10-28-2020, 01:43 AM | #1739 |
Rep 1
Hi everyone,
i am searching for a MCU Update for my device. Now i have the version 615085dFY-N5.0-G-D-C-200428 I bougt the screen from "FedJu" Shop, but they donīt give me an update. "dFY" should be DMP Cardesign and Wincago? I contact DMP Cardesign, but they cannot give me an update too, because i diddnt buy the screen by there. Have anyone the same screen and a update? I have a problem with that after a while there is a loud scratching and then the sound fails. Furthermore, the control panel always pops up even though no temperature etc. are adjusted. Got the screen in a Mercedes C-Class. Thanks, Robs |
10-28-2020, 02:28 AM | #1740 | |
Rep 1,048
Kri |
10-28-2020, 03:49 PM | #1741 | |
Rep 159
It would appear as if there would be light but the only light source is my own car. The only complaint I have with it is that it gets blinded by my license plate light, resulting in that white smear on the left. But I only see this at pitch black. Still I believe the trade-off is totally worth it coming from the standard CVBS. Thanks a lot for sharing that link |
10-28-2020, 05:02 PM | #1742 |
Rep 1,338
Drives: 2014 F30 320D X-Drive
Can it be possible to lock access to the system and keep BMW idrive visible only?
I am concerned when checking car into a garage and people might start messing with android and my personal information. I tried user management and set new user but a. on boot it defaults to the main user )owner) and b. you can't set password anyway
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
10-29-2020, 01:58 AM | #1743 |
Rep 143
For Kri or (anyone else interested), if you want to check if there's anything of note in this update.
Sent to me by AVIN to try to fix an ongoing issue with my new unit. While it did not resolve it, I doubt the issue is with this firmware (the issue persisted with every firmware I tried). Ksw-Q-Userdebug_OS_v2.3.5-ota.zip They also sent me their untranslated factory_config that they wanted me to install along with 2.3.5. I took a look at it and only found one new item at the end: "speed_play_switch". I don't use the SpeedPlay app that I'm guessing that's for. factory_config.xml |
10-29-2020, 03:14 AM | #1746 | |
Rep 2,367
Drives: E63 645Ci
EvntHrzn94.00 |
10-29-2020, 09:10 AM | #1748 |
Rep 116
Hello everyone!
Silly question, maybe.. I want to use ONLY the OEM system, but with the 10.25" screen.. I already have it installed but it's giving me many issues.. What if I unplug the cable mark in red? Will the monitor work as the original one, but 10.25? (Of course I do not expect that the resolution will be ok without coding it, but that's another topic) |
10-29-2020, 09:25 AM | #1749 | |
Rep 43
10-29-2020, 09:48 AM | #1750 |
Rep 116
Yes I know that I could do like that.. But my idea was to install an MMI for CarPlay (the only thing I use, and I've got a friend with the same OEM system I have and the MMI works great) with the bigger screen..
10-29-2020, 11:12 AM | #1751 | |
Rep 2,367
Drives: E63 645Ci
10-29-2020, 02:57 PM | #1755 | |
Rep 143
When it rains... EDIT: And also....2.3.6 fixed the issue I was having somehow! Hooray I guess when the gurus get done examining these updates, maybe there'll be a clue in there for me as to why this update fixed it when the others couldn't. Last edited by EvntHrzn; 10-29-2020 at 03:28 PM.. Reason: Hooray! |
10-29-2020, 03:42 PM | #1756 |
Rep 1,048
This time i got again two updates within a couple of hours, 2.3.5 and 2.3.6
Basicly they only forgot kswpmedia to update on 2.3.5 so with 2.3.6 they also updated that file, therfore i only compare it with this. I checked the update in comparison to 2.3.0 , this version 2.3.6 is from 28th October 2020. The update cen be found here: https://mega.nz/file/wRgw3ZxL#vvY997...BgW8cFohHr8j-c Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v2.3.6 ro.build.version.incremental=eng.zlx.20201028.094746 ro.system.build.date=Wed Oct 28 09:47:31 CST 2020 ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zlx10280947:userdebug/test-keys Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v2.3.5 ro.build.version.incremental=eng.zlx.20201023.153443 ro.system.build.date=Fri Oct 23 15:34:26 CST 2020 ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zlx10231534:userdebug/test-keys
As the factory config update is also not targeting our systems i do no new factory_config.xml file for this, so the 2.1.0 Config file can still be used. Kri Last edited by Kri; 06-06-2021 at 12:00 PM.. |
10-29-2020, 03:48 PM | #1757 | ||
Rep 1,048
The File updating is still a hurdle for some people so i don`t want to update it too often, Quote:
What did it fix exactly ? The update has lots of not related to our headunits changes , so its difficult to find real bux-fixes. Kri |
10-29-2020, 03:57 PM | #1758 | |
Rep 143
Original statement (see edit): All I know is yesterday I updated to 2.3.5 and the corruption happened immediately upon reboot as usual, and today I updated to 2.3.6, and until now several hours later, no corrupt reboot As RedErik mentioned, it does seem though that my specific model seems to have a hardcoded bootanimation of some sort (the circle of bubbles) https://f30.bimmerpost.com/forums/sh...&postcount=329 https://f30.bimmerpost.com/forums/sh...&postcount=331 EDIT: I should have known from years of IT that these things have a way of deceiving you. So the issue has definitely improved (corruption doesn't go past splash image) but neither of the new updates have completely resolved the corruption issue. Back to square one Last edited by EvntHrzn; 10-29-2020 at 07:25 PM.. Reason: Fuck |
10-30-2020, 03:15 AM | #1759 | |
Rep 2,367
Drives: E63 645Ci
EvntHrzn94.00 |
10-30-2020, 03:26 AM | #1760 | |
Rep 353
Night sensitivity of this camera is amazing, I recommend to make your lic plate lights tinted or as a temporary solution to steak black tape on the half of the light. I'm going to swap my LED light for the older ordinary ones (original for E70), hope this helps. |
