10-30-2020, 03:40 AM | #1761 | |
Rep 143
10-30-2020, 05:17 AM | #1762 | |
Rep 1,048
Kri |
10-30-2020, 05:22 AM | #1763 | |
Rep 2,367
Drives: E63 645Ci
I don't know to be honest, on one hand when it misbehaves it looks like LVDS hardware issue, but then switching to OEM and back to Android cures it Last edited by RedErik; 10-30-2020 at 05:41 AM.. |
EvntHrzn94.00 |
10-30-2020, 05:53 AM | #1764 |
Rep 3
I have problem with connecting Torque to OBD2 dongle via wifi (Vgate iCar2 wifi). Everything works fine on iOS and Android phones.
HU sees dongle network and manages to connect, however Torque doesn't connect. In Torque options I set correct IP and port. HU version 2.1.0 with root Do I have do anything extra for the connection to work? |
10-30-2020, 05:57 AM | #1765 | |
Rep 1,048
EvntHrzn do you have connected the chinese GPS mouse or are you using a splitter ? If using a splitter, remove it and connect the mouse for test. Kri |
EvntHrzn94.00 |
10-30-2020, 06:12 AM | #1766 |
Rep 2,367
Drives: E63 645Ci
I can't remember what was Nick's exact issue. Is it mentioned on Discord?
10-30-2020, 08:55 AM | #1767 |
Rep 2
I have a problem after the installation of my android10 64gb 10,25 unit. The time on the OEM is always --:--. I have no info about the trip or the gasoil stats. Can we help me? Thanks a los
10-30-2020, 10:14 AM | #1769 |
Rep 36
Installed android 10 unit and aftermarket rear camera. Anybody had an issue with front parking sensors audio beep? Graphic changes colour so sensors detecting.
Rear sensors and camera work ok. |
10-30-2020, 11:17 AM | #1771 |
Glücksritter
20
Rep 10
10-30-2020, 12:45 PM | #1772 |
Rep 12
Nope, stlll strugling pff
This Mekede HU seems not to have a boot menu. The trick from the frontpage with chaning the usb name and renaming the zip is also not working. Took it out of the car now trying to find a sollution behind my desk. After pushing the reset button (also when i push it for ages) only reboots into the oem look of the bmw. No Android id 7 part. |
10-30-2020, 12:48 PM | #1773 | |
Rep 12
Give it a shot, thanks for sharing. Maby it solves my trobbles
10-30-2020, 12:54 PM | #1774 |
Rep 12
Hi Kri,
I tried and i tried ... multiple usb sticks but no luck But thanks for the suggestion, nice to read people are traing to help me ;-) I think i have to go for the soldering part but now confronted the issue that there is no text on the motherboard of this Mekede SD625 HU so no idea what i should soldering |
F20_M135i100.50 |
10-30-2020, 02:43 PM | #1775 | |
Rep 1,048
Kri |
10-30-2020, 03:29 PM | #1776 | |
Rep 143
I'm not going to update the new one, or even look at it funny! at least at first. Just to cut down on any outside variables in trying to determine if the issue is inherent to these units or just the first one was bad. |
10-30-2020, 03:41 PM | #1777 | |
Rep 143
Something of note that I think I mentioned in my first post is that when I popped in my USB drive to update the firmware and the factory config, I kept the 720p bootnanimation and splash files in the OEM folder, as I have done for the last two units I have updated. I don't know if because of the weird nature of what seems like a baked in bootanimation it could have caused the ensuing corruption. If that turns out to be the case, at the time I didn't think I was causing any harm, as it's the standard procedure for updating these units as I'm sure you have done hundreds of times. If I had noticed the weird and different way in which it boots, perhaps I would have held off on updating, or at least not messed with the animation or image. |
10-30-2020, 04:33 PM | #1778 | |
Rep 12
Ask me how I know... |
10-30-2020, 06:59 PM | #1779 |
Rep 28
I have a problem with my Unit, latest Software, new Unit from Makede/Navifly (which I cannot recomend to buy from).
Everything workes somehow fine, the Screen picture is very blury, my old 8" was much better. But the real problem is when I go back from Android Apps to BMW NBT I get into the Page where it tires to connect to AUX and tells me that there is no signal or connection or alike. This is very anoying when switching back and forth. Also is there maybe a shortcut using the BMW dials etc. to jum back to BMW NBT? Btw. great threat, amazing people, amazing help here!!! |
10-30-2020, 09:53 PM | #1780 | |
Rep 143
Although, there is an option in the factory settings that needs to be set to the correct option for this to work. I think generally though, this function is its default setting anyway. Not 100% sure about that. |
10-31-2020, 12:50 AM | #1781 |
Rep 33
Zlink reliability has been extremely poor. So bad that I went the Autokit route and now disabled android BT altogether. Too bad too bc it does connect and launch zlink. I haven't had Autokit do this reliably either.
Doesn't seem like anyone here uses zlink, but I'll try this update and see if it's any better. Last version had zlink working 25% of the time and Carlinkit/Autokit about 70%. Connection was much more consistent on Autokit |
10-31-2020, 03:54 PM | #1782 |
Rep 8
Spotify Issue
I upgraded to the latest app version 2.6 from 2.09 and previously I had full spotify control in carplay, now I have to control spotify on my Iphone app as nothing appears in the headunit except the playing now info, Can anyone suggest a solution please?
