06-09-2019, 06:35 AM | #1 |
Rep 105
Part list:
PS2 Turbo GFB DV+ BM Port Injection /w 750cc injectors AIC1 controller Snow Performance Stage 2 meth Fuel-It! Stage 2 LPFP ER Chargepipe M-performance LSD VRSF Catless Downpipe ARM FMIC Pricision Raceworks coils NGK plugs BMS Intake N20 3.5 tmap Custom tune by Ken @ Wedge Performance Anything else I'm missing? inlet / outlet recommendations? money isnt an issue want the build done right. |
06-09-2019, 09:18 AM | #2 | |
Rep 188
For the outlet, I'd get the VRSF one, fitment is spot on. I think it's around $180 total. |
06-09-2019, 12:38 PM | #3 |
Rep 1,288
HPFP?
06-09-2019, 01:12 PM | #4 | |
Rep 184
pure inlet and vrsf tick will be good to go |
06-09-2019, 01:32 PM | #5 | ||
Rep 105
06-09-2019, 02:59 PM | #6 |
Rep 107
If you have PI why do the b58 hpfp? I’m not certain what the actual numbers are, so don’t flame me if I’m wrong, but I’ve read it provides 5-15% additional DI potential.
2014 F33 435i M Sport N55 EWG - MHD - Wagner HFC - VRSF 6" Race FMIC, CP & TIC - GFB DV+ - FuelIT Stage 3 525 - EOS PI - Turner Strut Brace - Bilstein B14 - M-LSD - Turner Aluminum Subframe Mounts - PowerFlex Adjustable LCA & TS Bushings - H&R Sway Bars - Dorch Stage 1 HPFP
06-09-2019, 06:02 PM | #7 |
Rep 184
Best answer is xdi unit. No need for pi possibly depending on goals
Ut the b58 is a off a newer motor look at the new b series engines And read the thread. Hpfp new option |
06-09-2019, 08:01 PM | #8 |
Rep 2,357
F me what a shopping list LOL If the Snow stg2 has a controller then that is a waste. Just run it on the AIC. On the other hand the separate controller adds some flexibility.
(A Dane in China) |
06-10-2019, 12:46 AM | #9 | |
Rep 105
06-10-2019, 05:18 AM | #10 |
Rep 184
if you run the XDI you could forgo the PI i would prefer it as it lets the dme control everything not a secondary control system that could fail, another leak point, yadda yadda
06-10-2019, 10:50 AM | #11 |
Rep 105
true! I'm gonna wait for the spool performance hpfp though because the xdi pump is way too expensive for just 35% more flow.
06-11-2019, 02:28 AM | #13 |
Rep 373
this is interesting do you have any information or links to the spool performance hpfp. seems like there is two competitors in the near future for XDI no more monopoly
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
06-11-2019, 06:22 PM | #14 | |
Rep 25
pure inlet and vrsf tick will be good to go Last edited by mopa9000; 06-14-2019 at 02:13 PM.. |
06-11-2019, 08:50 PM | #15 |
Rep 928
Is lpfp not needed?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
06-13-2019, 03:52 PM | #16 | |
3441
Rep 79,211
For PS2 you'll want LPFP upgrade, especially with E85 use.
06-14-2019, 01:23 AM | #21 |
Rep 105
06-14-2019, 07:06 AM | #22 |
Rep 164
not directly related to the power portion of your build, but you may also want to look into better brake and suspenion components.
2014 F30 335i xDrive 6MT - Pure Stage 2 GFB DV / Inlet | XDI-35 HPFP | Fuel-It PI w/ AIC and LPFP Upgrade | BM3 | Fabspeed Catted DP | Dinan axle back | VRSF Race FMIC/CP | Dinan CAI | KW V3 | Wiechers CF strut bar | Dinan ARB | Spec stage 2+ clutch SMFW | Full M Performance Interior | M Performance BBK | Vorsteiner VFF107 MPS4S | Jordan Tuned Full E85 - 558WHP/520TQ on Mustang Dyno
JRocker3346.00 |
