07-11-2019, 04:47 PM | #1 |
Rep 172
Spark plugs and coils
I am due for spark plugs and coil change. Do you guys recommend a brand or an upgrade I should do instead of getting the oem ones?
Thanks!! |
07-11-2019, 05:39 PM | #3 |
Rep 139
Agree on stock spark plugs.
Why do you need to change the coils?
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150 2021 RnineT 2022 K1600B |
floydarogers690.00 |
07-11-2019, 07:56 PM | #6 |
Rep 172
07-11-2019, 08:42 PM | #8 |
Rep 172
07-11-2019, 09:25 PM | #9 | |
Curmudgeon and Pedant
690
Rep 3,489
Unless, as someone asked, you have FBO or other mods that require a hotter spart, there is simply no need to use other than OEM if one needs replacement. |
07-11-2019, 09:26 PM | #10 |
Rep 1,906
07-12-2019, 06:10 AM | #11 |
Rep 172
Thx for your replies, thought spark plugs and coils need to be replaced together. Guess I just need to replace my spark plugs since I am at 45k miles right?
07-12-2019, 08:25 AM | #12 |
Rep 849
Drives: BMW 435i
The manual in my 2016 435 shows the plugs needing replacement at 60K miles. You might want to check the service manual to see what it shows in the event there was a change between 2015 and 2016, but I believe you have another 15K miles before needing new plugs.
Jam101jam20.00 |
07-12-2019, 09:03 AM | #13 | |
¯\_(ツ)_/¯
945
Rep 1,762
07-12-2019, 01:39 PM | #14 |
Rep 94
Sorry to piggyback the post but, I wanted to do a 30K service on my 435i and change the plugs and coils. My question is, I have BOSCH plugs and coils from my 2008 335xi that I never used, will they fit my 2014 435i?
07-12-2019, 08:59 PM | #16 | |
690
Rep 3,489
Bosch and/or NGK are OEM plugs. They're pre-gapped for the car you bought them for. Also, they're often not interchangeable. |
