12-26-2021, 05:23 PM | #1 |
Rep 7
ok I’ve had it with these run-flat tires
I managed to drive around for 35 years without ever blowing a tire on a pothole and now that I have a car with run-flats it costs me $300 every time I get within 6 blocks of one. They must have much nicer roads in Germany but these things just don’t work where I live. What do you do about spare tire storage if you switch back to decent tires? I’m not excited about losing half my trunk space but I can’t keep the car if this is how it has to be.
12-26-2021, 06:17 PM | #2 |
Rep 67
Triple A
'13 335i - 450whp / 450wtq @ 93 oct
BigBoost stage 3.3 turbo - FBOs / catless - DV+ - bm3 custom tune - xHP - Dinan springs - M Perf LSD - Borla ATAK |
12-26-2021, 06:43 PM | #3 |
Rep 4,358
2-ton scissor jack, breaker bar w/17mm deep socket, tire plug kit, battery or cigaretter lighter powered air compressor, roadside safety devices and if you feel more comfortable, a compact spare preferably 26" diameter.
12-26-2021, 06:58 PM | #4 | |
Rep 5,395
12-27-2021, 04:21 PM | #5 |
Rep 7
I'd be interested in seeing how that looks if you have a pic handy. Sounds like a good idea.
12-27-2021, 04:40 PM | #6 |
Rep 7
I think what I really need to do is make a coherent plan to do some suspension/brake/tire/wheel work so that might be another thread after I go read a whole bunch.
12-27-2021, 05:12 PM | #7 | |
Rep 5,395
I can give you some recommendations/options based on your answers |
12-27-2021, 05:24 PM | #8 | |
Rep 7
It is a daily driver that I'd like to evolve into something more track capable as it ages. I also admire a nice stance. I like the idea of going to 245/40 on the tires, and I'd also like to stiffen and lower it a bit. No coil-overs, and not too low given the roads around here. |
12-27-2021, 09:21 PM | #9 |
Rep 7
This is the fitment I really like, maybe not that wheel but I do like the OEM+ look
https://f30.bimmerpost.com/forums/sh...2&postcount=87 |
12-28-2021, 06:55 AM | #10 | ||
Rep 5,395
Do your grey front brake calipers look like the photo with two characteristic circles which indicate Brembo 4-piston calipers? See photo. |
12-28-2021, 01:28 PM | #11 |
Rep 7
Couldn't find any suspension info based on the VIN but from this pic I'd say that's not adaptive. Also my brakes look a bit different, photo is of the front.
Did a lot of digging yesterday and this is what I'm thinking currently, seems like pretty standard upgrades and mostly budget-friendly. Bilstein B8 Struts H&R Sport Springs Bump Stops (maybe? Dinan?) F80 M3 Brake retrofit It's wheel size that I'm having a hard time settling on. Either 18s or 19s all around, maybe 9w all around or it seems like a lot of people run 8.5 front and 9.5 rear? I'd like to understand the reasoning/impact of that a little better. update: strongly leaning toward 19x9 all around. Thanks a ton for the help btw! Last edited by bryankcmo; 12-28-2021 at 03:42 PM.. |
01-03-2022, 01:56 PM | #12 | |
Rep 498
The 18s feel nicer all around re: comfort, response, and handling. 19s do look better, of course. Last edited by AspektUSA; 01-03-2022 at 02:05 PM.. |
01-03-2022, 03:17 PM | #13 | |
Rep 5,395
You can easily run a square setup with 245/40-18 tires with BMW 8.0"x18" ET34 wheels. I have 400M wheels. They are other stock wheels the same size. With other 18" wheels depending on the offset you can run square 8.5" or 9.0" wheels with 255/40-18 tires. Square setups are nice with XDrive because you can rotate them front to back and get very even wear throughout the entire life of the tires. With XDrive, avoid dropping the front more than 1.5" or you risk breaking front axels. I'm not a fan of the B8/H&R combination. Both are setup too stiff at the factory and not adjustable. I prefer Koni Sport Yellows which are adjustable for comfort and Eibach Springs which aren't as harsh as H&R's. Don't pay expensive Dinan prices for repackaged BMW bumpstops. Just get shorter F80 bump stops. See attached photo. Based on what you have said, your brakes are one of three possible combinations: 1) Front 330mm x 24mm Rear 330mm x 20mm 2) F 330x24 R 300x20 3) F 312x24 R 300x20 You can measure the radius of your brake rotors right on the car and double it to find their diameter. See photos. Don't fall for people selling M3/M4 brakes at a premium price. They are exactly the same calipers as F30 Front 370x30/Rear 345x24 Other upgrade options for your car are: F340x30, R345x24 OR F340x30, R330x20 You can improve your existing brakes by installing Hawk 5.0 pads, full crossdrilled rotors from StopTech or Zimmermann and stainless steel brake lines. Do the same if you buy upgraded calipers. Hope this helps! |
01-04-2022, 11:04 AM | #14 | |
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
Photo: Whether or not this would work, or work very well, I don't know. Surely it's limited to the most common types of punctures that can be sealed with it. But hey, BMW felt that it was sufficient |
01-04-2022, 10:06 PM | #15 | |
Rep 498
Run flats have their perks, and I don't mind sticking with the factory RFT tires. |
01-05-2022, 11:42 AM | #16 | |
Rep 1,003
I can't think of a situation where a puncture wouldn't cause me to stop and get a tow, run-flats or not. I'd be too worried about damaging the wheel, and it's a game-over situation anyway since run-flats can't be repaired. Either way it's going to cost a lot of time. The likelihood of finding an 18 or 19 inch matching tire same-day is slim to none |
01-05-2022, 04:19 PM | #17 |
Rep 8
Echo this. I bought coilovers with EDC delete modules based on the sport button "handling" improvements, but once the car was apart found it had no EDC
01-07-2022, 12:23 PM | #18 | ||
Rep 312
johnung4531.00 |
01-07-2022, 02:15 PM | #19 | |||
Rep 5,395
01-07-2022, 02:22 PM | #20 | ||||
Rep 312
johnung4531.00 |
01-07-2022, 08:14 PM | #21 | |||||
Rep 5,395
01-08-2022, 08:44 PM | #22 | ||||||
Rep 312
And the Continentals from TireRack 225/45ZR-18 CONTINENTAL EXTREMECONTACT DWS 06 PLUS SL I nearly stepped up to the 19s but read some posts that it really wasn't worth it unless you were going for that slammed look, which I was not. That said next mod is gonna be some Dinan springs, not to lower it per se but to tighten up the suspension a bit more. |
