08-04-2018, 11:35 PM | #1 |
Rep 5,088
Total brand LL01 5W40 good for N20/N26?
A local indy uses Total LL01 5W40 in the shop for the F30 I4's, anyone has good experience with the Total brand?
08-05-2018, 02:44 AM | #3 |
Rep 5,088
08-05-2018, 08:48 AM | #4 |
Rep 5,457
Drives: F30
Looks like you should be fine with what your indy has in stock. I would not be concerned with the brand name whatsoever.
See attached for my owners manual recommendations. I have a 2014 328i with N26. |
08-05-2018, 10:53 AM | #5 | |
Rep 5,088
My impression is that going for heavy oil is recommended only past 100k miles, and/or oil leaks start to show up. My car is 60k and there is no oil leak yet. It will be a 6.5k oil change anyway. BTW, the dealer has oil change special for $95, the indy charges $120, my hope is the indy will inspect the car better than dealer. |
08-05-2018, 11:11 AM | #6 |
Rep 5,457
Drives: F30
For what its worth... I change my oil every 5k with 0w40 (Mobil1 euro formula). Currently have 57k miles on my N26.
08-05-2018, 11:26 AM | #7 |
Rep 5,088
There are still 12 Qs of M1 0w40 (the old pre-GTL one) in my garage, my thinking is to use those as top-off oil.
BTW, have your spark plugs be changed yet? Mine should be due this oil change. Indy said they usually recommend spark plugs + ignition coils, but in CA the ignition coils of N26 are covered by PZEV warranty though. Indy charges $400 plugs + coils, should that be done together? Dealers charge almost $400 for spark plugs only, but any new coil will be covered. |
08-05-2018, 11:52 AM | #8 | |
Rep 5,457
Drives: F30
Changed my plugs myself with NGK at 50k. Super easy all you need is a thin walled socket. $10 on eBay. |
bavarianride1506.50 |
08-05-2018, 11:53 AM | #9 |
Rep 5,457
Drives: F30
I think I spent $70 on the plugs. Make sure you order correct part number. Double check on NGK website.
08-05-2018, 01:12 PM | #10 | |
Rep 3,439
Here's what BMW manual actually said up to 2015 (this is from 2014 manual, but other model years just change wording a little, not the substance):
08-05-2018, 01:59 PM | #11 | |
Rep 5,088
BTW getbmpwarts N20 oil kit is 0w20 for $65, while N26 oil kit is 0w30 for $61. The dealer's special is not too bad given they also have 20-point inspection and such. |
08-05-2018, 04:11 PM | #12 |
Rep 5,457
Drives: F30
Cant go wrong using what your owners manual says, which is why I use:
Mobil1 0w40 |
08-05-2018, 04:25 PM | #13 |
Rep 5,088
08-05-2018, 05:06 PM | #14 | ||
Rep 3,622
BMW CCA Member #516012
08-05-2018, 05:11 PM | #15 | |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Personally if I was doing my own fill would go with Mobil 1 full syn Extended Performance. I use it on anything I have to do myself. Viscosity depends on what the engine specs say.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 08-05-2018 at 05:20 PM.. |
08-05-2018, 05:11 PM | #16 | |
Rep 5,088
Click service tab of dealer webpage, and look for "Value service", and look for 3-series, F30. These prices are mandated by BMWNA, so dealers cannot charge more than that. It is possible that dealer service can provide a $3k "recommended" repair bill after the oil change, but that can always be brought to indies for second opinion. |
08-05-2018, 05:13 PM | #17 | |
Rep 5,088
The new bottle has a "FS" label in the front, and the back label no longer lists LL01. |
08-05-2018, 05:15 PM | #18 | ||
Rep 3,622
I will likely do oil changes through an Indy performance shop after.
08-05-2018, 05:30 PM | #19 |
3127
Rep 5,264
Interesting. Shell is a world leader in GTL technology. Mobil 1 FS spec is a GTL based oil. They also formulate an ESP spec that is not. Two separate product lines.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
08-05-2018, 05:37 PM | #20 |
Rep 5,457
Drives: F30
LL01 is little more than a marketing ploy. Mobil1 has not changed their formula...
Running any engine oil for 10k miles is a bad idea if you plan to keep your vehicle for a long time. Thats why I change my oil every 5k with an OEM filter, plug and owners manual recommended oil. Cost is under $50 per change. |
08-05-2018, 05:38 PM | #21 | |
Rep 5,088
However Mobil 1 FS 0w40 data spec does not list LL01. So it looks like ESP is low SAPS(for US diesel), and FS is high SAPS(for US gasoline). |
08-05-2018, 06:06 PM | #22 |
Rep 5,088
Also, has anyone used oil additive, e.g. Liqui Moly? Warranty booklet does say no oil additive though, but one indy swear by the Liqui Moly stuff. BTW none of my cars have ever got oil additive.
