08-03-2020, 03:21 PM | #23 | |
Cheapskate
4447
Rep 4,993
Supr3me551.00 |
08-03-2020, 04:21 PM | #24 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
Thats helpful thanks. I had to believe that daily operation would work it out eventually too but sometimes the stuff in forums can make you paranoid lol
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
08-06-2020, 07:26 PM | #25 | |
Rep 10,256
Hoping bayern68 will see this message. Would be grateful for a copy of the repair invoice. |
09-12-2020, 11:49 AM | #26 |
Rep 40
Drives: '16 340i Estoril/Saddle/THP
Not sure if this is helpful or not but I had my turbo replaced and have had no coolant issues since. Though technically it wasn't a coolant leak that lead to replacement of the turbo.
I bought my '16 CPO last year out of state and drove it home. Car had low coolant light on when I bought it but techs filled it prior to me leaving the dealership. An hour or two later on the drive home, low coolant indicator again. Monitored temps and stopped at a dealership in the next town. Tech said he put a very small amount of coolant in and warning went away. I don't remember if I got any warnings on the rest of the drive home but it definitely remained an intermittent issue after I got home. Though I was still under warranty, I didn't bring it in until I was due for an oil change. I brought up the coolant issue at this time. High temp circuit was empty so they filled and ran pressure test but no issues detected. However, upon routine inspection, an oil leak was noticed to be coming from the turbo. They ended up replacing the turbo. This was between Christmas and New Years last year. In that time and roughly 5k miles since, I've not had any coolant issues. So, despite the turbo not actually being indicated as the problem with the coolant loss, the new turbo appears to have resolved the issue. Not sure if this helps you cfm56d7b but the invoice references SIB 11 15 16 as to what lead to the turbo being replaced. |
09-12-2020, 08:16 PM | #27 |
Rep 1,369
5k miles isn't nearly a long enough sample set to indicate the turbo made a difference. I didn't get the initial low coolant warning until 19K.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
09-13-2020, 09:50 AM | #28 |
Rep 40
True, the turbo could have some flaw that is prone to leaking and it could take thousands of miles to get a new one to leak again but considering I would get the indicator light after a hundred or so miles, I think 5k is enough to say that the turbo was the cause of the leak. Again, there could have been something else causing the coolant to disappear but the only thing that I know of to be replaced within the engine since I bought the car was the turbo and I've had no coolant issues since.
2016 340i Estoril Blue/Saddle Brown M-Sport THP
2011 Z4 35i Midnight Blue/Red (Sold) 2006 330i Sprk Graphite/Black (Sold) |
09-13-2020, 11:37 AM | #29 | |
Rep 10,256
10-07-2020, 07:15 AM | #30 |
Rep 104
What are you guys using for coolant to top off? I bought my 2016 340 in april of 2019 with 32K on it. I've now just gotten my 4th low coolant warning message w 71K miles on it. The few other times i've just topped off with water because the owners manual of course doesn't spec coolant for it. Which has undoubtedly diluted the protection.
2016 340i X / MP STG 3 DME / STG 1 TRANS / NGK 94201 @ .023 / NO BOLT ONS
10-07-2020, 09:25 AM | #32 |
Rep 104
Yes, purified. Same as distilled. Not interested in trekking to the dealer and paying $30 for a gallon of it.
10-15-2020, 02:20 PM | #34 |
Rep 139
Hey guys
I started up my 17 340 not long before I am writing now and got a coolant low message Turned the car off and back on and didnt get the message again Turned it off, ran into the store, and back on and still no message Whats going on here? Worth running to the dealer? |
10-15-2020, 02:43 PM | #35 | |
Rep 1,239
rambalu8078.00 |
10-15-2020, 02:52 PM | #36 | ||
Rep 139
10-17-2020, 03:47 AM | #37 |
Rep 1,452
Big yikes.
2022 CT4-V Blackwing 6-speed
11-18-2020, 02:46 PM | #38 |
Retired Car Nut
42
Rep 55
My experiences with coolant loss with B58
FWIW these are my experiences with coolant "consumption" on the B58 engine. My story begins with my 2017 340i. Throughout the entire time I owned the car I had to periodically add coolant to both the low temp and high temp circuits. Following the forums this appears to be a feature of this version of the B58 with a widespread number of instances being reported, and that is just representative of the owner population that participates in forums like this. Rather than being too concerned about it I just kind of accepted it as the way it was for whatever reason since it seemed to be so widespread and all of the dealer attempts seemed to never really identify a source for the consumption. I just kept coolant in the garage and periodically topped up both reservoirs. I had the car from new until it had 51,000 miles on it and the coolant consumption rate remained steady over the entire time I owned the car. No evidence of any external leaks anywhere and I always had oil analysis done at every oil change with 0 coolant being detected in the oil. In May of this year a driver turned left in front of me at an intersection and the car was totalled. (Very sad day, but no injuries, thank you BMW). In my time in owning the '17 I probably added 1 gallon or more of coolant spread over both cooling circuits.
I replaced the car with a 2020 M340i after waiting for 3 months for the car to get built (thanks to the COVID joys). I now have over 5000 miles on this car and it has used absolutely zero coolant, and I mean absolutely zero out of either reservoir. This car has the latest "version" of the B58 in it obviously and something is definitely different. Could it have been the turbo on my 2017, who knows as I didn't really pursue it and once again kind of looked at it as a feature. If it was the turbo, I would have expected the level to only drop in the low temp cooling circuit which I believe covers the turbo and intercooler. The high temp circuit covers the engine itself and the two circuits are not connected. And yet both consumed coolant. Nothing in the oil, nothing showing externally on the engine. Is this information useful, perhaps not, but it is at least mildly interesting, at least to me. |
12-27-2020, 03:54 PM | #40 |
Rep 11
Experienced very small loss with white residue on threads of large reservoir.
Applied a tiny smear of silicone grease to the inner bore of the hole where the "O"rings seat. Have done about 7000km. since with absolutely no loss of coolant and no white residue evident when cap removed. Cap was still firm to unscrew but not ridiculously tight like it was originally when exhibiting the leak. Hope this may be of some help. |
12-27-2020, 05:56 PM | #41 | |
Rep 413
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
dsc88864.50 |
07-29-2021, 01:57 PM | #43 | |
Cheapskate
4447
Rep 4,993
