BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 Welcome Light
Studio RSR
      06-10-2015, 02:28 AM   #1
bryan06
bryan06's Avatar
25
Drives: BMW F30
F30 Welcome Light
Hi,
I have coded fog lights for welcome like following,
FEM_BODY 3063 MAPPING_NEBELSCHW_L_PART_OF_WL, Soft_On
FEM_BODY 3063 MAPPING_NEBELSCHW_R_PART_OF_WL, Soft_On
it's working.
Also I want to open front left/right turn signals and Left/Rgiht Mirror turn signal at same time for welcome like following.
Actual I had previously it. But this is deleted after CC coding.
I have searched on the internet but I couldn't find the coding.
How can I code turn signals for wlecome?
Thanks in advance
      06-10-2015, 05:12 AM   #2
re4ryu
re4ryu's Avatar
Drives: 320D Efficientdynamics
Originally Posted by bryan06 View Post
Hi,
it's working.
Thanks in advance
Hi there,
To code in all the turn signals as a part of your welcome lights, code the following:
In FEMBODY:
3062 > mapping_blinken_v_l_part_of_wl > hard_on - (left turn signal)
3063 > mapping_blinken_v_r_part_of_wl > hard_on - (right turn signal)
3062 > mapping_blinken_z_l_part_of_wl > hard_on - (left mirror turn signal)
3062 > mapping_blinken_z_r_part_of_wl > hard_on - (right mirror turn signal)
Note: There is no/little difference between soft_on and hard_on for these two sets of lights, so i have just left them as "hard_on".
Mental1.50
      06-10-2015, 06:55 AM   #3
bryan06
bryan06's Avatar
25
Drives: BMW F30
Originally Posted by re4ryu View Post
Hi there,
In FEMBODY:
Dear re4ryu,
Thank you for help. I will try this evening and inform.
      06-10-2015, 02:13 PM   #4
bryan06
bryan06's Avatar
25
Drives: BMW F30
Hi there,
In FEMBODY:
Dear re4ryu,
I have tried which your shared code, it's working.
Thank you again
      06-10-2015, 04:53 PM   #5
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Anyone know how to turn on the xenons when unlocking the car? That would be an amazing feature.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      06-10-2015, 05:22 PM   #6
re4ryu
re4ryu's Avatar
To turn on your xenons with the welcome lights, try coding:
In FEMBODY 3062:
Mapping_abblendl_L_part_of_wl > hard_on
Mapping_abblendl_R_part_of_wl > hard_on
My car has ordinary halogens fitted, but the coding should be similar. Let me know if that works for you! If not, there must be another code to get them to turn on.
EDIT: Forgot to mention that this code turns on my low/dipped beams, so it should work for your xenons too.
      04-04-2017, 01:05 PM   #7
fortythirtyfive
Drives: 435i MS
Hi there,
In FEMBODY:
Sorry for reviving a dead horse here, but I coded this today so that I could have my wing mirrors stay orange as a welcome light. Instead they just flash as usual and now my halo's don't light up.. (see video below)
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      04-05-2017, 11:58 AM   #8
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
Is your light switch in the Auto position?
      04-05-2017, 04:29 PM   #9
fortythirtyfive
Drives: 435i MS
Headlights? If so yeah
Edit: Ahhh! Went down to my car to double check, the dealer had turned automatic lights off during the service (that day when I coded it). So it's working now.. thanks man!
2015 435i - 401whp
      07-23-2017, 09:07 AM   #10
ViA
Drives: G30, F34, E90
It is possible to have welcome light at light switch in 0 position?
      07-27-2017, 03:07 PM   #11
Hypermile
Hypermile's Avatar
Drives: 2017 F31 328d xDrive M-S M-P
This?
      07-28-2017, 03:27 AM   #12
beanbaguk
beanbaguk's Avatar
Spain
455
Drives: BMW G30 520d M-Sport
Sorry for hi-jacking the thread but that's an awesome front splitter! Where did you get that from?
ETA....just realised you have an F32....bugger!
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport
      07-28-2017, 03:08 PM   #13
ViA
Originally Posted by Hypermile View Post
This?
I always drive with the light switch on 0 and not on AUTO. Consequently, my welcome light does not work...
It is possible to code that the welcome light will work?!
      12-23-2017, 08:45 AM   #14
CharlieF576
CharlieF576's Avatar
Drives: BMW 335d xDrive M-Sport Shadow
Does anyone know the difference between hard and soft on?
      01-08-2018, 03:22 PM   #15
Hypermile
Hypermile's Avatar
Soft ON = Fade ON
Hard ON = No Fade
M Sport
M Performance
      08-06-2018, 06:44 AM   #16
Driv3r_FR
Driv3r_FR's Avatar
Drives: 330D Xdrive Touring F31
In FEMBODY 3062:
Hello
Did you try this on your Xenons ?
Regards
      07-03-2019, 07:24 AM   #17
Lans70
Drives: BMW F20
Thx, it works bmw F20 116i 2012!
      11-06-2021, 02:57 PM   #18
deusexe
Drives: BMW F30 320d
What do you need to do in the car's latest software (!) To be able to activate the LED fog lights with welcome light (not series, but added to the equipment with the code VO, previously halogen). I have E-SYS 3.27.1 with the latest PSdZData and after coding these standard codes (before the update the cars worked) it does not work. In E-Sys set MAPPING_NEBELSCHW_L_PART_OF_W to soft on, and additionally checked with bimmercod how it looks and:
I suspect that you need to change the Welcome Light cornering light code, not fog light as it was before, but which code in e-sys?
I have a free version of Bimmercode and if the app "sees" correctly that it is not coded, maybe it will be able to encode it effectively?
      11-30-2021, 09:22 AM   #19
Edd321
Drives: Bmw 428i
Hello. I have a 4 series with Adaptive LEDs (pre LCI) from factory.
I want to have low beam welcome lights at night when i unlock the car. Now i only have the halos light up in day/night when i unlock the car.
I tried looking everywhere and 3 people tried coding but couldn't figure it out.
On some places i found that only the normal LED or Xenons can do this, not the Adaptive LED.
