05-17-2019, 10:27 AM | #1 |
F30 335i Msport
22
Rep 83
Rough/shaky start up
I have f30 335i 3015
Vrsf charge pipe Vrsf intercooler Vrsf downpipe Stage 2 bootmod3 Ngk spark plugs Liquid moly oil Recently I been having roughy and very shaky start ups in the morning car almost pretty much turn off then had to restarted it
@supremegee
05-17-2019, 11:06 AM | #2 |
Rep 758
I know with bm3.it allows you to take logs, but does it also allow real time monitoring? if not take a log during your rough idle and use that to diagnose it.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
05-17-2019, 11:11 AM | #3 |
F30 335i Msport
22
Rep 83
How can I log it
@supremegee
05-17-2019, 11:13 AM | #4 |
Rep 758
one of the guys with bm3 are going to have to answer that, or you can try youtube or if their is a manual/help section within the software. I myself use mhd to flash/log so not sure about bootmode.
05-17-2019, 11:14 AM | #5 | |
F30 335i Msport
22
Rep 83
@supremegee
05-17-2019, 11:20 AM | #6 | ||
Rep 758
05-17-2019, 11:23 AM | #7 |
Rep 46
My car does the same, similar setup with new OEM plugs, but it has only done this a few times and has otherwise had smooth starts.
curious what is the cause for this, as well as the slight knocking for only the first few minutes of idle (injectors?).
2012 f30 n55 6 M/T, RWD
VRSF Catless DP/CP, CSF FMIC, BM3 Stage 2, KW V3 |
05-17-2019, 11:24 AM | #8 | |||
F30 335i Msport
22
Rep 83
@supremegee
05-17-2019, 11:25 AM | #9 |
F30 335i Msport
22
Rep 83
Yea my car just started doing it only has done it twice so far I have cold star delete too because I have muffler delete and both resonators deleted
@supremegee
05-17-2019, 11:46 AM | #10 |
Rep 557
@Supremegee, rough start up like the RPM goes below 700 almost turning off then the car recovers within 10 seconds and then idles high for about 20 seconds then normalizes? I have the same setups but not vrsf brands. I figured it could be due to my plug being gapped at .022. What is yours set at?
05-17-2019, 11:59 AM | #11 | |
F30 335i Msport
22
Rep 83
@supremegee
05-17-2019, 12:01 PM | #12 | |
F30 335i Msport
22
Rep 83
@supremegee
05-18-2019, 11:34 PM | #13 |
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
new coils fixed this issue in my car.
05-19-2019, 01:30 AM | #14 |
Rep 474
Start up bm3 on your phone or laptop. Then before you start the engine Click on date logs and start the log. You should let it start with the data going. Then stop the data logging after the rough idle.
J. D. Cordier
FSociety3811.50 |
05-19-2019, 11:21 PM | #15 |
Rep 439
Drives: 2016 M235i Xdrive 8A
What are these coils you speak of sir? My car is still shaking like a freightliner in first gear every time I turn it on.
No matter time of day, temperatures, humidity, hot or cold start you name it. Thing just shakes and Shakes.
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
05-20-2019, 06:17 AM | #16 |
Rep 2,653
Check codes and start by cleaning your MAF sensor with some CRC MAF Sensor Cleaner.
05-20-2019, 09:07 PM | #17 |
Rep 323
i first tried to eliminate the problem buying new spark plugs. it was better but not gone. i have bm3 and sent in the logs. tuners said to replace your ignition coils. i also before getting ignition coils did as the above post stated. i removed my maf and gave it a bath, twice with maf cleaner. rough idle still pursued. i finally bought new bosch ignition coils and fixed the issue.
people on forums will say log before throwing money at things. i agree. so i went through the neccessary steps before dropping 200 on 6 ignition coils. but that was in fact why i was having a rough idle. ignition coils go above your sparkplug and send electricity to them to create ignition. after 74k miles and how hot our engines run one of or more than one of mine were faulty. they were also causing a hesitation in wot. which is now fixed too. i bought the bosch set for the n55 off www.bmwsparkplugs.com they have an article of what maintence you should do before tuning your car. one of those things is change ignition coils! hope this helps! |
05-20-2019, 10:09 PM | #18 | |
F30 335i Msport
22
Rep 83
@supremegee
05-20-2019, 10:10 PM | #19 | |
F30 335i Msport
22
Rep 83
@supremegee
05-20-2019, 10:12 PM | #20 | |
F30 335i Msport
22
Rep 83
@supremegee
05-20-2019, 10:14 PM | #21 | ||
Respect My Authoritah
368
Rep 873
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
05-20-2019, 10:17 PM | #22 | ||
Rep 474
J. D. Cordier
