07-29-2021, 10:56 AM | #67 |
Rep 228
Hi again, when i get to step 19 both options for I-Step (shipm.) and I-Step(target) are both greyed out and are unavailable , although i can see them both in the previous step, any possible answer to this ? All the entries for the modules / ECUs ? are all blue indicating no updates ? Could it be the Typeschlusse of 3E51 that i am entering being wrong
thanks
F30 335d xDrive M Sport + 2014 |Birds B3 Dynamic Suspension Kit Springs and Dampers |Pro Media Pack | Visibilty Pack | Interior Comfort Pack | Electric Adjustable Heated Front Seats + Driver Memory
07-29-2021, 03:03 PM | #68 |
Rep 1,992
Drives: F30 335d
Do you have the full psdzData?
if I've helped - an Appreciate would be, er, very appreciated!
07-29-2021, 03:08 PM | #69 |
Rep 228
I have v.4.30.33_PSdZData_Full, and i am using E-Sys 3.281.
07-29-2021, 03:20 PM | #70 |
Rep 1,992
Drives: F30 335d
I think you will need a newer Esys version - 3.30.0 or onwards to use with that version of psdzdata. The 4.17.20 version covers cars up to 2019 iirc.
07-29-2021, 03:23 PM | #71 |
Rep 228
I did have 3.30 installed at first but it didn't give me the option to Read SVT( ... the option was Read VCM instead, then read ECU then Load, Save and finally Edit
08-14-2021, 11:44 AM | #73 |
Rep 20
Looking for a bit of help..
I've followed through all the steps, everything calculates and seems to work but right at the end when flashing it comes up with finished with error and the message below; TAL-execution "not successfully" finished. [G200] I used Typeschlussel 8K72 as the car's registered mid way through 2016 and this is the only bit that could be wrong but I figured none of the calculations after this would work if it was? Anyone got any ideas? Thanks |
08-15-2021, 03:38 AM | #74 |
Rep 424
When it's worked in the past for me it takes maybe 1-2 minutes to apply the update to the ECU. When it hasn't (due to wrong 'Typeschlussel') it's seemed to work, but the update takes a couple of seconds (and hasn't updated anything). It may have also had the 'not successfully finished' message - I can't remember tbh as it was obvious it wasn't successful.
If you've followed the instructions perfectly, chances are that it's expecting a different model type. The list isn't exhaustive, just what I cobbled together from my research / for my needs. Did you try 3E51? |
08-16-2021, 04:20 AM | #75 |
Rep 20
Update: Tried the other code and it definitely didn't work, shows as nothing to update and couldn't flash anything. I'll give it another go at weekend unless anyone has any other ideas?
It takes a few minutes before the error so it looks like it's doing something but I'll try the other code tonight and see what happens. Last edited by Labradoodleb; 08-17-2021 at 06:43 AM.. |
09-08-2021, 07:21 AM | #76 |
Rep 151
bishbosh Thank you very much for working this out and sharing how to do this, I tried to follow and do this to my 435xd and failed at many points by not having the full psdzdata, then the version was too new and I needed a newer version of e-sys, but I got there in the end. Like a few others I have a standard car at the moment so the gears do feel a little sluggish but I plan on getting it remapped quite soon. Thanks again,
2016 435xd GC, MTC intercooler, centre and back box deletes, GKR stage 2 remap, methanol injection, H&R lowering springs. To do: wash it. |
Stainy265.00 |
10-27-2021, 06:00 PM | #77 |
Rep 2
Hi,
I have a 2017 435D and would really like to carry out the Alpina Flash but cannot understand where I can get the Alpina Flash software from? I have E-sys but can anyone please point me in the right direction? Many thanks |
10-28-2021, 03:35 AM | #78 | |
Rep 1,325
Once you've got that again there's a full guide on the main forum, it's relatively straightforward |
10-28-2021, 05:40 AM | #79 |
Rep 211
Awesome post and exactly what forums are for! Well done. Loved the charger solution by the way. I remapped my car and didn't appreciate that the writing process could be so intensive in terms of power as to require 50amps !! at 14V. I don't know what on earth is in those ECUs. I did 'support' my battery, with another battery and a 15amp charger (set to supply mode). The thing that troubles me is that voltage requirement. Really? 14V required on a 12V system? A good condition battery, fully charged is going to be able to maintain 12V against virtually armageddon. But if programming is going to fail potentially when you get below 14V its a whole different ballpark. Anyway, great post.
10-29-2021, 05:05 AM | #80 | |
Rep 2
02-16-2022, 02:47 AM | #81 |
Rep 131
Just wanted to say a big thank you bishbosh for the guide on this. Having done made a guide in the past, I know these can take a lot of time but they are very very helpful.
Like another member, I didn't get the blflash option but I've had my istep updated before so this could be why. I was also using E-Sys 3.36 and psdzdata 4.33 so may have been a little different. Unlike other members I am not getting the gear selection in comfort mode of sport, only sport +. I had these before so have lost them which is odd. I have bimmercode so can get them back but I don't know which module I should be search for... any ideas? |
03-16-2022, 07:25 PM | #82 | |
Rep 85
03-17-2022, 05:25 AM | #83 |
Rep 468
03-17-2022, 06:40 AM | #84 |
Rep 85
03-17-2022, 10:58 AM | #85 |
Rep 85
I found this One WAPBG2000MEV#####
I have obscured the last Number for privacy. This Is an alpina vin of b3 g20. Can you help me to understand how can flash the alpina software please? |
03-17-2022, 12:31 PM | #86 |
Rep 1,992
Drives: F30 335d
Bg20 will be the code.
03-18-2022, 04:52 PM | #88 |
Rep 85
