08-10-2019, 07:41 AM | #1 |
Rep 89
Idrive vehicle status screen
Hi
I have recently changed my wheels and tyres with tyre sensors . 1 sensor didn't work so i changed it and now all working fine but the Idrive vehicle status screen is now showing a picture of the car at the right hand side of the screen with the pressures and temp instead of the 3d/ghost type off picture it showed previous . Please could anyone advise me if it could be changed back . Thanks https://f30.bimmerpost.com/forums/at...1&d=1565440265 |
08-10-2019, 08:57 AM | #3 |
Rep 1,991
Drives: F30 335d
Mine shows the car in 3d with or without tyre temps coded.
If you click left on the controller what's the 4th icon down? (I'd check my car but I'm ill in bed) Edit: could it be the idrive version? Mines nbt |
08-10-2019, 09:21 AM | #4 |
Rep 89
Hi
Thanks for the replies. The temp was already active from being coded a while ago using carly app.never had a problem until one of the sensor stopped working but then replaced . But before changing the sensor i did try and clear any errors from the car using the app (not knowing the sensor was bad) put the new sensor in and all working fine apart from the change off screen. I re-coded without the temps but still the same picture ? The 4th icon is Service Requirements , I can't really remember but i think an icon is missing . My car is 2017 335d Xdrive . I believe it is the NBT ID5. Thanks |
08-12-2019, 03:22 AM | #5 |
Rep 1,704
I had the 3d picture on my 2015 320i but mine shows the same image as yours on my 2019 420i (without the temps). Is it possible to change it to the 3d image of the car or is that just how it is now?
08-14-2019, 02:39 AM | #6 |
Bird Flu and Cat Aids combined
857
Rep 1,122
When mine was coded (which reminds me I need to get it sorted again) it was a 3D car like it was pre coding, with temperatures. My guess is you've changed some option of some sort.
08-15-2019, 02:18 AM | #9 |
857
Rep 1,122
