BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Engine: please post your experience, including problems / resolutions
      05-07-2019, 11:09 AM   #375
TakoMako
Drives: M240i Xdrive
Originally Posted by bucky_u View Post
All this talk of motors that need replacing have me afraid of some undiagnosed damage after my turbo blew. I did limp it home for about 10 miles ...
Everything seems like it's running great. Should I go back and ask for borescope inspection to check for scored walls? The SA said my turbo "disintegrated," so I have no idea where all that extra metal went ...
No harm done by asking for it. BMW over here did it because some other tests failed.
      05-07-2019, 01:21 PM   #376
B58
B58's Avatar
65
Drives: 2018 BMW 340i, 2011 BMW 335d
I just changed my oil to liqui moly 5w40. I don't recommend anyone running 0w20 unless you drive like a grandpa lol. The best oil to probably use is the Shell Rotella T6 5w40 since diesel oil has a larger amount of zinc for better protection. We did find a small glaze of metal in the left over oil sitting on the oil filter housing cap, but it just appeared to be normal wear from the engine and nothing on or inside the oil filter itself. Next oil change I'm going to send the oil out for a analysis.
      05-07-2019, 05:14 PM   #377
youngdoc1
Drives: 2016 340i X-Drive
Returning 340i lease this week with 43 000 miles, not a single issue with the engine/transmission.
      05-07-2019, 05:33 PM   #378
NormanConquest
Drives: 340i
Any idea what you will replace it with?
      05-07-2019, 06:13 PM   #379
youngdoc1
X4 M40i. Looking forward to it!
      05-07-2019, 08:01 PM   #380
TakoMako
      05-08-2019, 07:50 AM   #381
B58-Rocks
Drives: BMW M140i
Thank you for your answers!
The MG FLASHER app is one of the best Apss I've seen so far. The support is simply unique. I do not know if the other manufacturers can be just like these people .... but it can not be any better.
if you have discovered a mistake or a wish, which is said to support, it will be perceived and implemented immediately!
Best Team!
      05-08-2019, 11:24 AM   #382
NormanConquest
Drives: 340i
Best Team!
Post on wrong thread?
      05-09-2019, 07:11 AM   #383
Wires
Drives: 2016 340i xDrive
Originally Posted by cfm56d7b View Post
How many forum members experienced cylinder wall scoring in B58 engines?
Mileage? Symptoms? BMW response?
EVERY Otto style engine has scoring over time. You cannot drag pistons up and down in the bore without that happening.
The real question is "how bad was your scoring, and how does it compare to other similar engines"?
I guarantee anyone that hasn't had issues does not get the cylinders scoped, and pictures taken so they just don't know.
      05-09-2019, 01:56 PM   #384
bucky_u
Drives: Z3 M Roadster, 340i xDrive 6MT
Well I suppose that if the valve cover was replaced, then I they would have seen other damage underneath without needing to borescope. Must have been clean enough.
2002 E39 M5: RIP -- 2000 M Roadster: Silver/Red, S52 -- 2016 340i xDrive 6MT: Gray/Red
      05-17-2019, 08:25 AM   #385
BMW in NE
Drives: 2018 BMW 340i xDrive
Originally Posted by cptcrunch View Post
No issues here on the B58 engine except the 'stumble' or rough idle after initial start once the RPMs go below 1000 and how the engine acts like its a cold startup everytime the car is started, regardless of how warm the engine is.
I had this same issue. Dealer found 47 misfire counts in cylinder 3 due to a faulty spark plug. Got the car back and it idles like it should.
      05-17-2019, 10:46 AM   #386
madmortar
Drives: 2013 BMW 328i M-Sport
Safe to say later years N55 might be more reliable vs. B58?
Or vice versa?
      05-17-2019, 01:36 PM   #387
NormanConquest
Drives: 340i
Or vice versa?
Currently the B58 has been more solid then the 2014 N55 that I had in comparison to miles.
      05-18-2019, 01:33 AM   #388
vinzcast21
vinzcast21's Avatar
101
Drives: F30 340i MY2017
mine is cyl 2 yay
Mod bug will bite you if you buy a BMW
      05-18-2019, 07:08 AM   #389
ntailor
Drives: F30 340
Did any codes show up? CEL?
      05-18-2019, 07:25 AM   #390
madmortar
Or vice versa?
interesting.
just a bit thrown off by the few examples of B58 misfires causing cylinder wall damage and a toast engine. Coming from a n20 with the timing chain issues, I just need a reliable engine if I make a jump!
      05-18-2019, 07:50 AM   #391
bimmer456
Drives: 340i
Or vice versa?
interesting.
Yes B58 has been pretty good after 53k miles. Know blown charge pipes reported on this forum like with the N55 and upgrading to steel aftermarket pipe required. No timing chain issues reported by users. Did have low coolant initially but pressure testing by BMW revealed no leaks. No factory recalls for me only small numbers of units had recalls. Seems as bulletproof as a Honda. I did have one situation where the idle got erratic for some unknown reason and resolved itself after turning it off and turning it back on. Dealer was not able to replicate. Seems Toyota is confident enough to use it and the Z4 platform in the Supra. Solid enough that you can tune it.
      05-19-2019, 06:36 AM   #392
ESvensson
Drives: M140i xdrive -17
M140 production date 11/16.
- At 8k miles ignition coil broke on 6th cylinder... bmw replaced it (and all sparkplugs) under warrenty.
- 600 miles later same thing... bmw then also replaced fuel injector and some gasket to the crank case ventilation. Warrenty.
- 20k miles... same thing again... dealer and technicans from germany does every test posibble... leakdown, compression, checking for oil in crankcase ventilation... cant find anything wrong except the pressure of the crankcase ventilation...
So they gave up and replaced the whole engine on goodwill.
The car ran a Jb+ set at 3 a’clock....
      05-19-2019, 06:47 AM   #393
fun240i
Drives: BMW 2017 M240i
Most fun I've ever had with clothes on
'17 240 17k miles....this may be a dealer issue....but noticed for first time coolant a bit low a month after a 5k 12 month service...low coolant warning...checked large reservoir stone cold engine...below min mark but coolant visible.....overflow tank correct level....taking back to dealer for a check.
this minor blip aside.....bmw got this motor exactly right....smooth as silk.
      05-19-2019, 11:31 AM   #394
Araemo
Drives: 2017 340iX 6MT
After doing multiple post-testing teardowns and requesting design/parts changes to address their reliability concerns discovered during those teardowns, yes.
So: First-gen B58? Probably pretty reliable for a BMW engine.
Post-Z4 B58 revisions: Probably very reliable. But until those changes make it out to every car that has a B58, don't think it has Toyota reliability.
VVlasy32.00
      05-20-2019, 11:33 AM   #395
VVlasy
Drives: 2016 440i xDrive GC with MPPSK
Source? Insider info?
      05-20-2019, 11:38 AM   #396
MassNerd
Drives: 2019 M240i Coupe RWD
Source was automotive journalists at the recent Supra press event in Texas asking about reliability and getting the answer about teardowns.
VVlasy32.00
b58
