10-21-2020, 05:36 AM | #1695 | |
Rep 2,367
Drives: E63 645Ci
10-21-2020, 09:04 AM | #1696 |
Rep 41
10-21-2020, 09:25 AM | #1697 |
Rep 22
10-21-2020, 10:45 AM | #1698 | |
Rep 41
That's nice.. usually it has to do with newer options and some fixes and or more support for the canbus and other types of cars etc. I always welcome those newer mcu files and img's.. it means there is still some hope & support behind the sunset for these al cheapo chinese headunit's. Ps: today and for no reason whatsoever, the navi sound went off, after i got back home and restart the car after 30 minutes, it was (did) fine again.. there is and always was something weird with these things. Success |
10-21-2020, 11:48 AM | #1699 | |
Rep 190
With that the system will think that you still have reverse gear and will be on till the PDC shuts off. Maybe after that you must enable the aftermarket camera to function correctly. I had this configuration with my old 8.1 unit and was working flawlessly. I do not know if the system is different in Android 10 but give it a try, it needs some wiring but you can achieve what you want without software upgrade. |
RedErik1023.50 |
10-21-2020, 01:05 PM | #1700 | |
Rep 2,367
Drives: E63 645Ci
10-21-2020, 01:07 PM | #1701 | |
Rep 12
10-21-2020, 01:27 PM | #1702 |
Rep 43
10-21-2020, 02:45 PM | #1703 | |
Rep 41
Indeed.. you already have mentioned it in your previous post, the problem is the splitting and different in the voltage supply, usually in such case you hear some pop sound from the speakers coming, as our forum mates also they not recommended.. here's what you should to try: remove the car gps / splitter. connect it to the supplied gps and see if you get rid of the problem? simple to find out.. right? i'm almost sure you'll get rid of that pop sound. Success |
10-22-2020, 02:49 AM | #1704 | |
Rep 114
At the moment the only "manual" solution is to touch "PDC" button and then will work as espected, then this is why I think with MCU update the Chinnese enginer can fix the problem, I don't think that we need to wire to PDC button to fix it. Cheers. |
10-22-2020, 03:55 AM | #1705 | |
Rep 190
These guys hear our problems but the prefer solving issues with the next generation of the units. ex iDrive integration to work in all apps , in Android 8.1 this is not happening but they did it in android 9 , although they could do it with a software update. That for i think that this will be the solution ! |
10-22-2020, 04:38 AM | #1706 | |
Rep 2,367
Drives: E63 645Ci
10-22-2020, 11:26 PM | #1707 | |
Rep 19
10-23-2020, 06:47 AM | #1708 |
Rep 4
Video out
Has anyone tested video out RCA (CVBS)? Trying to add a screen to rear seats but can't get any signal. Unit is old split box version.
10-23-2020, 06:45 PM | #1709 |
Rep 592
I'm currently using the 720p PX6 unit from CarNavi via Aliexpress. What advantages you get from moving up to Snapdragon and which supplier would you guys recommend. Im in the U.S.
10-24-2020, 02:15 PM | #1711 |
Rep 12
Hi all,
Today I upgraded from android 9 to 10 as discribed first to 1.2.0. after first boot, wat went fine I updated to 2.3.0 and now it stucks (bootloop?) on logo connectdrive. I won't boot into Android. The oem bmw is working fine. Anyone had this issue as well and solved this? The tip on the first page in this topic to change the ota file name doesn't work... After 10 minutes still de logo and no reboot. Hope someone can help me . Last edited by Aram2020; 10-24-2020 at 03:46 PM.. |
10-24-2020, 05:28 PM | #1712 |
Rep 36
Also looking to see which exact screen and buyer people have bought off on Aliexpress, I don't want to buy an older and possibly slower model so a link would be appreciated.
With this screen installed can BMW still update my service history once it's serviced or should I be holding off until my service pack ends? |
10-24-2020, 07:11 PM | #1713 |
Rep 28
I just tried to update from 2.09 to 2.3 which failed.
It sayes: joes F! Finding Update package Opening Updt...... E: map(0, R, Private, 4 , 0) failed; invalid argument E:map of '/dev/ota.mt/....imagename.zip' failed E: failed to map file install aborted Any ideas? The Files mapps perfect to my unit. |
10-25-2020, 03:42 AM | #1714 | |
Rep 41
is het al uw gelukt ermee? zo neen.. probeer het volgende maar ff: try this: go to recovery mode of it, from there do the wipe things and restart it and wait until it's done with his things, be patient. Succes/s |
10-25-2020, 03:47 AM | #1715 | |
Rep 41
try another sd (or use an usb!) card.. mostly in such case it has to do with a bad sd card and of course format it to fat... you know. Success |
10-25-2020, 09:32 AM | #1716 |
Rep 12
Hoi / hello,
nee, hoe krijg ik hem in recovery mode? Android deel start niet op. How to get it in recovery mode. I can't boot the unit into Android. I discovered a reset button in the back of my Mekede unit but it is only turning it of and wenn i puss another time it shows the bwm connectdrive logo again but noting happens. Pussing the button for 30 sec won't also not help. What i tried: Disconnecting power on the battery Short press reset button Long press reset button (30 sec +) USB changing the OTA Package name Thanks in advanced (alsvast dank) Last edited by Aram2020; 10-25-2020 at 09:38 AM.. |
