M3 / AH3
Something has done a job on your trim.
Suspect previous owner had a crappy phone mount in the vent and the phone banged on the radio/climate controls.
Stable: F80 / AH3
Past: F80 ZCP / F22 M235i / E89 35is
      08-14-2019, 04:26 AM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
Drives: F32 435ix MSport ->M6
2016 BMW 435ix  [0.00]
Decode your VIN to see if your car originally was equipped with heated seats
If not, then its a pigment of your imagination that they are heating up
If so, then previous owner swapped out the original HVAC controls for some reason & got the version without heated seats
Even then, since there are no switches present, I would not think that the seat heating elements would default to ON
If I remove/unplug my HVAC in F32 with heated seats, the car will still run and the seat heating does not come ON - this is essentially same as you possibly having incorrect HVAC...
F32 435ix//Mineral Gray Metallic//Black Dakota Leather//Alum Blade Trim//M Sport Pkg//Prem Pkg//Tech Pkg//Driver Assist Pkg//Lighting Pkg//Cold Weather Pkg//Dyn Handling Pkg//HK Sound+BavSound Stg2//763M Wheels//M4 Mirrors w/NWC CF Covers//MPerf Pedals-CF Rear Spoiler-LED Sills-CF Shift Knob/Surround/IND M4 Alcantara Armrest//MPE w/CF Tips+CGP VSC-1//Dinan CF Intake//PURE S2 Turbo//AA FMIC//ER CP+TIC//3.5bar TMAP/DV+//AA OBD Flash Tune Stg2
      08-15-2019, 08:48 PM   #5
wespiard
It was on red for heat. I changed it, and I'll try to see if it makes a difference!
Yeah, unfortunately.. I was thinking it may have been a girl with long fingernails or something since the most commonly used function buttons are messed up but your idea sounds pretty plausible.
Looked up the VIN, and no heated seat option as expected. I'm going to try Billfitz suggestion and see if it's that simple.
Thanks for the responses.
