05-07-2020, 07:57 PM | #1 |
Beach Bum
95
Rep 210
Aftermarket tire pressure sensors for 2018 340i
Can anyone link me to a good set (4 pieces) of aftermarket tire pressure sensors that will work with my 2018 340i?
Will these work?: https://www.amazon.com/gp/product/B0...=AHW66927YBQN9
2018 340i - lease returned
2008 335i - sold 2006 SL55 - Sold 2004 SL600 - Sold 1999 540i - Sold |
05-07-2020, 08:04 PM | #2 |
Beach Bum
95
Rep 210
05-07-2020, 08:20 PM | #3 |
Rep 3,748
You need to check for part # first.
Go to realoem.com You can pay a little more buying from tirerack.com , plug in your car then call them to verify. The tpms tirerack sell works properly. Last edited by Gen13 F36; 05-07-2020 at 08:31 PM.. |
05-08-2020, 11:42 AM | #4 |
Rep 49
Drives: BMW G20 330e M Sport
I purchased mine from here:
https://www.aliexpress.com/item/4000...287e76bbW7cNON I just added on my summer set of wheels and all is working perfect and the price is on the half... My car is an F30 from 2014 but I don't think that it matters, just to be sure if you are on 433Mhz Last edited by Scrupix; 05-08-2020 at 11:59 AM.. |
05-08-2020, 12:28 PM | #5 | |
Rep 3,748
I think this is your pn# 36-10-6-881-890 is for your 2018 340i, maybe you can verify it with the dealer. Then go look for an aftermarket that list compatibility with the OEM. I like OEM, you can find them at Ebay unbranded straight from Germany. Exact BMW OEM without the BMW price tag. |
05-08-2020, 03:00 PM | #6 |
Rep 611
Based on recommendation, I bought the Autel MX-sensor 433 MHz for my aftermarket wheels. EAN code of the black version is 6937357202402. They need to be programmed for your car, possibly as any other. Not the cheapest option, but works exactly as the OEM ones (Continental//VDO).
I've been told the cheap sensors can work well, too. While you can find they are not as accurate, the difference is often also in the cheap/low capacity batteries being used. These sensors should use the 350 mAh made by reputable brand (Panasonic/Maxell/Sanyo/...). |
05-08-2020, 04:02 PM | #7 | |
Rep 3,748
OEM cost around $300 for a set of 4. |
05-13-2020, 06:24 AM | #8 |
Rep 384
hi, i'm going to order the aftermarket tpms
previously, i had a universal tpms i use on my golf gti which work with android head unit (download the apps from play store), and remove it before the car was sold question is, can i use those tpms on my bmw 330i? or do i have to order from the link you guys shared above because it has to be pre-programmed for bmw? TIA
Instagram: nightfall.f30
05-17-2020, 07:22 PM | #9 | |
Beach Bum
95
Rep 210
Any help you can provide would be great.
05-17-2020, 07:40 PM | #10 | ||
Rep 3,748
just go to tirerack... there tpms works ... just submit your car info... yr, model, etc... they recommend a tpms... call them to verify. I bought this one with this markings. https://www.ebay.com/itm/153738914066 Check image... verify with the seller if your ebay route.
JUST an F36....extra door, slower than you
AWE Quad Exhaust, Bootmod3 VMR v804 GM 19" Staggered Last edited by Gen13 F36; 05-17-2020 at 07:52 PM.. |
