01-13-2019, 06:59 PM | #1695 |
Rep 12
I have exactly the same case. What kind of Android image u have? I firstly upgraded from default dated 20180828 to 20181128 (many thanks to German guy that shares his drive) and then I tried to update MCU from version CIC 180824 to 180921 and I get the same message no matter what. You have to feel very lucky to buy from Ali. There is zero support, u write to him a page describing the problems and u get a few irrelevant words for answer. Your are completely on your own. Anyway my main issue is an idrive like controller that came with the unit that works for a few seconds and the stops. If u unplug and plug again it works again for a few secs and then nothing. Nothing solved with Android upgrade and my only hope is with MCU update. If someone has to suggest anything else he is welcome. Sorry for writing here but couldn’t find any specific thread for e83 units although they are pretty the same.
01-15-2019, 01:35 PM | #1696 |
Rep 190
Has anyone problem with HERE WEGO MAPS ? When I am in idrive side and hear radio while navigating with HERE WEGO the sound coming from the left front speaker is cracking.
Am I the only one ? |
01-15-2019, 04:16 PM | #1697 |
Rep 78
splitter works but you have to start your car quickly from the moment of unlocking, if you slow android side will not trigger and car will not start.
01-15-2019, 05:57 PM | #1698 | |
Rep 190
01-15-2019, 11:07 PM | #1699 | |
Rep 33
I wish this could be fixed somehow as first of all the sound is cracking indeed and it is annoying that it comes only from left front speaker. When Android is in front of idrive, the audio quality is exactly as good as expected. I can't figure out why they set the audio to come from front left channel only when Android is running in the background with poor quality. |
01-16-2019, 01:18 AM | #1700 | |
Rep 190
01-17-2019, 12:09 AM | #1703 |
Rep 47
01-17-2019, 11:33 AM | #1704 |
Rep 78
on NBT android boot is timing out after 10-15 secs, I'll update firmware maybe this issue has been solved
01-17-2019, 02:50 PM | #1705 |
Rep 33
01-17-2019, 03:48 PM | #1706 | |
Rep 190
The navigation apps is another story. Sygic Truck does not output sound at all unless you choose aux as a source. Igo the same. Here WEGO maps sound is crackling. Waze the same. Is this app problem or eventcenter app of the unit does not let these apps function correctly? By the way Sygic truck has very good output on the screen. Is like an OEM app navigation. Try it and you will see. Also uses maps from Navteq which are the same as HERE WEGO. It is a pitty that the sound does not come at all when you are in idrive side for audio. Has anyone any clue for this behavior? Also my unit sometimes does not output sound from left front speaker at all. For making calls etc. If I restart the unit everything is ok. Does anyone have the same problem ? |
01-17-2019, 06:08 PM | #1707 |
Rep 540
I've still got weird problems with TomTom on my Avin unit. The GPS signal is intermittent and it can take a while to realise where I am so it's useless.
It's confusing me because Sygic works perfectly fine and I used it throughout a 100 mile trip with no issues at all which proves GPS is working alright. Anyone else have any weird problems with some GPS apps or any thoughts on what I can do to be able to use TomTom? I will factory it at some point when I can be bothered to redownload everything on there...which brings me onto another question - does anyone else find download speeds really slow on their units? I've even tried an Ethernet cable with a USB to Ethernet adapter which works but download speeds are still slow. The 1GB or so map updates for Sygic and TomTom each took a good half hour or so to download when on my connection that should be about 40 seconds at full speed. |
01-18-2019, 03:18 AM | #1708 |
Rep 2
Hi all, so although being new to this forum I have read almost everything re:android units and wanted to thank everyone’s input as it made ordering one far simpler and lowered expectations. I had a 7.1 unit delivered and had several issues so have now installed the new 8.1 Oreo, I need to update the firmware this weekend as there’s just a boot up issue currently. Once I’ve done that I’ll post some pictures of my install and write up in my experience of use and functionality.
I’m also installing an amp with and alpine upgraded speakers so will get images and how I’ve done it too. Cheers for everyone’s support so far |
01-18-2019, 05:44 AM | #1709 | |
Rep 102
Do you know if this could be an issue? On the main harness to add the Ugode and the Match ISO cables? Is the amplifier using any power from the main harness? I really hope I will not break the electrical system in my car... |
01-18-2019, 02:18 PM | #1710 |
Rep 36
No one faced the problem that the mp3 tags are not well read? I found that if the mp3 file has a point in the name, such as "feat.", the tags of the file are not read correctly and shows unknown artist and unknown album.
In the 20/09 update this was not happening... |
01-18-2019, 11:35 PM | #1711 | |
Rep 33
01-19-2019, 11:09 AM | #1713 |
Rep 102
Thanks! Do you know if the Alpine upgrade has a harness similar to Ugode's? The one that the optical cable needs to transfer to, I think its called ISO cable. If yes, where should I assemble the amplifier ISO harness, before the Ugode or after? CD player - amplifier - Ugode- main car harness, or CD player - Ugode - amplifier- main car harness?
01-19-2019, 11:12 AM | #1714 |
Rep 102
01-19-2019, 11:17 AM | #1715 | |
Rep 33
When I installed Ugode, I did not pay attention at all to how Alpine upgrade kit is installed, just unplugged the original radio and plugged Ugode's harness there in between. |
01-19-2019, 11:25 AM | #1716 | |
Rep 32
