BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 pre lci halogen to lci full led headlight retrofit
      12-28-2018, 12:08 PM   #23
Jhnblckwood
Drives: F30 2014 320i xdrive
Originally Posted by tonyhhandler View Post
Originally Posted by Jhnblckwood View Post
Read the first post n the post above. I did add 5A2 to Fa.
Thanks very much,
It works now,
the only problem is that after sometime, it stores a can timeout fault and the mirrors turn indicators turn off.
Code the rem too with vo and changed build date.
      12-28-2018, 12:09 PM   #24
Jhnblckwood
Thanks very much,
It works now,
5A2 is for non adaptive led btw
      12-28-2018, 04:04 PM   #25
tonyhhandler
Egypt
Drives: f30 328i
Thanks very much,
It works now,
Thanks very much,
It works now,
Sorry but what do you mean with changing build date, or how should I do it
      12-28-2018, 11:22 PM   #26
Jhnblckwood
Thanks very much,
It works now,
Thanks very much,
It works now,
U change build date in FA. U should see like "0314" if car was built March 2014 etc. so change it to 07/15 n code fem n rem with that build date and 5A2
      12-29-2018, 09:37 AM   #27
tonyhhandler
Egypt
Drives: f30 328i
Thanks very much,
everything works well now.
      12-29-2018, 09:48 AM   #28
Jhnblckwood
Thanks very much,
Nice.
      03-14-2019, 07:20 AM   #29
alexmars
Ukraine
Drives: BMW F30 BMW E87
Hello,
where did u put the new wires of the kcan in the fem ( i mean in which plug and in which pin ?)
and what is the code you did ?
Have you added the led headlight option to the vehicle order ? or changed the build date for the fem ?
Hello,
so where did you put new wires for K-CAN2 in FEM???
for left headlight:
Pin 9 from headlight to Pin 21--A173*2B
Pin 10 from headlight to Pin 20--A173*2B
For right headlight:
Pin 9 from headlight to Pin 50--A173*8B
Pin 10 from headlight to Pin 49--A173*8B
When i'm putting these wires,it didn't work,nothing at all.
Even worser,KOMBI,HU-ENTRY are not working.
How do You solved that??
F30 2013/07
Thanks.
      03-14-2019, 07:25 AM   #30
alexmars
Ukraine
Already have newest i-Level, edited zeitkriterium to 07/2015, added 552(adaptive),coded FEM,REM.ESYS not show any FLE's.
ISTA shows just one FLER block...
      03-14-2019, 06:55 PM   #31
Jhnblckwood
Originally Posted by alexmars View Post
Hello,
for left headlight:
F30 2013/07
Thanks.
I would get ur kombi n hu back up n working first. Check ur wiring. When I first installed I only had one fle showing up too n here it wasn’t getting power. But if ur not getting any lights working at all then u need to double check ur wiring n go over all diagrams n triple check it. Goodluck.
      03-15-2019, 12:21 AM   #32
alexmars
Ukraine
SOLVED.
Had bad contact on left headlight CAN-Low, everything working fine now,looks amazing,especially with LCI taillights)
Thank You
      07-30-2019, 07:22 AM   #33
Wetter
Drives: E91 335d Sparkling graphite
Bumper pre lci vs lci
Hi there..
Thinking about converting my car - does the lci lights fit in non lci bumper and hood ?
Thanks in advance
      07-31-2019, 10:21 AM   #34
maruti
Drives: f30
hello
thanks a lot for all information i try for lci light
thanks
      08-07-2019, 09:07 AM   #35
deneyer
Belgium
35
I have a problem with adaptieve led retrofit, i have an F34 with adaptive bi-xenon from 2014.
Did the wiring according to newtis info, changed date to 1116, deleted 522 and 524 and added 552 and then vo coded FEM, REM, FLE43 and FLE44.
Now the problem, low beam, high beam, direction indicators and vertical aim are working. What is not working is the DRL and adaptive function.
On my cluster i get drl defect and if i read out with ista it says open circuit, no error for AHL.
Annuone had this problem or know what the problem is and how to fix it?
      08-10-2019, 03:41 PM   #36
Jhnblckwood
Try coding ur icm too
      08-11-2019, 08:29 AM   #37
deneyer
Belgium
35
Coding ICM, but ICM has nothing to do with your lights. Its integrated chassis manegment; or am i wrong?
      08-14-2019, 01:39 AM   #38
Johny212
FEM module is responsible for leds
      08-16-2019, 04:50 PM   #39
Jhnblckwood
Icm controller your level sensors tho.
      08-18-2019, 07:22 AM   #40
deneyer
Belgium
35
Like i said vertical aim is working so there is no problem with icm
      03-20-2020, 02:51 PM   #41
ashikaitc
France
Drives: BMW F30 318i
have you got a pdf for the whole pre lci to lci led retrofit u did ?
      07-30-2020, 06:28 PM   #42
turbovf
Drives: bmw 320i
FEM help
Hi, I,m new to this forum. I'm attempting to retrofit led headlights as well. My 320i was manufactured on 10/2014. I'm not sure where to install the pins in my FEM. I tried to put them where the PDF stated, but it caused my trunk, interrior lights and AC to stop working. Any help would be greatly appreciated.
      08-08-2020, 05:03 PM   #43
turbovf
Drives: bmw 320i
what do you mean by "FA"?
      08-09-2020, 04:51 AM   #44
Jhnblckwood
Double check ur wiring.
