05-26-2020, 09:03 AM | #573 |
Rep 2,368
Drives: E63 645Ci
05-26-2020, 10:01 AM | #574 | |
Rep 30
05-26-2020, 11:17 AM | #575 |
Rep 2
I would like to use Tasker to switch to the AUX.app but I can't find them in the Tasker app list, 'cause of a system app ?
I know, that it's sth like AV IN, but in which folder should I search for it. |
05-26-2020, 03:23 PM | #576 |
Rep 1,048
Here you find the updated Factory_config.xml files for Android 9 Update 3.9.8 and Android 10 Update 1.5.7
Changes since my last update File 1.4.1. Added GUI "Benz_NTG5" . and updated description: now available GUI`s are: Code:
<Item id="1" name = "BMW_EVO_ID5" /> <Item id="2" name = "BMW_EVO_ID6" /> <Item id="5" name = "BMW_EVO_ID7" /> <Item id="8" name = "Common_UI_GS" /> <!-- AVIN8 GUI --> <Item id="90" name = "Common_UI_GS_UG" /> <!-- ID7 Style--> <Item id="91" name = "Benz_MBUX" /> <Item id="97" name = "Benz_NTG5" /> <!-- requires Android 9 - 398 or Android 10 - 147) --> <Item id="92" name = "Benz_NTG6" /> <!-- AVIN8 Style --> <Item id="93" name = "Audi_MMI_4G" /> <Item id="95" name = "Benz_GS" /> <Item id="96" name = "BMW_EVO_ID6_GS" /> <!-- ID6 Style with 4 tiles-->
Password changed to "0" (zero) Download for BMW Users: factory_config_BMW_A9_398_A10_157.zipDownload for Mercedes Users: factory_config_Mercedes_A10_157.zipKri Last edited by Kri; 05-27-2020 at 12:12 AM.. |
05-27-2020, 01:16 PM | #577 |
Rep 5
Local media access
Hello everyone, first time poster on this subject. I want to start off by thanking everyone who helps out.
My unit is brand new and running 1.5.7 software and is installed in an E70. My main issue is my inability to get any media player outside of the built in version to see my media files. I have about 50 gigs worth of MP3 files and it simply chokes out the default player (WitsKswMedia). I have tried having the music in an SD card (which increases boot time) and moved them to the internal flash, but I still can't get any players to see them. Ideally I would like to get Amazon Music to see the offline files the same way my Samsung S10+ does. I would also like to get Alexa working as the voice assistant instead of Google, but the app crashes immediately after launching. Using OK Google causes both the HU and my phone to spring into action everytime I say the command. Thank you, Gary Last edited by fstick09; 05-28-2020 at 10:02 AM.. |
05-28-2020, 02:35 AM | #578 | |
Rep 80
https://f30.bimmerpost.com/forums/sh...4#post26014674 Anyone else experiencing this? |
05-28-2020, 04:26 AM | #579 | |
Rep 2,368
Drives: E63 645Ci
I think it very much depends how multiple Bluetooth connections feature was implemented by each manufacturer. Sadly this is the downside of Android devices - inconsistence between different brands. |
05-28-2020, 05:26 AM | #580 | |
Rep 30
05-28-2020, 05:58 AM | #581 |
Rep 2,368
Drives: E63 645Ci
05-28-2020, 12:50 PM | #582 | |
Rep 1,048
I checked the update in comparison to 1.5.7, this version 1.6.4 is from 25th May 2020.
The Update can be found here. Quote:
Update: Audio Drivers, as always changes/fixes unknown Update/bugfix: Update to Image Recovery procedure code Update/bugfix: Update to BT Thething code (KswBT), change unknown Update/bugfix: Update to Bugfix reporting (still not found where it will be activated) Kri Last edited by Kri; 06-03-2020 at 09:29 AM.. |
05-28-2020, 11:11 PM | #583 | |
Rep 122
05-29-2020, 04:32 AM | #584 | |
Rep 1,048
my bmw sellers share jumped from 1.3.0 to 1.6.4 so also had not the updates in between. The 3.9.8 Update is also not that old so there for sure will come some updates again. Kri |
05-29-2020, 08:20 PM | #585 | |
Rep 7
Since upgrading to this version, I can't control the android menus with the iDrive knob (touch screen control only ). Any thoughts on how to fix this? Edit: Using AVIN Android 10 Snapdradon 625 previously on v1.5.7 out of the box Last edited by qwertyman999; 05-29-2020 at 08:31 PM.. |
05-30-2020, 10:05 AM | #586 |
Rep 17
Hi
I bought a new device from Android 10 from AVI, I used Android 9 Snapdradon 625 before, now new unit new back camera application has been added but how can I go back to the old one very slowly new application |
05-30-2020, 12:20 PM | #587 | ||
Rep 1,048
Kri |
05-30-2020, 03:32 PM | #588 | |
Rep 117
Sometimes this helps in solving strange issues |
05-30-2020, 10:13 PM | #590 | |
Rep 7
Is it possible this was a non-BMW update? Is there any harm/is it possible to revert back to 1.5.7? Edit: I've just got back in my car and the iDrive system is working fine now for some reason. Thanks so much for your help! Last edited by qwertyman999; 05-30-2020 at 10:25 PM.. |
05-30-2020, 11:57 PM | #591 |
Rep 7
05-31-2020, 10:09 AM | #592 |
Rep 220
Drives: MINI Cooper, 2020 X1
Reverse camera display is not an Android application, it is part of the MCU. But you can try to downgrade ksw_mcu.bin to an older version !! But beware, only CORRECT ksw_mcu.bin for your unit !!
05-31-2020, 10:36 AM | #593 |
Rep 17
Thanks, where can i find that correct mcu version
05-31-2020, 11:53 AM | #594 |
Rep 220
