07-17-2018, 08:03 AM | #1 |
Rep 4,933
Home applied paint protection
Now We have a new pcp car in the house I am looking to get some form of pain t protection on it. I have a drive way but no fancy polishers etc so would be manual labour and cloths.
What would people recommend for a technical novice? I was thinking I would use gtechniq serum light as I had on the 340 but not sure I trust myself to apply it properly without leaving ceramic streaks or what ever everywhere. cheers |
07-17-2018, 08:07 AM | #2 | ||
Rep 4,933
07-17-2018, 08:13 AM | #3 |
Rep 13,043
Drives: BMW M340I G20
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
07-17-2018, 09:12 AM | #4 |
Rep 944
Autoglym Extra Gloss Protection (EGP) is a synthetic paint sealant which should be applied thinly to the paint and buffed off once completely dry (~45mins). Nothing wrong with going for two thin layers ( buffing off in between coats) if you wish.
Can have waxes etc applied over it for extra layering and protection, but is good for many months on its own if you wish. A small bottle of EGP goes a very long way, probably do a car ten times over. Available at you local Halfords. |
07-17-2018, 10:26 AM | #5 | |
Rep 2,113
....,,,,..,,..6732.50 |
07-17-2018, 10:34 AM | #6 |
Rep 20,651
Sonax do some pretty decent protection, far superior to autoglym, last longer and decent range of top ups available.
Just remember spend as much time as possible on the prep, using stuff like Dodo Juice Lime Prime etc. Clean your car have a decent easy to follow prep process. |
07-17-2018, 10:53 AM | #8 | ||
Rep 4,451
LobB5109.00 |
07-17-2018, 10:58 AM | #9 | |
Rep 7,484
07-17-2018, 12:49 PM | #10 |
Rep 7,484
OP if you follow the instructions you can't go wrong. Make sure you apply in a garage and allow the coat to cure. Don't get the coat wet for at least 24 hours. Don't apply in heat or in direct sunlight. Smears are easy to deal with during the application stage. Use an LED light if required to check and check again. Not an issue if you work in small areas and a panel at a time.
There are many options. Gtechnique CSL followed by Exo V3 CarPro CQ110UK followed by CarPro Gliss Sonax CC36. Carbon Collective Oracle (made in the same factory as CSL and similar ingredients). I have the Sonax on mine at the moment. The CSL had to be removed. I had a few fox scratches so decided to do it all again. This is a major drawback. You need a professional detailer or know your stuff and have a paint gauge to remove it else you may take off the paint! |
07-17-2018, 01:26 PM | #11 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Going off piste slightly, has anyone tried a paint protection film in all the right places, like the 3M stuff?
07-17-2018, 01:42 PM | #12 | |
Rep 4,933
Brigand I use sonax now as an after wash spray so I assume the actual protection is good stuff as well. I don't have access to a garage so it have to be outdoors after a wash and dry. Thanks all. |
07-17-2018, 03:36 PM | #13 | |
Rep 1,373
No stone chips. Its a bitch if you crash though like i just did. |
07-17-2018, 11:12 PM | #14 | ||
Rep 7,484
07-18-2018, 02:18 AM | #15 |
Rep 13,043
No. I just finish with a coat of decent wax now and again.just started using
Collinite 845. It's brilliant https://www.cleanyourcar.co.uk/colli...-insulator-wax
07-18-2018, 03:40 AM | #16 | |
Rep 1,847
Did the whole car and left it overnight....... was a pain to get it off. Wont do that again! |
07-18-2018, 04:24 AM | #17 |
Rep 13,043
I'm only gutted I've not used it before. I did as I was told and covered quarter of a panel at a time. It was sooo easy to use.
07-18-2018, 04:55 AM | #18 |
Rep 1,847
creepy coupe1867.00 |
07-18-2018, 05:27 AM | #19 |
Rep 1,373
Because its expensive to replace and im not sure insurance companies pay out unless you tell them its on there. The last damage i did i went outside insurance as i forgot to protect no claims and had 1k Excess anyway and i got all work done for 1200 quid.
Soul_Glo13347.00 |
