06-13-2017, 12:06 PM | #1 |
Rep 87
Bc Racing Coilovers
Has anyone had issues with camber after any coilovers install? I was looking at the BC setup and wondering what's everyone's thoughts.
06-13-2017, 01:38 PM | #2 |
Rep 456
Anytime you raise or lower a vehicle, it's always recommended to have an alignment performed to correct any camber/toe issues. For a minimal drop, you might be able to get away with out one. However, what's cheaper in the long run: $100/alignment or a set of new tires due to mis-alignment?
With respect to the BC coils, I have heard good things about this manufacture as they not only make the setup for BMWs, but for many different vehicle brands. Personally, I would look into a set of coils which have a progressively rated spring, such as ones from Bilstein or H&R. Coils with progressive springs ride excellent when DD-ing, but stiffen up when you're driving spiritedly or at the track. Linear springs such as BC's have the same spring rate throughout the entire shock travel. This means they'll ride equally firm on the street, as they would on the track. It's just something for you to consider. |
06-14-2017, 10:39 AM | #3 | |
Rep 69
06-14-2017, 12:56 PM | #4 |
Rep 456
If I were DD-ing my F30 with occasional spirited drives, I would go with either the Bilstein B10/B12 Pro Kit or H&R sport coils. As nice as BC's are, I just find them to be too stiff for DD use.
06-14-2017, 07:22 PM | #5 |
Rep 69
06-16-2017, 01:23 PM | #7 |
Rep 87
06-16-2017, 06:16 PM | #8 |
Rep 418
I haven't seen anyone complain about BC coils in 370z forums and here
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
07-06-2017, 04:06 PM | #10 | |
Modder of everything I own
147
Rep 491
Thanks!
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
07-06-2017, 06:32 PM | #11 |
Rep 757
yes I did, currently having issues with rear coilovers ..making clucking noises on small bumps. Ive verified and everything is solid but still making those noises, all i did was raised them .75 inches thats all. Besides that is a good ride quality ...
zole2112146.50 |
07-06-2017, 08:18 PM | #12 |
Rep 456
Did you make sure to properly torque down the shock tophat nut? In many cases, people forget to torque these down. When your shock compresses/decompresses (IE, slowing going over a speed bump), it leaves "room" for the tophat to move around. This may be the case so double check.
the dope steez403.00 |
07-06-2017, 08:45 PM | #13 | |
Rep 757
07-06-2017, 09:03 PM | #14 |
Rep 456
07-06-2017, 09:04 PM | #15 |
Rep 757
07-10-2017, 06:43 PM | #19 |
Rep 1
Bc coilover
Just received my bc coilover br series with the extreme low package and upgraded swift springs hoping to put them in tomorrow if not definitely by the end of the week I'll give an update when complete
08-14-2017, 10:30 AM | #20 |
335i F30
68
Rep 252
I have BC Coils and im a fan. For the price you can't beat them. no complaints about the ride either.
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers Coral Red Interior | H/K Package Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP |
08-14-2017, 02:01 PM | #21 | |
Rep 1,290
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
08-15-2017, 08:34 AM | #22 |
Rep 123
Has anyone drove on bc coils and kw variant 2 Im wondering if I should go bc or kw. Not planning on tracking the car too heavily but I would definitely want a more stiff ride
