06-07-2018, 07:38 AM | #1 |
Rep 135
Good source for Reversing Camera Retrofit hardware?
Hi All,
Anyone have a recomendation for a reliable source of the retrofit hardware to install the reversing camera in My F31? The 'bay seems to be unusally light on complete kits at the moment . . . TIA John
Past Previous: E92 335i, CIC retrofit, JB+, Perf Exhaust Last Car: MB ML350CDI, X800D-ML Retrofit, AMG Steering wheel, Brabus tuning box Current car: F31 335d - NBT EVO ID6 retrofit, 3AG retrofit, Coded EBT, Deleted RFTs!! |
06-07-2018, 08:07 AM | #2 |
Rep 644
I've recently fitted this kit to my F36, I also fitted the same kit on my previous F30. The kit is all brand new and all OEM. One thing to note is that the harness and camera cable are from a F10 so the harness needs a little bit of modification and you'll need to mount the control unit in the boot, there's a perfect place above the battery, it usually gets installed under the dash but it makes no difference.
https://rover.ebay.com/rover/0/0/0?m...2F262689576531 |
06-07-2018, 08:26 AM | #3 |
Coding ECU's remotely
445
Rep 1,176
Another vote for the Emtronika kit, I've used them twice for that kit and itis very good.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
06-07-2018, 10:03 AM | #4 |
Rep 135
Do you have a breakdown of what needs to be chnaged on the harness? I know the 5m HSD cables just don't exist - so boot mounting the box is fine with me...
Thanks.
06-07-2018, 01:55 PM | #7 |
Rep 644
Hi John, there's not that much to it really, I stripped the fabric tape off the harness so I could pull the power supply cable back and shorten it as it needs to be connected to the fuse box in the boot, I also shortened the ground cable and connected that to a ground point behind the boot side panel. There's also a ground point on the HSD cable, it reaches one of the car ground points ok in F30 but I had to run a separate cable from that down to a ground point on my F36, it was no problem though. I also purchased 2x pins with crimped tails from BMW to connect the cables to the FEM. I purchased some automotive fabric tape to re-wrap everything, it looks totally stock. The last thing is to code the car to get everything talking.
06-07-2018, 01:59 PM | #8 |
Rep 644
Yeah biggest pain for me on F36 was getting the HSD cable from the roof lining down to the rear pillar and into the boot, was ok though. I was a bit worried about taking the tailgate trim off but that turned out to be straightforward enough.
06-07-2018, 02:22 PM | #9 |
Rep 4,653
Can you get a kit for M4 - really miss it!
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
06-07-2018, 02:30 PM | #10 |
Rep 644
06-07-2018, 04:40 PM | #12 |
Rep 4,653
From Emtronica? Are they hard to install?
Steve Roberts UK
06-09-2018, 08:02 PM | #15 |
Rep 1,338
Drives: 2014 F30 320D X-Drive
06-10-2018, 10:41 AM | #16 |
445
Rep 1,176
if it's an F30 then it's about 3 hours of labour, F31 is a pain in the ass and is 5hrs
06-10-2018, 03:01 PM | #17 |
Rep 171
Done this myself, it's not that difficult at all (F30)
One thing I will say is the customer service from Emtronika was exceptional. They sent me an incorrect switch mechanism housing and had to send me a replacement one, they were superb to deal with. |
06-10-2018, 04:13 PM | #18 |
Rep 644
Yep, have only had excellent service from Emtronika as well and they deliver very quickly. Don't forget to ask for a new boot release handle with the integrated camera mount if you order a kit, they supplied it FOC.
06-21-2018, 06:54 AM | #21 |
Rep 8,636
I emailed them about the OEM kit and they said that they also recommend the cheaper non oem kit which is easier to fit, anyone used it? If so whats the difference between this and oem?
https://www.ebay.co.uk/itm/253053562512 |
06-21-2018, 12:52 PM | #22 | |
Proud Owner
39
Rep 30
At a much cheaper price than OEM, why would you not? The installation kit is the same BTW, i.e. the control unit is in the boot, not behind the dash. Hope this helps.
BMW F30 320d M Sport Auto with Veneto Beige Dakota Leather, Walnut Trim, Prof. Nav, M Adaptive Suspension and 19" 403M Alloys. Mods: Debadge, Evolve Remap (221BHP), Depo Headlights, M-Sport Brakes (370mm), ACS Springs, Eibach Spacers (10mm), Dual Exhaust Conversion, M-Perf. Diffuser, M-Perf. Exhaust Tips, LCI Rear Lights, Boot Spoiler, Reverse Camera, LCI A/C Surround Trim, Sport Gearshifter (with 2TB), EBT + General Coding Items
SkyJawa3718.50 |
