06-13-2017, 08:41 AM | #1 |
Rep 1,381
Sanding existing pads before new rotors?
So I'm desperately in need of some new discs (front and the rears are on the way so I might as well do them all to the same brand - plus I want all round matching slotted & dimpled).
My question however is, the front pads were only changed back in February and have 9mm of thickness, the rears also have around 7mm (still stock oem). Is it possible for me to just sand the pads flat and stick them onto the new discs? To waste £80-90 on more pads that already have decent thickness seems a little ludicrous. I have read mixed reports about doing this online so I'm set on finding out whether I can do this before placing an order. The health of the current discs can be seen here, lipped, corroded and glazed http://video.citnow.com/vxW2dj22zyV
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
06-14-2017, 10:57 AM | #2 |
Rep 766
Unless the pads for some bizarre reason are wildly uneven just replace the rotors and dont worry about it.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
fortythirtyfive639.50 |
06-15-2017, 03:57 AM | #3 | |
Rep 4,516
If plenty of meat on them - you could get them skimmed. http://skimmydiscs.co.uk/
Current '22 X3M LCI.. |
06-15-2017, 05:01 AM | #4 | |
Rep 1,381
They're corroded on the edges and are pretty badly lipped. I was massively impressed with my brakes after I swapped out the front pads for Pagids back in April, but from around May'ish I developed an insane amount of brake wobble and vibration throughout the cabin at speeds of 60-70mph + My dealer ran it on a brake roller which they claimed indicated the front discs to be problem, with a small amount coming from the rears.
2015 435i - 401whp
06-15-2017, 05:07 AM | #5 | |
Rep 4,516
Did you bed-in the pagid pads post install ? Could be disc faces have un-even deposits from new pads that is causing the wobble - if discs aren't near min. thickness then perhaps "Italian tune-up" for your brakes may reduce/remove brake wobble
06-15-2017, 05:27 AM | #6 | |
Rep 1,381
Yeah might be worth a shot. I'm away all next weekend but hopefully the weekend after I might try and pop the front pads out and just do a quick inspection of the entire disc too. Annoyingly I just missed a huge sale at onlinecarparts.co.uk, they had dimpled and slotted Zimmermann coated discs going with something silly like 30% off.
2015 435i - 401whp
06-15-2017, 05:41 AM | #7 | |
Rep 4,516
• Light braking to warm the pads and discs. • 8-10 cycles of threshold braking*, 60-5mph in quick succession. *Threshold braking = getting to the point of ABS intervention, but not actually triggering ABS. • Brake pressure must be released as you approach stop - do not stop the car after each deceleration. • Repeated above threshold braking cycle with higher speed deceleration, say 80-10 on a private closed road...... • Drive for several miles afterwards to let the brakes cool. The above works well to get the disc and pad temperatures high enough to ship pad material evenly to the disc faces.
06-15-2017, 09:53 AM | #8 |
Rep 766
Not aggressive enough. You need to get the rotors and pads hot enough. Its more than likely as was mentioned above uneven pad deposits. Warping rotors is much rarer than people think especially on a performance oriented car its damn near impossible. Econo-shit-box ok maybe if the rotors are small and cheap.
06-19-2017, 04:20 AM | #9 | |
Rep 1,381
2015 435i - 401whp
06-19-2017, 05:09 AM | #10 |
Rep 4,516
NP - hopefully this helps improve your brakes.
06-19-2017, 08:45 AM | #11 |
Rep 10,352
Assuming that you didn't re-set the brake replacement interval when you changed out the pads I would replace rotors when CBS states and sand the pads.
When pads wear out you'll want to change rotors as well. Lesson learned here is to always change rotors and pads at same time. Doing so makes the ownership experience less annoying.
"Drive more, worry less. "
06-26-2017, 06:23 AM | #12 | |
Rep 1,381
It'll do for now though, it's nowhere near as bad as it was initially thanks!
2015 435i - 401whp
