03-11-2021, 07:55 AM | #23 |
Rep 4,134
How is the car running otherwise? Did you get the Meth hooked up?
Mods: Yes.
03-11-2021, 08:19 AM | #24 | |
Rep 1,148
So far so good tho, I'll try to get a fin measurement later, I don't drive the car much |
03-11-2021, 09:23 AM | #25 | |
Rep 4,134
What map are you running?
Mods: Yes.
03-11-2021, 09:38 AM | #26 | ||
Rep 1,148
I'm Excited to, I'm going with the aem kit, a lot of great reviews on it, simple and easy. I can post logs of a few runs currently if you want those. |
03-11-2021, 10:49 AM | #28 |
Rep 1,148
I'll get them up shortly bro
Plugs have from the best of my knowledge 70k on them lol Previous owner took care of the car pretty well but some things were left unattended, so I think that's where some of the timing issues are. I'll update in about 15/20 min with logs |
03-11-2021, 11:08 AM | #29 |
Rep 1,148
91 octane stage 2+
https://datazap.me/u/pussiwillow/91-...&data=3-14 95 octane stage 2+ on vp octanium mix https://datazap.me/u/pussiwillow/95-...&data=3-14 https://datazap.me/u/pussiwillow/95-...&data=3-14 |
03-11-2021, 02:39 PM | #30 |
Rep 4,134
Looks like that 95oct cleaed up the timing, but like you said, you may need to change the plugs. I also note that the IC is doing a good job of keeping temps down, but you're probably at 50F during those runs, right?
Mods: Yes.
03-11-2021, 04:45 PM | #31 | |
Rep 1,148
Ambient was around 63* on the 95 octane map runs |
03-30-2021, 11:46 PM | #32 |
Rep 1,148
Alright so new plugs in today, been a rough couple weeks with work etc, bit the bullet and ate dinner in the garage while I changed plugs, I'd say this is my timing issue but logs tomorrow will confirm that, definitely some worn plugs
03-31-2021, 10:43 AM | #33 |
Rep 7,602
They look similar to mine. Did you confirm the gap of the ones coming out vs the ones going in?
https://f30.bimmerpost.com/forums/sh...3&postcount=35 |
03-31-2021, 01:04 PM | #34 | |
Rep 1,148
03-31-2021, 01:11 PM | #35 |
Rep 1,148
I did this to confirm if my timing being pulled from a few cylinders is from the plugs, maybe a few coil packs are within spec but not enough output to jump the larger gap from the worn plugs, data logging after work, car felt smoother on the way to work but didn't get on it.
I will be doing b58 coils in a few months when the kit is finally released and I will push the gap on new plugs closer to .032 and see how things look as far as timing etc |
03-31-2021, 01:58 PM | #36 | |
Rep 7,602
Mine coming out were about the and and looked visibly worn as yours did. 45k miles on those. |
03-31-2021, 02:06 PM | #37 | ||
Rep 1,148
03-31-2021, 02:14 PM | #38 |
Rep 7,602
Yeah i dont think you'll have any issues with that, and they are indeed pregapped and not supposed to be changed, but didnt the box say they are 0.032 lol? Again i dont think its a problem, but just seems yours came gapped a little smaller than average.
03-31-2021, 11:36 PM | #40 |
Rep 1,148
New data log, I was only able to get 1 log tonight, not many places to open up 4th gear and too many people around, ideally would like atleast 2 but too much attention anyway, compared to the others i posed in here I think they look "better" as in not as much being pulled, not ideal, bumped back to a 91 octane map and going to re log later when the weather temps come down.
https://datazap.me/u/pussiwillow/95-...&data=3-16 Pushing 80's today so iat was mid down to low 90's at end of pull, started 99* and ended around 92* about 11 degree over ambient, possible the timing can be affected by the iat temps compared to other my runs 20/30 degrees lower but I think it's a small improvement, 91 octane map with some octanium in the tank sometime this week to see more info. |
04-01-2021, 12:41 AM | #41 | |
Rep 7,602
Yeah timing not great. I would get a fresh tank of pump gas with no additives on the 91 map and see how timing looks to make an accurate assessment of how the plugs are doing. You could also consider resetting octane adaptations and putting some miles on it after the map change since you have been running octanium. |
04-01-2021, 09:08 AM | #42 | ||
Rep 1,148
12-27-2021, 10:43 AM | #43 |
Rep 1,148
Bump. Putting my meth kit together as we speak, what's the favorable set up here, check valve or solenoid set up? I see mixed reviews on both set ups, I hear solenoids don't hold up, and vice versa. Anyone?
12-28-2021, 01:57 AM | #44 | |
Rep 2,357
Solenoid would be better for progressive control, but that doesn't matter as you want to run 100% for max atomization and even distribution. Adjust your volumen with the nozzle size - not the PWM. What controller have you chosen? My setup...
(A Dane in China) |
