10-31-2021, 05:02 PM | #45 |
Rep 188
Again, never a doubt. That's a good partnership you've got and I appreciate the top-notch service.
2015 M-Sport 435i xDrive (6MT)
MHD Stage 2+ / VRSF Catted DP / ARM F3X IC / BMS CP / AFE Pro Dry S |
10-31-2021, 07:21 PM | #46 | |
Rep 7,598
10-31-2021, 07:50 PM | #47 | ||
Rep 188
11-01-2021, 07:18 AM | #48 |
Rep 188
Would someone mind looking at this log to see if anything stands out? Although it seems kind of obvious, what's the relationship with boost target to boost? Why is there a gap in the two when I punch it, is that turbo lag demonstrated with data?
https://datazap.me/u/mcsweeto/pre-fm...og=0&data=3-16
MHD Stage 2+ / VRSF Catted DP / ARM F3X IC / BMS CP / AFE Pro Dry S Last edited by mcsweeto; 11-01-2021 at 08:08 AM.. |
11-01-2021, 09:11 AM | #49 | |
Rep 190,730
it takes 500 RPM (2000 - 2500 RPM) for your boost to reach the target, that's normal since your turbo needs time to spool.
AmuroRay2267.50 |
11-01-2021, 09:23 AM | #50 |
Rep 4,132
Mike is correct, that's normal. How does the car feel?
Mods: Yes.
mike@x-ph.com24165.50 |
11-01-2021, 09:27 AM | #51 |
Rep 188
Feels good, pulls strong. I had posted in another thread a few months back I felt like timing was being pulled in 5th while stepping on it to pass. That was during the heat of summer and I didn't have a chance to log then. I haven't noticed it since so maybe it was just IATs.
11-01-2021, 12:14 PM | #52 | |
Rep 7,598
Correct, all on the front of the turbo.
https://f30.bimmerpost.com/forums/sh....php?t=1732327 |
AmuroRay2267.50 1bad14-F3030.50 |
11-01-2021, 03:48 PM | #53 | |
Rep 4,132
Mods: Yes.
11-08-2021, 08:44 AM | #54 |
Rep 4,132
OP, did you Intercooler have a way to mount the fan shroud?
grocerylist has been having issues with his installation: https://www.2addicts.com/forums/show...1850989&page=3
Mods: Yes.
11-08-2021, 09:52 AM | #55 | |
Rep 188
11-08-2021, 11:06 AM | #56 |
Rep 7,598
Wait what the heck - this isnt right. The fan is supposed to be attached to the IC. The fan is going to be significantly less effective when there's a huge air gap between the fan and IC not to mention it going to put a lot of stress on the other mounting points
11-08-2021, 11:11 AM | #57 | |
Rep 7,598
11-08-2021, 12:24 PM | #58 | |
Rep 4,132
Is it less effective because the bottom portion isn't hook up? I don't think so - the stock IC is 5" high and only connects to the bottom portion of the radiator. So the even if it were stepped, there would still be distance between the two on the top half of the fan.
Mods: Yes.
11-08-2021, 12:36 PM | #59 | |
Rep 7,598
The fan is absolutely less effective when there is a huge air gap infront of it. It's not only about it being closer to the IC, the IC tabs are important to hold the fan up against the other cooling system components (toward the front of the car) that are higher up... The air is going to take the path of least resistance which means not going through the heat exchangers if it can draw air around |
11-08-2021, 01:50 PM | #60 | |
Rep 4,132
Mods: Yes.
11-09-2021, 06:46 PM | #61 |
Rep 188
Install vid:
Not my channel, but please subscribe to it- it belongs my friend Aaron who's an awesome host and fellow German enthusiast. Please go easy on me.
11-09-2021, 08:59 PM | #63 |
Rep 5,369
Hear exchanger fans are designed to fit within about 1 inch of exchanger and the fans need shrouding around the fan and heat exchanger to create a pressure differential to work. By having the fan sitting inches away from the radiator and IC makes it basically worthless.
BMW went to great lengths to have duct work forward of the IC and radiator create a pressure effect at speed and have the fan and shrouding tight against the back of the IC and radiator to maximize cooling. This ARM design negates all of that effort. Last edited by XutvJet; 11-09-2021 at 09:06 PM.. |
11-09-2021, 09:03 PM | #64 | |
Rep 7,598
11-09-2021, 09:41 PM | #65 | ||
Rep 4,132
1. The intercooler has more thermal capacity than stock 2. As I mentioned before, the thicker (more depth) a core has, the less effective that cooling is. The fan is there is help makers the core doesn’t heat soak. The ARM and ER cores don’t utilize this, and typically won’t suffer from this issue. 3. The fan is literally still mounted to the radiator 4. The fan is only running at a standstill or low speeds Look at these pictures and you can see the fan is still mounted on the back of the radiator with its shroud - oil/coolant temperatures should not be impacted. The intercooler is larger than stock, it will not see large increases in IAT like the stock intercooler would. Quote:
The easier way to tell how much of an impact this has is simply by logging it. Can anyone show their coolant logs before and after their IC install?
Mods: Yes.
sspade2464.50 |
11-10-2021, 12:33 AM | #66 | |
Rep 7,598
