08-15-2019, 06:55 PM | #2443 |
Rep 101
08-16-2019, 08:33 AM | #2444 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
08-16-2019, 08:57 AM | #2445 | |
Rep 1,499
I just saw on the FB page that they released all the ACN maps and they are now under the OTS tab on the website (just confirmed). If you have the map pack you can move it over to "My Maps" and flash.
08-16-2019, 09:02 AM | #2446 |
Rep 101
I just went into the app and checked and all the acn beta maps are there now! Thank you for your help I’m about to flash over!!
08-16-2019, 10:56 AM | #2447 |
Rep 142
Can anyone tell me how idle timing should work? Mine is all over the place and I'm not sure if this is normal.
View post on imgur.com |
08-17-2019, 05:44 AM | #2448 |
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
my hesitation problem was my clutch slipping. fueling is great.
08-19-2019, 11:13 AM | #2449 | |
Rep 151
Thoughts? Thinking about switching to the standard 91 octane tune and seeing what happens as this gas appears to be better (consistent timing advance) compared to the chevron or shell 92 gas up top. Costco 92 (91 ACN): http://www.bootmod3.net/log?id=5d59b49cc090c644084cb94f http://www.bootmod3.net/log?id=5d59b4e5c090c644084cb951 http://www.bootmod3.net/log?id=5d5aaab2c090c644c52e0d5b Chevron 92 (91 ACN): http://www.bootmod3.net/log?id=5d50af76c090c623d664e701 http://www.bootmod3.net/log?id=5d540f15c090c638743c4f0d (overboost) Chevron 92 (Standard 91 stg2): http://www.bootmod3.net/log?id=5d386376c090c65ddbf47c69 Any advice would be appreciated (even if it's telling me i'm being too paranoid and should just enjoy the car). JaredG_F30 SeanWRT
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
08-19-2019, 01:08 PM | #2450 | |
Rep 1,115
08-19-2019, 01:09 PM | #2451 | |
Rep 2,639
8AT you need to do a 2nd to 4th gear pull, starting from 2000rpm to 6500rpm, if you don't have space, do a 4th gear pull, same rpms. 6MT, you do a 3rd gear pull, same rpm.
08-19-2019, 01:34 PM | #2452 | |
Rep 1,499
Costco gas seems to be a bit better quality but if I were you I would run the 91 ACN map and call it a day. With the gas you have you aren't going to see great timing advance.
08-19-2019, 01:43 PM | #2453 | |
Rep 151
Considering ordering some boostane and just deal with the orange deposits over all the plugs and o2 sensors that concerns me less than knocking and damaging the motor.
08-19-2019, 04:00 PM | #2454 |
Rep 1,499
Have you tried stage 1?
08-19-2019, 04:10 PM | #2455 |
Rep 151
08-20-2019, 09:23 AM | #2456 |
Rep 151
Seems like it was the ACN map causing overboost or me resetting the adaptations that fixed it.
Switched to the standard 91 stage 2 map and looks better all around. http://www.bootmod3.net/log?id=5d5b547bc090c644c52e0f32 Thanks for the help!
08-20-2019, 10:03 PM | #2457 |
Rep 1,286
When should one reset adaptations? I ran the Stage 2H map for about a day (so amazing!) and now flashed back to regular Stage 2. Should I reset adaptations? Car runs fine, just wondering...
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
08-21-2019, 12:55 PM | #2458 |
Rep 7,789
Hey Fellas,
Do you mind taking a look at my log below and give me some feedback to solve my stuttering issue? I was running E30 mix/tune for little over a year. The car ran perfectly with no issues. Approximately 2 weeks ago I switched from E30 to CA91 tune + transmission update and the car started stuttering almost immediately ~50% + throttle. I thought there might have been some Ethanol left in the gas tank/fuel lines so I drove it carefully under 3K RPM and went through the whole tank, nothing changed. After 2 full tanks of CA91, I switched back to E30 mix/tune hoping to fix the problem as it was functioning correctly before the change. Unfortunately, the car is still stuttering and I couldn't get a straight answer from PTF guys. From reading the latest round of replies on here, sounds like trialmountain and I might be experiancing the same issues? I've reset all adaptaions, ECU, went to a different gas station etc... no help. Can anyone help me out? Spark plugs have less than 20K miles on them. Coils are undetermined....but not sure if its a hardware issue as the car was running perfectly fine before the tune changes. Thank you in advance! Run on 8/20/19 (after reset, back to e30 map...etc) http://www.bootmod3.net/log?id=5d5cc0ddc090c644c52e132f CA91 gas http://www.bootmod3.net/log?id=5d5432eac090c644084cab7f Last edited by Bimmer Nerd; 08-21-2019 at 01:01 PM.. |
08-21-2019, 02:17 PM | #2459 | |
Rep 151
Your 8/20 logs to my rookie eyes doesn't make it seem like it should be stuttering. No major variations through each pull, consistent timing, no HPFP crashing (difference between target-actual) no throttle closure. I'll let someone with more experience chime in though. That said, your 91 log appears a ton worse than mine so I don't know if we can correlate this as the same issue.
08-21-2019, 04:27 PM | #2460 |
Rep 1,115
I'd try and flash back to the map version it ran well on to eliminate the possibility its software. If that doesn't work, you could try cleaning the MAF sensor with CRC Sensorkleen and see if that helps. If you're using a non-oem air filter there might be some oil on the MAF.
08-21-2019, 07:29 PM | #2461 | ||
Rep 7,789
08-22-2019, 02:19 PM | #2462 |
Rep 7,789
Hi everyone,
Please let me know your thoughts on the updated log. Still, there's a little stuttering present. I'm starting to think the clutch might be slipping from 1 year of E30 mix. I'll take it to an Indy shop if you guys can't find anything from the logs. ACN91 tune. Half a tank of CA91 and 2 gallons of 101 Octane. So octane should not be an issue according to my calculations. http://www.bootmod3.net/log?id=5d5df603ae729b7ca06b08aa |
08-22-2019, 02:51 PM | #2463 | |
Rep 1,499
Are you PWG or EWG?
All kinds of wacky stuff going on in that log 1. First thing that stands out is your IATs are extremely high. 155F IAT is significant and the DME will pull timing. Ambient temp isn't logged so I'm not sure how hot it was outside but if it's not over 100F outside then you should consider a better FMIC 2. You start over boosting at 3197 RPM and hit up to 19.9PSI with a boost target of 15.8PSI at 4147RPM at which you have a throttle closure. Boost starts to settle down then undershoots and by the time you hit 5802RPM you are at 12.1PSI with a 15.8PSI target. Not sure if that is a PWG thing 3. Timing across all cylinders is pretty consistent so that is good Quote:
08-22-2019, 02:53 PM | #2464 | |
Rep 151
Are you PWG or EWG? Why not just stick with the E30 if it works? Could be the clutch slipping, but you'd probably see the revs go up faster than normal if that's the case?
